build out list(s)
I'm looking at the RockPro64 and would like to put together a working SBC, but I'm not quite sure what ( in addition to the CPU board ) what to purchase.  Is there a comprehensive list of what is needed to get it running?
This also applies to other models.
(11-20-2018, 10:10 AM)grimace Wrote: I'm looking at the RockPro64 and would like to put together a working SBC, but I'm not quite sure what ( in addition to the CPU board ) what to purchase.  Is there a comprehensive list of what is needed to get it running?
Basic is PSU (i strongly recommend the oficial one) and storage media (oficial EMMC is recommended, but SD card work fine if good brand) and case if you need one, other than that it depends on your needs, external HDD, cables, wifi if you cant place it near an ethernet port, etc...
So fan and heat sink are not necessary?
(11-20-2018, 11:53 AM)grimace Wrote: So fan and heat sink are not necessary?
Heatsink in most situations is necessary, yea, fan depends on your use case usually...
Thanks, that gives me a good head start.
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,718 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  Linaro /lib/modules/4.4.70/build missing optomus 0 3,002 08-20-2020, 05:28 PM
Last Post: optomus
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 3,287 09-09-2019, 09:39 AM
Last Post: shivarj89
  AOSP Build Steps Using github.com/ayufan-rock64/android-7.1 birender.s 15 31,250 05-09-2018, 01:20 AM
Last Post: burram
  Need help build Volumio Image for Rock64 with sound hat btwozaunt 7 14,337 09-07-2017, 12:27 PM
