PoE Splitter that's compatible with the ROCK64?
Looking to replace my Pine A64 with a more powerful ROCK 64 4GB, but I need PoE power for my use case.  I understand the requirement for power is a 5V adapter with up to 3A current.
So there are a few PoE Splitters out there, such as this one (http://www.poesystem.com/15.4w-poe-splitter/693.html) which can output 15.4W (5V/3A), but the specs tell me it's rated at 10/100Mbps, and has a 5.5mm barrel jack.  I'd have to get an adapter to drop to 3.5mm, but it's not worth it unless it can handle GbE speeds (or at least near).
Is there any known splitters out there that anyone could recommend?  Would save me time and potentially buying something that doesn't work.
Thanks!
(09-07-2017, 10:28 AM)tycoonbob Wrote: Looking to replace my Pine A64 with a more powerful ROCK 64 4GB, but I need PoE power for my use case.  I understand the requirement for power is a 5V adapter with up to 3A current.
Thanks!
Here is the PoE splitter for ROCK64 carry at PINE64 store: https://www.pine64.org/?product=rock64-poe-splitter
(09-07-2017, 12:25 PM)tllim Wrote: Here is the PoE splitter for ROCK64 carry at PINE64 store: https://www.pine64.org/?product=rock64-poe-splitter
Holy crap...how did I miss that?? Ugh, any way I can add one to an existing order so I don't have to pay separate shipping?
You could try emailing sales@pine64.org - you may be lucky and get though to them before the order goes out.
Can someone please confirm if this PoE splitter in the store is capable of gigabit speeds? I've noticed a lot of the cheaper ones out there are only 10/100M. Thanks!
  DeskPi case alternative for ROCK64 v1k699 2 13,584 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,798 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,685 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 49,837 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 11,644 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 5,158 04-26-2023, 11:38 PM
Question Compatible eMMC modules and benchmarks danboid 7 26,545 03-09-2023, 08:14 AM
Last Post: arvendui
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 22,207 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,858 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,233 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
