Fan speed controlled by CPU temp script
Bug
I wrote a script to control my fan.
The fan speed is controlled by the temp of the CPU.
I'm pretty new to bash so I'm hoping for some feedback and off course is everybody free to use the script how they like. Big Grin
#!/bin/bash #MikeD #Automatic fan on cpu temp CHECK_TIME=10 #IN SEC function pwm(){ LOOP=0 while [ $LOOP -lt $(($CHECK_TIME*75)) ]; do        echo 1 > /sys/class/gpio/gpio82/value        sleep $1        echo 0 > /sys/class/gpio/gpio82/value        sleep $2        LOOP=$(($LOOP+1)) done } function fanOff() { echo 0 > /sys/class/gpio/gpio82/value sleep $CHECK_TIME } function fanTweFiv() { pwm .0025 .0075 } function fanFifty() { pwm .0050 .0050 } function fanSevFiv() { pwm .0075 .0025 } function fanFull() { echo 1 > /sys/class/gpio/gpio82/value sleep $CHECK_TIME } while [ 1 ]; do        TEMP=$(cat /sys/class/thermal/thermal_zone0/temp)        if [ $TEMP -le 20000 ]        then                fanOff        fi        if [ $TEMP -gt 20000  -a  $TEMP -le 35000 ]        then                fanTweFiv        fi        if [ $TEMP -gt 35000 -a $TEMP -le 50000 ]        then                fanFifty        fi        if [ $TEMP -gt 50000 -a $TEMP -le 65000 ]        then                fanSevFiv        fi        if [ $TEMP -gt 65000 ]        then                fanFull        fi done
Thx in advance Smile
Hey there, how is this script holding up today? Has anyone been using it?
Can't get it to work:
./fantemp.sh: line 10: /sys/class/gpio/gpio82/value: No such file or directory
./fantemp.sh: line 12: /sys/class/gpio/gpio82/value: No such file or directory
I have these gpio's:
rock64@rock64:/sys/class/gpio$ ls
export gpiochip0 gpiochip32 gpiochip510 gpiochip64 gpiochip96 unexport
Heart Best quick/easy way to control case fan speed? idillicah 4 12,366 06-24-2021, 09:14 AM
Last Post: CounterPillow
  low speed wifi pas059 4 9,420 05-13-2019, 12:09 PM
Last Post: pas059
  Network Speed stuartiannaylor 27 52,348 05-06-2018, 10:07 AM
Last Post: S3phi40T
