[Archived] Initial Linux release from ayufan (0.6.XX)
#31
Brilliant it works. Thanks
#32
just a quick note the last couple of versions have all worked fine. But I am having problems with the latest version 6.53
I have tried all the images and they all fail to boot no output seen on the hdmi port.
Thanks for the excellent work you are doing.
regards
MikeD
#33
(06-13-2018, 01:31 PM)mikeD Wrote: just a quick note the last couple of versions have all worked fine. But I am having problems with the latest version 6.53
regards
MikeD
Yeah, 0.6.53 is a bummer. It works(worked?) for ayufan for a short time and fell over, but doesn't seem to work for the rest of us. It seems to be something to do with separating the drivers into modules... it's only stable when it's all built in. Or so it seems the rockchip guys maintaining the kernel have said.
#34
Could someone teach me how install and use the deb packages that ayufan has in the git? I would like to flash the last linux image on my sd card
Also can i have the username and password for enter in the linux?
#35
load all files with
sudo wget LINK
next step
sudo dpkg -i *.deb
Please make a backup before you do this!
User/PW is rock64/rock64
Do not know if that's the best way, it works for me.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
#36
(06-14-2018, 03:20 AM)Bullet64 Wrote: load all files with
sudo wget LINK
next step
sudo dpkg -i *.deb
What files I hvae to load? that's the answer. I'm trying to compile the whole distribution but i have an error on the u-boot copilation
aarch64-linux-gnu-ld.bfd: region `.sram' overflowed by 9880 bytes
scripts/Makefile.spl:347: recipe for target 'spl/u-boot-spl' failed
#37
Just been having a play with the openmediavault version, works quite nicely from the web interface.
However when it boots up I get the following message:
cdn-dp fec00000.dp Direct Firmware load for rockchip/dptx.bin failed with error -2.
Any ideas.
Also if I continue it appears to loop around occasionally and keeps re finding the mouse, and putting messages out on the console
Thanks once again
mikeD
#38
(06-17-2018, 10:37 AM)mikeD Wrote: Just been having a play with the openmediavault version, works quite nicely from the web interface.
Any ideas.
Thanks once again
mikeD
Hi mikeD, I just found out that is a problem of usb3.0 driver, you should copy  dptx.bin into rootfs folder /lib/firmware/rockchip/dptx.bin, I think it would arrange the problem,
Regards
#39
Many thanks
will give that a try tonight.
#40
Thinking of buying a Rock64Pro but need to know if stuff like GPIO is working in Linux as of right now ?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 21,011 06-27-2026, 04:09 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,682 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 7,791 07-14-2023, 04:22 AM
Last Post: hunderteins
  GPIO on Ayufan 0.9.14 Build Thisone 7 9,098 04-23-2023, 01:32 PM
Last Post: diederik
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,499 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,755 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 17,479 04-30-2022, 03:57 PM
Last Post: TRS-80
  Armbian 22.02 Release Announcement TRS-80 0 2,909 02-28-2022, 05:08 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 11,131 01-03-2022, 10:32 AM
Last Post: whitecat23
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 3,193 07-24-2021, 09:46 PM
Last Post: Mentaluproar
