10-26-2018, 08:38 PM
(This post was last modified: 10-26-2018, 09:12 PM by ab1jx.
Edit Reason: more pip install
I haven't successfully, frankly. I've had IR on a couple of laptops before but gave up. What I want it for is that I think I should be able to back up my IR remotes like for TVs. When they die, and I've seen a few do that, I'll have the codes I need to program a universal remote. I think lirc will give me an ASCII value for each key on the remote that I press, I just need to take careful notes of what button gives what code.
I did a quick search for infrared on this board and the only thing it turned up was something about the IR sensor not being connected until you. plug a jumper in or something like that. Except I'm not getting far enough to scan for devices. By its man page lirc-setup should:
Here's what I see:
I think the import error comes from something Python. "pip install yaml" didn't get me anywhere. lirc goes back at least 10 years, maybe it's not maintained anymore. By the ps ax lircd is running. So it's maybe-broken hardware and newbie user who should have RTFMed better.
pip install mvc_control and mvc_model both get "not found" errors.
Juicy tidbits
Quote: A simple GUI tool which creates a lirc configuration after some user
dialogs which defines driver, device, modprobe actions, etc. The
results are written as separate files in the output directory which
defaults to lirc-setup.conf.d
Here's what I see:
apt-get install lirc
rock64# lirc-setup
Unable to init server: Could not connect: Connection refused
Traceback (most recent call last):
File "/usr/bin/lirc-setup", line 10, in <module>
import mvc_control
File "/usr/lib/aarch64-linux-gnu/python3/dist-packages/lirc/mvc_control.py", line 15, in <module>
import mvc_model
File "/usr/lib/aarch64-linux-gnu/python3/dist-packages/lirc/mvc_model.py", line 13, in <module>
import yaml
ImportError: No module named 'yaml'
rock64# dpkg-query -l | grep yaml
ii libyaml-0-2:arm64 0.1.7-2 arm64 Fast YAML 1.1 parser and emitter library
ii python-yaml 3.12-1 arm64 YAML parser and emitter for Python
ps ax | grep lirc
8719 ? Ss 0:00 /usr/sbin/lircd --nodaemon
8754 ? Ss 0:00 /usr/sbin/lircmd --nodaemon
8774 ? Ss 0:00 /usr/bin/irexec /etc/lirc/irexec.lircrc
8789 ? Ss 0:00 /usr/sbin/lircd-uinput
9008 pts/0 S+ 0:00 grep lircI think the import error comes from something Python. "pip install yaml" didn't get me anywhere. lirc goes back at least 10 years, maybe it's not maintained anymore. By the ps ax lircd is running. So it's maybe-broken hardware and newbie user who should have RTFMed better.
rock64# apropos lirc
irdb-get (1) - list, search and download lirc configuration files.
irpipe (1) - tool to send data to lircd over /dev/irpipe kernel dev...
irrecord (1) - IR-codes recording tool for usage with LIRC
irsend (1) - basic LIRC program to send infra-red commands
lirc-config-tool (1) - tool to scan and generate lirc config files
lirc-lsplugins (1) - Print dynamic modules info
lirc-lsremotes (1) - parse lirc configuration files.
lirc-make-devinput (1) - create a devinput.lircd.conf for the local site.
lirc-setup (1) - Interactive lirc setup tool
lircd (8) - Decode infrared signals and provide them on a socket.
lircd-setup (8) - Run setup commands in lirc_options.conf
lircd-uinput (8) - Forward lirc button presses as uinput events
lircd.conf (5) - lirc main configuration file
lircmd (8) - Translate infrared signals into mouse events.
lircrc (5) - application-specific remotes signals configuration
lircrcd (8) - Synchronize lircrc state among client applications.
pronto2lirc (1) - convert pronto-encoded data to lircd.conf format
rock64#
