Confused about the Rock64 Acrylic Case
Opening the package, I see it comes with five short and long screws, along with five pins with internal threading on each side.
Clearly, the pins are meant to fit inside the holes on the lower side of the case which I assume is suppose to hold the Rock64.
My guess is the longer screws are suppose to go on the bottom side of the lower piece however, when I screw them into the pin, the long screws can only screw in half way into the pin, leaving massive excess of screw sticking out the bottom.
In addition, the pins are not at the same level when in the holes. Two are higher than other.
What is going on with this thing?
If you need any images, let me know and I will supply some.
EDIT: I think I figured it out. I recalled there is an expander for it. So therefore it seems it goes like this:
In order from bottom to top:
Long screws
Bottom of case
Rock64
Pins
Expansion board
Short screws
Top of case
Moved the thread to Rock64 section.
  DeskPi case alternative for ROCK64 v1k699 2 13,242 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,568 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,498 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 48,634 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,315 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,938 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 21,647 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,586 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,977 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,943 06-08-2022, 12:44 AM
Last Post: Zoz
