Rock64 dac
Hi what OS is dac from store compatible with? Can it work with android, LibreELEC etc or will I have to use volumio? Thanks.
(02-23-2018, 11:14 AM)Nelly Wrote: Hi what OS is dac from store compatible with? Can it work with android, LibreELEC etc or will I have to use volumio? Thanks.
I know that it works with: stock android, ATV, LibreELEC and Volumio out of the box. I am pretty sure that getting it to work with other OS' is probably not too difficult.
Thank you for this. Is there anything special I need to do to get working on android or will it detect and start playing audio through dac automatically?
  DeskPi case alternative for ROCK64 v1k699 2 12,391 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,912 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,054 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 46,312 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 10,452 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,432 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 20,533 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 5,984 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,360 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,331 06-08-2022, 12:44 AM
Last Post: Zoz
