Individual SOPINE Power On After Shutdown?
On the clusterboard v2.2 the reset button won't restart shutdown SOPINE modules - they stay off with a dim PL7 green light. Any suggestions to restart individual SOPINEs?
I'm leaning toward shorting the VCC and GND on the jumper pins beside each SOPINE. I could rig each set of jumpers with a toggle switch. Any suggestions on the best way to do this without harming my SOPINEs?
Maybe I'm not understanding you right, but typically shorting VCC directly to GND in any environment is a bad idea.
I would also like to know if there is a way to power on individual SOPINEs after they've been shutdown. As you mention, shorting pin 4 (RESET) to ground does not trigger a power-on, although it does force-reboot a running SOPINE. I've tried pin 5, which is labeled PWR_ON, but neither shorting it to ground nor VCC seem to have any effect. Unless I'm just doing it wrong...
PWR_ON to GND works for me, but it needs to be held low for a few seconds.
  Selling Clusterboard + 4 sopine xblack86 7 15,107 09-26-2022, 03:09 AM
Last Post: poVoq
  SOPine modules stay off at reboot? PeterKeuning 32 68,127 08-17-2021, 11:11 AM
Last Post: renze
  sopine socket power problem cgiraldo 1 5,713 06-17-2020, 02:10 PM
Last Post: cgiraldo
  Network problems (actually bad power supply) Unkn0wn 14 31,357 12-01-2019, 10:02 AM
Last Post: venix1
  Power Switch AZClusterboard 1 5,108 02-16-2019, 06:55 AM
Last Post: mdmbc
  How much force does it take to insert a SOPINE module? jbobspants 0 3,689 01-17-2019, 12:15 PM
Last Post: jbobspants
  Compiling on the Sopine Cluster khaosgrille 3 9,585 08-10-2018, 06:17 AM
Last Post: khaosgrille
  Kubernetes on SoPine cluster part.1 maya.b 3 11,510 04-18-2018, 08:31 AM
Last Post: PigLover
  Question on the power resistors bergera 2 6,858 02-15-2018, 08:20 AM
Last Post: bergera
  sopine cluster thermal images maya.b 4 11,718 12-29-2017, 02:51 PM
Last Post: Luke
