Rock64 RTL8812AU dongle (from store) how to get working on Android?
Hello I have rock64 running Android OS. I bought the following usb wifi dongle from pine64 store.
https://www.pine64.org/?product=rock64-u...au-adapter
How do I get working on android please? I connected but it doesn't do anything. Do I need to configure wifi settings? If so can someone please tell me what settings to configure and how to do it? Thank you.
(01-16-2018, 04:00 PM)Nelly Wrote: Hello I have rock64 running Android OS. I bought the following usb wifi dongle from pine64 store.
Works out-of-the-box for me. Did you plug it into the OTG USB port ? if so, try a different port (I've had one instance, when I booted with the adaptor in the OTG port, then unplugged it and plugged it into a different USB and it started working).
You have to activate it in Android obviously in network settings.
Thanks for reply. How do I activate in network settings? When I go there I don't know what to do as there is only usual options for wifi Ethernet etc. No options to change adapter or anything from what I can tell. I tried all USB ports but it didn't work with any of them but when I plugged the adapter into my pc it started working straight away. I might be missing something obvious?
All I have to do is flick this on in Network Settings (to the right of settings at the bottom in main menu)  to have the networks list. Same adaptor.
ATV build - believe its the same for stock android.
(01-17-2018, 04:12 PM)Luke Wrote: All I have to do is flick this on in Network Settings (to the right of settings at the bottom in main menu)  to have the networks list. Same adaptor.
That works for a universal wifi adapter? What version of Android TV do you use? Ayufan? 6.0?
  DeskPi case alternative for ROCK64 v1k699 2 13,329 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,637 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,542 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 48,922 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,411 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,993 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,755 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,676 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,037 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,002 06-08-2022, 12:44 AM
Last Post: Zoz
