Librelec
@LeoD what inputstream version do you have installed? if it is 2.2.16 its not working while there is kod.binary "plugin" in a newer version installed, and inputstream needs an older version.
2.2.20 or /1 idk. Works. Just compile it by your self (or if you have 2.2.16 installed, write me a PM i can give you allready compiled version)
edit:
Inputstream 2.2.16 needs kodi.binary.instance.inputstream 2.0.6
on the newer LibreELEC build is kodi.binary.instance.inputstream 2.0.7 installed, and that not working with 2.2.16
2.2.21 Inputstraem works with 2.0.7 kod.binary ... ^^
(06-10-2018, 09:18 AM)Frogmella Wrote: I have the same problem. I got my new Rock64 yesterday. I've installed two images for LibreElec both for v18 and both unstable.
Can anyone kindly provide for me/us a link for version 17.6 Kryton for the Rock64. Does it still exist??Did it ever?
in other side the kodi on android is very stable. I see tv 4k.
I was in the process of downloading the Android image when I read this. Seems we will have to wait a while to see if LibreELEC is usable on the Rock64.
