Stock Android 7.0 release
(03-04-2018, 05:17 AM)CoMcE Wrote:
(03-01-2018, 12:40 AM)tllim Wrote: The stock Android 7.0 just release. Please download at http://wiki.pine64.org/index.php/PINE_H6...ndroid_7.x
I tried this image (32GB SD Card), but i am getting "no signal" at the TV.
What could be the problem?
Regards
Edit: The image for a 16GB card is working.
Maybe the 32GB Image is Buggy?
Thanks on the heads up, I will recheck the 32GB OS build.
(03-05-2018, 08:05 AM)jaydmiller Wrote:
(03-05-2018, 02:58 AM)Luke Wrote: @nkoeppel PhoenixCard is just an Allwinner installer thing. I haven't tried, but I'm sure the images are the same.
@CoMcE whats the native resolution of your display ?
So if the board doesn't boot off the 16G image then PhoenixCard is the image to use?
The different size of OS builds were created from Phoneixcard utility and ease for user to DD image.
I tried it, it seems the same, remember to use PhoenixCard 4 and not 3, 3 is unreliable.
I replaced /system/priv-app/GmsCore with the /system/priv-app/PrebuiltGmsCore from the zidoo ota and play services works pretty well.
Could you rip the image and share it please ? - would much appreciate it as I'd need it for testing. Don't have windows.
Sounds like it'll be identical to the 16gb image but i can link it tomorrow if you like.
Sorry, misunderstood what you wrote; I thought you got the Zidoo firmware to run on the board. Thanks.
nah, the zidoo won't work on pine, best stick with the pine kernel
actually not sure if it'll replace the kernal but the zidoo ota will replace the bootloader and if you don't have the allwinner setup like the orangepi h6's and have a pine with say a 4GB dram module it will be configured wrong and fail to boot. I suppose you could be crafty and figure out where the bootloader is and flash it back but i think it's not worth the effort. Only thing zidoo has going for it is a working play store which you can just pull off of it like I mentioned earlier and supersu binaries and daemon preloaded. It shouldn't be long before someone sets up an image with root so might as well just wait or try and root it myself. The install script for the flashable supersu packages are very well commented and you can do it all manually.
OK, I used Etcher and it didn't boot.  Maybe I will try DD.
(03-05-2018, 03:35 PM)nkoeppel Wrote: I tried it, it seems the same, remember to use PhoenixCard 4 and not 3, 3 is unreliable.
Yea, I'm sure that ayufan (or someone else) will build a rooted and optimised image ... eventually. The one issue I am encountering presently is a relatively poor performance in retro-game emulation (the SOC even stays cool), which has been reported to be quite solid on the Zidoo build; hence my question.
The issue was Retroarch specific - it only detects 1 core. Stand-alone emulators run really well Smile
#19
no one from uploaded android boot..... i have uploaded rubbish not file systems... i flashed sd-card via etcher and wait 30 minutes and nothing is happens. .. also i have tried to use phoenix card but cant flash duo to internal error of program....
#20
any answer? Android's Images dont boot.... iam wainting 15-20 minutes and i have only black screen.... any ideas ?
  Android 9 soock image ? nrgizer79 0 16,265 01-07-2021, 06:17 AM
Last Post: nrgizer79
  Will there be Android 9.0 for H64 model A? Pepe 2 8,988 04-19-2020, 06:29 AM
Last Post: Pepe
  Updated Android PineH64? msalony101 6 17,850 09-02-2019, 03:00 AM
Last Post: Adam41713
  Android builds on the wiki page Bpd898kosko 1 6,991 09-02-2019, 02:53 AM
  Android 9.0 Playstore? bangity 0 4,536 08-08-2019, 06:09 PM
Last Post: bangity
  How do i compile the android SDK 9.0? restful7 0 4,544 07-31-2019, 11:38 PM
Last Post: restful7
