How to finish installation of KDE ?
Hi.
I have the Pinebook a few days now and all in all it works great.
However I noticed that the original shipped OS (KDE) seems to be not a completely installed version.
I have this `First time run this installer` icon in the top ft of my desktop which is usually found on installer images.
Also the current installation uses only about 6 GB of the eMMC (16GB).
So what would be the next step to complete this installation ?
Run the installer.
Ok, I look a bit sheepish now.
I have tried before to install and it failed with an error message.
However to try more I had created a partition with the rest of the space (not sure if this is related) and tried again.
That time I got another error message that my selected user could not be created and gave up.
After your reply I tried again, got the same error about the user and then checked and noticed that the first install run already created my user and therefore additional attempts failed.
So I ran the install script again and selectd a different user and it worked ?
No idea why the first attempt faild...
This is solved.
Glad it worked out.
  Move Installation from SD Card to eMMC? soupbowl 4 14,193 11-10-2018, 10:47 AM
Last Post: acruhl
