Will this wifi dongle work @ rock64?
Tongue
https://fccid.io/WKLWL6203
I have one lying around.
(09-25-2017, 06:43 PM)cheungtsw Wrote: https://fccid.io/WKLWL6203
Try it and report back ( please ).  The wifi dongle ( with external antennae ) works fine from the Pine store;  that's the one I've been using.
The issue is I dont have a rock64 yet.
Hi
I am new to ROCK64 and have purchased the SOC and other accessories from Pine store. I have purchased the single antenna WiFi dongle, installed Android 7.1 but the WiFi is not detecting. I tried to switch on the WiFi from settings, but it automatically switched-off. Can you please help?
Android Img Installed: android-7.1-rock-64-rock64_atv-v0.3.10-r105-update
Regards
Sanjeev
Will the one from the Pine store work on the android 7.1.2 build? I am looking for one that will work on it. Flashed to EMMC already. Smile
For anyone who was wondering. I bought this receiver as well to test with the new release of Android 7.1.2 and it is fully functrional.
https://www.amazon.com/gp/product/B008IF...=UTF8&th=1
Hi there, I'm planning buying one of these https://www.amazon.com/RTL8812AU-Adapter...B0761L7TV6
I think it should just work as the store's dongle because of the chipset (RTL8812AU) but I'm not sure. Could someone tell me if I'm wrong or not?
Thanks in advance.
(12-28-2017, 09:57 AM)zehks Wrote: Hi there, I'm planning buying one of these https://www.amazon.com/RTL8812AU-Adapter...B0761L7TV6
Thanks in advance.
from the Amazon info, may works with ROCK64
This dongle has got a RTL8191SU chip, so check this: click me
So, I would say, this will work.
  DeskPi case alternative for ROCK64 v1k699 2 11,914 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 3,680 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,844 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 45,027 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 10,107 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,226 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 19,869 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 5,737 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,073 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,079 06-08-2022, 12:44 AM
Last Post: Zoz
