Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well
Information
The pic above shows the RTL8188EU usb2.0 wifi adapter from the Pine Store.  I have been testing this $7.00 adapter for the past day;  running great !
This usb2.0 adapter has a fabulous adjustable external antennae and a really good signal;  connection has been solid with no drops or errors;  a really great on-on for the Rock64 !
Rolleyes
(09-03-2017, 04:28 PM)MarkHaysHarris777 Wrote: The pic above shows the RTL8188EU usb2.0 wifi adapter from the Pine Store.  I have been testing this $7.00 adapter for the past day;  running great !
Rolleyes
Thanks on the confirmation.
I bought another one doing AC/BT at the same time with antenna since i need an external antenna for both BT and Wifi
but it seems it is not supported is there any other option like this dongle ?
I have the same setup but need instruction on activating that device. Anyone? Just thought of something. Does it need to be in the USB 2 or 3 port?
(09-18-2017, 01:34 PM)mcrognale Wrote: I have the same setup but need instruction on activating that device. Anyone? Just thought of something. Does it need to be in the USB 2 or 3 port?
You can see that I have the device plugged into the usb2.0 port.  Network Manager in Xenial Mate will see the device and just work;  no worries.
thank you Mark.
Finally got it to work. You were right it just works. Thanks a lot.
Mike Smile
Rolleyes
I wish I was having the same luck, I got the same dongle for my rock64 running debian and even though the wifi indicator shows it connected I am unable to connect with firefox or chrome to google or any site. Wired ETH0 works fine but wifi don't. lsusb shows it connected bus 004 device 002: id 0bda:8176 realtek semiconductor corp. rtl8188cus 802.11n wlan adaper. any help out there would be appreciated. Thanks.
  DeskPi case alternative for ROCK64 v1k699 2 12,708 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,095 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 3,199 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 47,150 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 10,759 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 4,605 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 20,925 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 6,208 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 8,578 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 7,541 06-08-2022, 12:44 AM
Last Post: Zoz
