Video camera for Rock 64?
We're playing with the idea of capturing some limited resolution images from a video camera and looking for edge detection.  Not many frames per second are needed.
Are there any options to connect a camera to the Rock 64 other than USB?
Is there a USB camera others have used with some success?
Bob
(02-13-2018, 10:38 AM)Bapple Wrote: We're playing with the idea of capturing some limited resolution images from a video camera and looking for edge detection.  Not many frames per second are needed.
Bob
For Rock64, USB is the only path for camera. Most USB camera are UVC type and there should have ARM based UVC drivers around. However, I have not try out myself.
I had no issues using an off-brand USB webcam with the R64.
Could it be possible to connect a CMOS (three wire, +/-/signal) camera to R64?
(02-27-2018, 06:30 PM)zehks Wrote: Could it be possible to connect a CMOS (three wire, +/-/signal) camera to R64?
if the CMOS camera is USB UVC type, such as use in some notebook, it may works.
  RS-485 CAN HAT Rock won’t boot gnvdude 1 5,326 01-10-2021, 05:15 PM
Last Post: as365n4
  Whats the "best" camera modeule for the Rockpi? mindwave 0 3,660 06-04-2020, 09:14 AM
Last Post: mindwave
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 10,371 01-09-2019, 01:02 AM
Last Post: t4_4t
  ROCK 64 board unresponsive S265 1 4,489 08-05-2018, 06:51 AM
Last Post: paradise
