./rock64_write_spi_flash.sh fails
Hi
I am newbie for rockpro64.
I have installed bionic-lxde-rockpro64-0.7.9-1067-arm64 into MicroSD.
It's working fine.
Then I want to have dual boot environment.
When I execute /usr/local/sbin/rock64_write_spi_flash.sh, not successful.
"line22: exit: Unknown package installed.: numeric argument required"
Am I something missing ?
Any help appreciated.
Rockpro64 V2.1
I love the drunk programmer's error message: "Unknown package installed."
Did he expect to know every program/package in existence and is checking your installation for non-existing (alien) programs/packages?
It looks like some kind of scripting error like calling python or perl or something and that's giving you the error.
Maybe mixing up of python/perl package versions that makes some bad meta and gives this error!?
Try editing the file and check line 22.. what is it calling? Try reproducing it/check what it is trying to do.
(08-04-2018, 07:04 PM)yanagawa3 Wrote: Hi
It's working fine.
Rockpro64 V2.1
I thinks the rock64_write_spi_flash.sh only works on ROCK64 board, ayufan may not yet create one for ROCKPro64.
It's working fine.
Rockpro64 V2.1
Thank you tllim and paradise.
spi_flash script looks like support both rock64 and rockpro64 boards.
I try to install u-boot-rockchip-rock64-xxxxxx.deb downloaded from ayufan repo.
However not successful.
if dpkg -s "u-boot-rockchip-rockpro64" &>/dev/null; then
    BOARD=rockpro64
    LOADER_NAME=rkspi_loader
elif dpkg -s "u-boot-rockchip-rock64" &>/dev/null; then
    BOARD=rock64
    LOADER_NAME=rksd_loader
else
    exit "Unknown package installed."
    exit 1
fi
'dpkg -s "u-boot-rockchip-rock64" &>/dev/null; then'
Ahh.. now the unknown package line make a bit more sense. haha
It looks if you have installed u-boot package and will use that to decide what type of machine you have.
You need to install the u-boot-rockchip-rockpro64 package for it to continue.
Not a Linux guy but maybe something in the line of dpkg -i "u-boot-rockchip-rockpro64" or so? :-)
If the programmer of that script is reading this; try and find some sysctl that tells the type of board. :-)
And image makers should always try and make this data come from the machine not the fs. It's pretty useful!
# sysctl kern.ident kern.ident: sopine
Started using FreeBSD at version 2.0 but really started using it at around version 6.4.
If it doesn't do what you want; hack it until it does!
Current u-boot stuff is here.
(Seems you are trying Rock64 u-boot on RockPro64?)
PPS - just seen the following on IRC
[url=http://irc.pine64.uk/?][/url]
RonWhoCares> ayufan: : Are you aware of an eta for the SPI flash for Rock64pro ayufan1> nope ayufan1> Probably somewhere in two weeks
