RockBox
#31
Which one do you prefer? I use Nova Launcher on the phone and tablet, but dont think it is a good idea for a video player box.
#32
(11-10-2017, 05:53 AM)Wizzard Wrote: Which one do you prefer? I use Nova Launcher on the phone and tablet, but dont think it is a good idea for a video player box.
Will check when I get back home monday - cant remember the name. I know it was £2 or so.
#33
Ok, I also found out there is no root Smile
How to fix that? I need to customize the hosts file.
#34
Pretty sure the android that comes with it is not rooted -- again, consumer device.
#35
I see, so except ATV there is no other Android build available for now?
#36
(11-13-2017, 01:55 PM)Wizzard Wrote: I see, so except ATV there is no other Android build available for now?
You can also try the new stock build for Rock64. Its rooted too IIRC.
#37
I am afraid my remote will stop working Smile
#38
So I can copy that to SD, rename to update.img and it will flash itself and should work?
(btw ayufan's ATV and regular Android is also rooted?)
#39
(11-15-2017, 02:39 PM)Wizzard Wrote: So I can copy that to SD, rename to update.img and it will flash itself and should work?
i got my rockbox a few days ago
suprising i cannot copy file from my pc to my external storage in device using ESexplorer pro
i think its all because the permission access
so i want to root my rockbox
using your method and file .img from link up there, is not working at all
my rockbox cannot detect any update even i`ve already rename the file to update.img
any help and guide to root my rockbox
#40
For those of you who got the rockbox, here is an updated image which increases performance in ayufan's ATV build: https://github.com/ayufan-rock64/android...tag/0.3.13
  Rockbox firmware Wizzard 0 2,622 11-21-2021, 12:47 PM
Last Post: Wizzard
