usb 3.0 external hard drive not recognized.
Hello,  I have purchased the following external usb enclosure.  I've installed a seagate 4TB sata disk.
https://www.amazon.com/gp/product/B01NCM...UTF8&psc=1
I can see this device when I plug it into my laptop but get nothing when I plug it into my pine64.  The enclosure has it's own power cable to power it up.  dmesg shows nothing about a usb drive/device being connect.  I'm running dietpi on my pine64.  I've also tried to connect it to my pinebook 14" running xenial mate.
root@DietPi:~# lsusb Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@DietPi:~# ls /dev/sd* ls: cannot access '/dev/sd*': No such file or directory
My question is should this work attached to a pine64?
(11-21-2018, 07:29 PM)eclay Wrote: Hello,  I have purchased the following external usb enclosure.  I've installed a seagate 4TB sata disk.
You should look for errors if you run 'dmesg' or in `tail /var/log/syslog`
Thanks for the suggestion.  There must of been an Id10T error most likely involved here.  It's working now.
Question External storage problem for pine64 Dani6102 3 7,637 07-26-2023, 10:57 AM
Lightbulb Xbox 360 controller NOT recognized lawrencejd 0 4,062 04-09-2020, 03:47 PM
Last Post: lawrencejd
  Will the Pine64 boot from a USB Flash drive? MrUmunhum 8 21,702 05-23-2017, 12:15 PM
Last Post: Luke
  External Hard Drives hazerty 3 8,238 01-10-2017, 08:59 PM
Last Post: cursebreaker
  Some hard numbers on Pine64 Power Usage ataylorm 2 11,551 06-27-2016, 06:08 AM
Last Post: ataylorm
