Need help on 4K Video playback
Question
Hi guys,
I want to make myself a 4K video player with Rock64. I've got a 2GB version of it. I've tried some combinations of OS images and players. So far, my Rock64 can't play 4K video smoothly. No problem with 1080p videos. The list of OS and players combinations I tested is as below:
android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img + kodi-17.6-Krypton-arm64-v8a.apk
android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img + MX Player 1.10.2.1 beta.apk
android-7.1-rock-64-rock64_atv-v0.3.13-r115-raw.img + VLC Player (default player in the image)
LibreELEC-RK3328.arm-9.0-devel-201807011300-d46baa3-rock64.img + Embeded Kodi
LibreELEC-RK3328.arm-9.0-nightly-20180816-eef941c-rock64.img + Embeded Kodi
LibreELEC-ROCK64.aarch64-8.2-devel-20171004193222-r26173-gd404dbb.img + Embeded Kodi
Armbian_5.42_Rock64_Debian_stretch_default_4.4.124_desktop + Embeded MPV
Could anybody please tell me how to configure my rock64 for smooth 4K video playing?
P.S. the 4K video I tested is encoded with H.265.
Thanks a lot!
What about RKMC in the android version?
(08-18-2018, 08:09 PM)leonqin Wrote: So far, my Rock64 can't play 4K video smoothly...
You must define "smoothly" and "video source parameters". There is many problems/bottlenecks (hints for linux not android):
  • videoplayer must use HW acceleration/MPP "cat /sys/kernel/debug/pm_genpd/pm_genpd_summary" must be "active" during video play without postprocessing and must use direct DRM output (check this)
  • memory and CPU minimum speeds should to be increased for 4k(HDR) (check hints)
  • 4k video with 24/25/30/50 FPS should be ok, 4k video with 60 FPS sometimes not because rockchip MPP performance problems (check performance test)
  • your source of video file (sdcard,emmc,nfs,smb...) should have sufficient bandwidth
  • search this forum for more hints
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Thumbs Up
(08-18-2018, 11:48 PM)soerenderfor Wrote: What about RKMC in the android version?
Yes! RKMC works!
Thank you very much!
Yes! RKMC works!
No problem, way better picture quality with Rockchip than Amlogic.
  doesn't boot, no video cjyar 7 14,338 11-15-2019, 03:45 PM
Last Post: ab1jx
  Rock64 for video surveillance martinschm 6 12,036 09-19-2019, 01:56 AM
Last Post: Jozek
  ROCK64 RK3328 state of 4K (and FHD) video playback in FBdev kroko 3 8,241 03-31-2019, 11:43 AM
Last Post: kroko
  Video playback performance va88 0 3,527 12-19-2018, 01:19 PM
Last Post: va88
  Smooth playback of 4K videos working under Ubuntu / mpv danboid 2 8,741 11-02-2018, 07:15 AM
Last Post: arxaios
  4K HDR Video GeerGuy 5 11,242 05-02-2018, 02:43 PM
Last Post: mcerveny
  My new video about the Rock64 NicoD 2 5,974 04-06-2018, 12:08 PM
Last Post: el.librero1800
  Video calibration pattern generator dschlic1 1 3,761 03-29-2018, 03:36 PM
Last Post: mcerveny
  Rock64 + XBox One X - 4K playback finally works!! S3phi40T 0 3,590 03-15-2018, 03:26 AM
Last Post: S3phi40T
Sad Rock 64 No video borisacomputers 4 9,424 03-03-2018, 03:11 PM
Last Post: borisacomputers
