Power switch circuit
#21
Yeah, it is worthwile to check the dimensions of the switches / board holes.
I got the switches from retired kettle http://www.oster.com/coffee-and-kettles/...67-NP.html Tongue
(03-06-2016, 11:12 AM)MichaelMeissner Wrote: From the picture, it looks like this Adafruit tactile switch (https://www.adafruit.com/products/1489).
Pololu.com also sells a similar tactile switch: https://www.pololu.com/product/1400.
I'm sure you can find these cheaper elsewhere, but if you are ordering things from Adafruit or Pololu, consider adding a pack of these to your next order.
Cool
Every Pine 64 board for KS shipment already included one tactile switch as promised.
Cool
Will the tactile switch work out of the box, or additional soldering/programming is needed?
Follow me on Twitter: @MarlonRibunal
Follow my blog: SQL, Code, Coffee, etc.
You will have to solder it yourself. According to the updates, there were folks who didn't want this, so it's not soldered on by default.
Sent from my iPhone using Tapatalk
Board: Pine A64+ 2GB board.
MicroSD: Samsung Evo/+ 32/64GB
(03-06-2016, 09:36 AM)janjwerner Wrote: I was recycling some home appliances and found some tactile switches. Found a new home for them - Pine Wink
Pressing power button for 15 seconds do hard power off, short press of power currently does nothing under Linux (investigating now), reset works just as intended.
Heatsinks are from RPi, they are bit small, still better than nothing.
[Image: SbKoWRz.jpg]
I take it one switch is for on and the other is for off?
Left switch is power, and right switch is reset.
on and off the power to the left switch? short tip is on. long tip is off.
(03-11-2016, 03:28 AM)norm24 Wrote: on and off the power to the left switch? short tip is on. long tip is off.
yes
So where am i suppose to put this switch to? Really i searched a lot found nothing :|
http://imgur.com/a/wc1pt
(04-16-2016, 09:10 AM)stevejobs Wrote: So where am i suppose to put this switch to? Really i searched a lot found nothing :|
On your last picture, right in front of the wifi/bt module, you have 8 holes for 2 switches. Left is for power, right is for reset.
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,244 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 7,450 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 24,138 01-05-2017, 12:37 AM
Last Post: swinging
  Power Off / Reset Buttons - DietPi casmiguefl 4 13,916 08-12-2016, 05:28 PM
Last Post: casmiguefl
  power Circuit polo 28 66,494 07-01-2016, 07:06 PM
Last Post: pfeerick
  Power over Ethernet (PoE) WLR 1 8,485 02-10-2016, 07:14 PM
  USB HDD Power eender 5 14,733 02-06-2016, 09:30 PM
Last Post: blktiger
