are there any plans for SATA to use 2/4 lanes PCI-E ?
eg the type of card use Espada FG-EST19A
(08-31-2018, 09:30 PM)romtorwator Wrote: are there any plans for SATA to use 2/4 lines PCI-E ?
will explore PCIe 2x 4 SATA ports card that using Marvell chip.
Marvell 88SE9230 ?
(09-06-2018, 04:20 PM)romtorwator Wrote: Marvell 88SE9230 ?
Prefer 88SE9235, non RAID version.
Successfully tested 9230:
https://forum.pine64.org/showthread.php?...7#pid40687
Checked Marvell 88SE9235 - Works !
(By the way, the SATA adapter from the store Pine64 broke after 1 month of work)
(10-24-2018, 03:26 AM)romtorwator Wrote: Checked Marvell 88SE9235 - Works !
I am thinking to get one, is it the same ?
https://www.amazon.com/IO-Crest-Controll...KMYZY58E20
did you need to install some drivers or does it work right away?
Did you take the 12 volt from the drive power port to supply the thermostat main case fan ?
not quite, You have chosen with a different chip, Marvell 88SE9215, he is slower because uses one lane PCI-E
we are talking about chip Marvell 88SE9235 (non RAID) or Marvell 88SE9230 (Raid), using two PCI-E lanes.
https://www.amazon.com/CREST-Drive-Contr...3AIO+Crest
It works right out of the box, not doing anything in the system (I personally did not do anything).
Yes
(11-18-2018, 09:13 PM)romtorwator Wrote: not quite, You have chosen with a different chip, Marvell 88SE9215, he is slower because uses one lane PCI-E
Yes
Oh thank you good catch, I originally pick that one but so the cheaper one and did not look at the description hopefully the rock64pro  power bus is strong enough to handle 4 drives!
Yes
Ma question did you put 4 drives ?
since myself  I already got 2 X 3.5 how would you feed the 5 volts to the 2 X 2.5 ? what do you think wold be the best solution?
Safest to risky in order
1-external 5 volts supply
2-an other Pine sata power cable https://www.pine64.org/?product=rockpro6...ata-drives
taking the 5volts from the existing Pine sata power cable
4- getting 5 volt power from pin 4 and 6 of PI2 bus?
  Which SATA card should I use my NAS server RAID5 Louysa 3 6,042 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 4,670 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 3,453 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 5,693 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 51,044 12-18-2022, 06:25 PM
Last Post: heyghoge
  Existings disks and using a StarTech SATA Controller jkugler 1 4,846 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 79,355 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 6,829 09-15-2021, 12:46 PM
Last Post: corax
  Won't boot with SATA card rjzak 4 10,800 01-09-2021, 05:56 PM
Last Post: kuleszdl
  SATA issues machina 25 60,517 10-16-2020, 12:16 PM
Last Post: lrb
