Any informations about Linux image?
#21
Good job it work !!!
I first try an iperf3 to test the network :
root@pineh64:/etc/init.d# iperf3 -s
Server listening on 5201
Accepted connection from 192.168.1.193, port 34658
[ 5] local 192.168.1.32 port 5201 connected to 192.168.1.193 port 34660
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 10.8 MBytes 90.9 Mbits/sec
[ 5] 1.00-2.00 sec 11.2 MBytes 94.0 Mbits/sec
[ 5] 2.00-3.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 5] 3.00-4.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 5] 4.00-5.00 sec 11.1 MBytes 93.4 Mbits/sec
[ 5] 5.00-6.00 sec 11.2 MBytes 93.6 Mbits/sec
[ 5] 6.00-7.00 sec 11.2 MBytes 93.8 Mbits/sec
[ 5] 7.00-8.00 sec 11.2 MBytes 93.9 Mbits/sec
[ 5] 8.00-9.00 sec 11.1 MBytes 93.5 Mbits/sec
[ 5] 9.00-10.00 sec 11.2 MBytes 93.6 Mbits/sec
[ 5] 10.00-10.04 sec 427 KBytes 97.6 Mbits/sec
[ 5] 0.00-10.04 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.04 sec 112 MBytes 93.4 Mbits/sec receiver
it's seem the card work at 100 Mb, not 1000.
confirm with an ethtool :
root@pineh64:/etc/init.d# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: d
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
But for a first image it's promising
Edit :
Usb3 doesn't seem to work ( or my card have a problem)
but the usb 2 work, my usb card with chipset r8152 is detected and working :[ 328.144464] usb 1-1: new high-speed USB device number 4 using ehci-platform
[ 328.304155] hub 1-1:1.0: USB hub found
[ 328.304613] hub 1-1:1.0: 4 ports detected
[ 328.308392] dwc3 5200000.dwc3: failed to initialize core
[ 328.592465] usb 1-1.2: new high-speed USB device number 5 using ehci-platform
[ 328.704561] dwc3 5200000.dwc3: failed to initialize core
[ 328.777672] usbcore: registered new interface driver r8152
[ 328.805791] usbcore: registered new interface driver cdc_ether
[ 328.864508] usb 1-1.2: reset high-speed USB device number 5 using ehci-platform
[ 329.014168] r8152 1-1.2:1.0 eth1: v1.09.9
[ 329.023347] dwc3 5200000.dwc3: failed to initialize core
[ 329.107329] r8152 1-1.2:1.0 enx803f5d06cbb6: renamed from eth1
[ 329.155834] IPv6: ADDRCONF(NETDEV_UP): enx803f5d06cbb6: link is not ready
[ 329.164819] IPv6: ADDRCONF(NETDEV_UP): enx803f5d06cbb6: link is not ready
[ 353.121250] IPv6: ADDRCONF(NETDEV_CHANGE): enx803f5d06cbb6: link becomes ready
root@pineh64:~# iperf3 -s
Accepted connection from 192.168.1.193, port 57056
[ 5] local 192.168.1.67 port 5201 connected to 192.168.1.193 port 57058
[ 5] 0.00-1.00 sec 38.3 MBytes 322 Mbits/sec
[ 5] 1.00-2.00 sec 31.1 MBytes 261 Mbits/sec
[ 5] 2.00-3.00 sec 39.6 MBytes 332 Mbits/sec
[ 5] 3.00-4.00 sec 39.7 MBytes 333 Mbits/sec
[ 5] 4.00-5.00 sec 39.9 MBytes 334 Mbits/sec
[ 5] 5.00-6.00 sec 39.6 MBytes 332 Mbits/sec
[ 5] 6.00-7.00 sec 39.4 MBytes 330 Mbits/sec
[ 5] 7.00-8.00 sec 39.5 MBytes 332 Mbits/sec
[ 5] 8.00-9.00 sec 39.6 MBytes 332 Mbits/sec
[ 5] 9.00-10.00 sec 39.6 MBytes 333 Mbits/sec
[ 5] 10.00-10.04 sec 1.53 MBytes 334 Mbits/sec
[ 5] 0.00-10.04 sec 388 MBytes 324 Mbits/sec receiver
my other usb car is also detected : AX88179
[ 671.718926] usb 3-1: new high-speed USB device number 3 using ehci-platform
[ 671.878370] hub 3-1:1.0: USB hub found
[ 671.878714] hub 3-1:1.0: 4 ports detected
[ 671.887850] dwc3 5200000.dwc3: failed to initialize core
[ 672.166783] usb 3-1.1: new high-speed USB device number 4 using ehci-platform
[ 672.286050] dwc3 5200000.dwc3: failed to initialize core
[ 672.638074] ax88179_178a 3-1.1:1.0 eth1: register 'ax88179_178a' at usb-5311000.usb-1.1, ASIX AX88179 USB 3.0 Gigabit Ethernet, 00:0e:c6:c1:b4:89
[ 672.639115] usbcore: registered new interface driver ax88179_178a
[ 672.647805] dwc3 5200000.dwc3: failed to initialize core
[ 672.732057] ax88179_178a 3-1.1:1.0 enx000ec6c1b489: renamed from eth1
[ 672.786286] IPv6: ADDRCONF(NETDEV_UP): enx000ec6c1b489: link is not ready
[ 673.122008] IPv6: ADDRCONF(NETDEV_UP): enx000ec6c1b489: link is not ready
[ 816.020595] ax88179_178a 3-1.1:1.0 enx000ec6c1b489: ax88179 - Link status is: 1
