Could you potentially create a Portable Emulation Machine with the Rock64?
I wanted to know if it was possible to develop a Rock64 Portable Console, with a controller inside of it like this:
[Image: Raspberry-Pi-Portable-by-benheck-Thingiverse.png]
Yea, I am quite certain its possible. I've built two PiGRRLs in the past and I am sure that Adafruit's powerboost1000 and control PCBs will work pretty much as you'd expect. Then there is only a question of the LCD panels/ driver boards - someone more knowledgeable would have to let us how much effort (if any) it would take a stock Pi LCD to work with the Rock64.
(12-08-2017, 11:19 AM)Luke Wrote: Yea, I am quite certain its possible. I've built two PiGRRLs in the past and I am sure that Adafruit's powerboost1000 and control PCBs will work pretty much as you'd expect. Then there is only a question of the LCD panels/ driver boards - someone more knowledgeable would have to let us how much effort (if any) it would take a stock Pi LCD to work with the Rock64.
Can't you buy a 7" inch Pine64 LCD for pretty cheap?  Huh
You were asking about the Rock64 right ? The R64 doesnt have DSI (or TP) - so the Pine64 LCD will not work. You'd need a driver board - just like you do on a RPI.
  DeskPi case alternative for ROCK64 v1k699 2 13,588 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,803 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,688 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,841 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,649 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,163 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 22,210 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,858 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,234 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 8,197 06-08-2022, 12:44 AM
Last Post: Zoz
