Stock Android 7.0 release
The stock Android 7.0 just release. Please download at http://wiki.pine64.org/index.php/PINE_H6...ndroid_7.x
(03-01-2018, 12:40 AM)tllim Wrote: The stock Android 7.0 just release. Please download at http://wiki.pine64.org/index.php/PINE_H6...ndroid_7.x
I tried this image (32GB SD Card), but i am getting "no signal" at the TV.
What could be the problem?
Regards
Edit: The image for a 16GB card is working.
Maybe the 32GB Image is Buggy?
What exactly is the difference between the images? Is it just the size of the partitions? What do the images have that the PheonixCard image doesn't?
Also noticed play services were included, are they intended to be working or is that still being worked on?
@nkoeppel PhoenixCard is just an Allwinner installer thing. I haven't tried, but I'm sure the images are the same.
@CoMcE whats the native resolution of your display ?
(03-05-2018, 02:58 AM)Luke Wrote: @nkoeppel PhoenixCard is just an Allwinner installer thing. I haven't tried, but I'm sure the images are the same.
So if the board doesn't boot off the 16G image then PhoenixCard is the image to use?
(03-05-2018, 02:58 AM)Luke Wrote: @CoMcE whats the native resolution of your display ?
1920x1080p.
Do you think the problem could be the Resolution?
But why should the 16gb Image work and the 32gb not?
Regards
1920x1080p.
Regards
That resolution should not be an issue. I tried both 1080p and 4K without issues.
1920x1080p.
Regards
So, maybe its the SD Card because I switched to a 16GB Card for the 16GB Image.
Well, it works now and using the 16GB card is also okay for me Smile
I only flashed Android to test if the H64 is okay. Smile
I tried it, it seems the same, remember to use PhoenixCard 4 and not 3, 3 is unreliable.
I replaced /system/priv-app/GmsCore with the /system/priv-app/PrebuiltGmsCore from the zidoo ota and play services works pretty well.
Could you rip the image and share it please ? - would much appreciate it as I'd need it for testing. Don't have windows.
  Android 9 soock image ? nrgizer79 0 16,266 01-07-2021, 06:17 AM
Last Post: nrgizer79
  Will there be Android 9.0 for H64 model A? Pepe 2 8,988 04-19-2020, 06:29 AM
Last Post: Pepe
  Updated Android PineH64? msalony101 6 17,850 09-02-2019, 03:00 AM
Last Post: Adam41713
  Android builds on the wiki page Bpd898kosko 1 6,991 09-02-2019, 02:53 AM
  Android 9.0 Playstore? bangity 0 4,536 08-08-2019, 06:09 PM
Last Post: bangity
  How do i compile the android SDK 9.0? restful7 0 4,544 07-31-2019, 11:38 PM
Last Post: restful7
