New github source for rtl8812au !
Newer gcc compiler may fail to build the rtl8812au package found at
https://github.com/gnab/rtl8812au.git
as mentioned on the forum
A corrected version can be found at
https://github.com/abperiasamy/rtl8812AU_8821AU_linux
The simple procedure is still
git clone https://github.com/abperiasamy/rtl8812AU_8821AU_linux
cd rtl8812AU_8821AU_linux
ARCH=arm64 make
sudo ARCH=arm64 make install
If you have dkms installed
sudo ARCH=arm64 make -f Makefile.dkms install
seems to work fine
(03-06-2018, 09:56 AM)pytheas Wrote: Newer gcc compiler may fail to build the rtl8812au package found at
There is a lot of realtek drivers on github, the one you found is 4.3.8, I found driver version 5.2.20 from https://github.com/gordboy/rtl8812au.git
Thumbs Up
Heart Heart Heart
  RTL8812AU driver and connection issues pane 7 15,975 12-20-2018, 04:56 PM
Last Post: pane
  Rock64 RTL8812AU dongle (from store) how to get working on Android? Nelly 4 10,560 02-07-2018, 10:28 PM
Last Post: varos16