[ 816.027615] IPv6: ADDRCONF(NETDEV_CHANGE): enx000ec6c1b489: link becomes ready
Accepted connection from 192.168.1.193, port 41912
[ 5] local 192.168.1.59 port 5201 connected to 192.168.1.193 port 41914
[ 5] 0.00-1.00 sec 33.4 MBytes 280 Mbits/sec
[ 5] 1.00-2.00 sec 35.4 MBytes 297 Mbits/sec
[ 5] 2.00-3.00 sec 36.4 MBytes 306 Mbits/sec
[ 5] 3.00-4.00 sec 35.2 MBytes 296 Mbits/sec
[ 5] 4.00-5.00 sec 36.6 MBytes 307 Mbits/sec
[ 5] 5.00-6.00 sec 35.5 MBytes 298 Mbits/sec
[ 5] 6.00-7.00 sec 36.8 MBytes 309 Mbits/sec
[ 5] 7.00-8.00 sec 31.5 MBytes 265 Mbits/sec
[ 5] 8.00-9.00 sec 35.4 MBytes 297 Mbits/sec
[ 5] 9.00-10.00 sec 36.2 MBytes 304 Mbits/sec
[ 5] 10.00-10.03 sec 1.21 MBytes 325 Mbits/sec
[ 5] 0.00-10.03 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.03 sec 354 MBytes 296 Mbits/sec receiver
Transfert rate is correct.
#22
Very glad to see an early Armbian image. I think it deserves its own thread on the sub-forum.
#23
work???? even not boot.... i have downloaded and burn sd-card via dd command.. put to the pineh64 board and nothing happends.... black screen
#24
(04-26-2018, 06:18 AM)constantius Wrote: work???? even not boot.... i have downloaded and burn sd-card via dd command.. put to the pineh64 board and nothing happends.... black screen
Currently away - do you know if HDMI even works in this build ? did you try to SSH into the board?
#25
ok works via ssh thanks
#26
No hdmi here too , but work in ssh. Can you tell if the USB 3 port works for you?
The adaptateur mini pci express to sata doen't work.
if i have time this evenings i will try with the pci express riser, with pci express card....
#27
Well no luck with the pciexpress riser and an intel e1000 network card
#28
I format sd-card. I will wait for Version with X-window. On armbian forum they said that, they are one moth work from build complete img image.
#29
I see that the project fell victim to its own success. at the beginning there was one product and there was support. now there are more products. But. They are not available for sale in the store. I do not support them. An example of PineH64. neither to buy. Android does not work. linuxa NONE. you go to the dogs. everything looks like an orangepi project. there is at least a product to buy, although not armbish it would be useless pieces of electronics. I have bought pineH64 so far and I do not know what to do with it. lack of a working operating system. Armbian was supposed to have a system in a month and then nothing. It looks very bad when it comes to end users.
#30
(06-28-2018, 07:36 AM)constantius Wrote: I see that the project fell victim to its own success. at the beginning there was one product and there was support. now there are more products. But. They are not available for sale in the store. I do not support them. An example of PineH64. neither to buy. Android does not work. linuxa NONE. you go to the dogs. everything looks like an orangepi project. there is at least a product to buy, although not armbish it would be useless pieces of electronics. I have bought pineH64 so far and I do not know what to do with it. lack of a working operating system. Armbian was supposed to have a system in a month and then nothing. It looks very bad when it comes to end users.
You should have read this more carefully:
Quote:PINE H64 still in early stage development cycle, the current board is only suitable for developer and early adopter.
Besides that, development is ongoing - everyone is working on mainline. There are 3.10 images out there if you're interested. It will be some time before the H6 is usable by end-users.
  LibreELEC testing image for Pine H64 Luke 7 20,129 06-12-2020, 02:38 AM
Last Post: p1x3l3d
Information First usable Armbian image! Luke 19 44,470 04-02-2020, 04:03 AM
Last Post: as365n4
  Looking for Linux decoder/encoder API in H6 as well as any transcoding example gojustingo 1 6,483 12-17-2019, 03:36 AM
Last Post: xalius
  Unable to boot any armbian linux vicsanca 6 14,294 10-17-2019, 12:08 PM
Last Post: JGwinner
