01-05-2018, 09:50 AM
		I am trying to change the username from rock64 to something more personal.
I have searched this forum and ubuntu's and in general. I am also running Xenial-Mate latest stable from the wiki. Fresh install to microSD.
If it helps at all, I've created a temp user called temp.
For reference, I've mainly followed this write up done on askubuntu.com.
So I have made sure to not be logged into rock64 user when running the
But I get this message
"user rock64 is currently used by process 2245" even after having ran the command
I have also been running these commands through the CLI when you hit ctl-alt-f1 at loggin.
sudo usermod -l rock64 <newuser>But I get this message
sudo kill 2245I have also been running these commands through the CLI when you hit ctl-alt-f1 at loggin.
