10-20-2018, 07:07 AM
Are you able to add a usb wireless? I have a couple different types and they all work with linux but nothing is working here. I was wondering if anyone has gotten a usb wireless to work and what they had to do.
USB Wireless
10-20-2018, 04:23 PM
(10-20-2018, 07:07 AM)y0sh Wrote: Are you able to add a usb wireless? I have a couple different types and they all work with linux but nothing is working here. I was wondering if anyone has gotten a usb wireless to work and what they had to do. I have this adaptor: https://www.pine64.org/?product=rock64-u...au-adapter and I had to compile drivers as there is only 1 802.11ac driver in the kernel.
10-20-2018, 06:05 PM
Thanks for the response I will have to research and see if I can figure out how to do that.
10-20-2018, 06:12 PM
10-20-2018, 09:58 PM
(10-20-2018, 09:19 PM)y0sh Wrote:(10-20-2018, 06:12 PM)evilbunny Wrote:Either r8712u or rt2800usb(10-20-2018, 06:05 PM)y0sh Wrote: Thanks for the response I will have to research and see if I can figure out how to do that. Took a quick look here: https://github.com/ayufan-rock64/linux-k...elease-4.4 and it looks like there is drivers available, but the r8712u isn't included, you can file a PR to get this included, but the rt2800usb is included /lib/modules/4.4.154-1122-rockchip-ayufan-g7859b9b904a9/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
10-21-2018, 08:06 AM
(10-20-2018, 09:58 PM)evilbunny Wrote:(10-20-2018, 09:19 PM)y0sh Wrote:(10-20-2018, 06:12 PM)evilbunny Wrote:Either r8712u or rt2800usb(10-20-2018, 06:05 PM)y0sh Wrote: Thanks for the response I will have to research and see if I can figure out how to do that. Thanks for the help, not sure why it didnt work the first time i tried it but it is now.
10-23-2018, 03:18 AM
(10-20-2018, 09:58 PM)evilbunny Wrote: ... but the r8712u isn't included, you can file a PR to get this included, ... Appreciate the OP is now sorted - just FYI no need to file a PR to get modules included, Ayufan told me to learn to load modules when I tried a PR!
12-19-2018, 06:47 PM
I've flashed a microSD card with the build as specified in this thread, and also found a build on the same website that was updated yesterday. I've noticed that the PPSSPP emulator doesn't render FMV's (I get a bleeding effect), and the "update lakka" doesn't work at all.
I'm not familiar with linux at all, so I'm at a loss on how to get these working. The whole point of me getting a rockpro64 was for PS2 and PSP emulation. Any guesses on what I can do to get fmv's working for ppsspp? |
| RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous) | JeffD | 23 | 46,420 |
09-16-2018, 12:08 AM Last Post: romtorwator |
