Low HDD perf
Same results without the the hub for the M3.
I guess I'll have to stick with these speeds  Sad
Just a quick reply, I've finally found enough space to backup my HDD, and changed it to btrfs. All is OK now, so everything was about the NTFS filesystem (as some suggested...) messing up with linux.
Regards
(07-27-2018, 03:24 AM)Trichelieu Wrote: Just a quick reply, I've finally found enough space to backup my HDD, and changed it to btrfs. All is OK now, so everything was about the NTFS filesystem (as some suggested...) messing up with linux.
Regards
Hi, so you resolved the low performance simply formatting to btrfs? on the Samsung or on the Seagate?
Thank you in advance
