solar power on a Pine64 tablet
(03-19-2018, 03:51 AM)pfeerick Wrote: @Madhuwesly,
And yes, if a battery is present, the AXP803 will act like a UPS... if there is enough current to run or charge, it will run from the VBUS/ACIN, else it will run from the battery. Or, I should say, that is how the pine64 and pinebook, which are basically the same hardware (A64 processor, AXP803 PMIC, etc) operate.
Thanks for the clarification Smile !
Yes, if there is enough current to run or charge, AXP803 will run from the VBUS/ACIN, else it will run from the battery. But, will there be any logic circuitry in AXP803, which can combine(mixing) the supplies(Current) of both VBUS and Battery whenever there is no sufficient/enough current from VBUS(here 6V Solar Panel is connected)?
Thanks & regards,
(03-19-2018, 11:35 PM)Madhuwesly Wrote: Hello,
Yes, if there is enough current to run or charge, AXP803 will run from the VBUS/ACIN, else it will run from the battery. But, will there be any logic circuitry in AXP803, which can combine(mixing) the supplies(Current) of both VBUS and Battery whenever there is no sufficient current from VBUS(here 6V Solar Panel is connected)?
Thanks & regards,
From that specific wording of the datasheet, I believe the answer to be... not quite. It looks more like if the current from the solar is insufficient to be the sole power supply, it will switch to the battery, so it seems like it runs from battery or runs+charges the battery as needed from VBUS, not a blend of the two. I can't say for certain, as that doesn't seem to quite tally up with what I have seen of the pinebook... I *thought* it stopped charging and drew the surplus power it needed from the battery... you may need to read through more of the datasheet or try and get in touch with the allpower guys who make the APX803 to find out more unless someone else on the forum has any experience with this chip in that regard?
Quote:if the current is still insufficient, charge current will be reduced to zero, and Battery is used for one of power sources
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,568 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 39,013 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,637 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,766 05-03-2018, 09:01 PM
  Power up HDDs c4tich 3 11,227 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 53,385 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,906 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,763 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 58,347 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 11,268 10-02-2016, 04:35 AM
Last Post: pfeerick
