Greetings,
The purpose of this post is to make the Pine Installer script available (on the forum) for Pinebook users who want to create SD cards on their Pinebook using the SD card slot, which will allow making SD cards directly on the Pinebook from the network; this script is similar to the pin64_install_to_emm.sh , as well the rock64_install_to_SD.sh.
The script does require the curl package, as well the jq package.
( This script allows you to burn Pinebook images from the network, to the SD card while booted from eMMC )
pinebook_install_to_SD.sh
Notes:
Place the script in the normal place /usr/local/sbin/pinebook_install_to_SD.sh
make the script executable with :
sudo chmod 0775 /usr/local/sbin/pinebook_install_to_SD.sh
sudo chown root /usr/local/sbin/pinebook_install_to_SD.sh
sudo chgrp root /usr/local/sbin/pinebook_install_to_SD.sh
To run the script and get usage:
sudo /usr/local/sbin/pinebook_install_to_SD.sh
To run the script and load xenial-i3 :
sudo /usr/local/sbin/pinebook_install_to_SD.sh xenial-i3
If you do not specify a version then the script will pull the most recent (non pre release) from the repos.
![Rolleyes Rolleyes](https://forum.pine64.org/images/smilies/rolleyes.png)
Updated Instructions.
#!/bin/bash
set -eo pipefail
if [[ "$(id -u)" -ne "0" ]]; then
echo "This script requires root."
exit 1
fi
echo "Pine A64/Pinebook release installer!"
echo "(C) 2017. Kamil Trzciński (https://ayufan.eu)."
echo ""
usage() {
echo "Usage:"
echo "$ $0 <system> [version]"
echo ""
echo "Systems:"
echo " - xenial-minimal (https://github.com/ayufan-pine64/linux-build/releases)"
echo " - xenial-mate (https://github.com/ayufan-pine64/linux-build/releases)"
echo " - xenial-i3 (https://github.com/ayufan-pine64/linux-build/releases)"
echo " - android-7.0 (https://github.com/ayufan-pine64/android-7.0/releases)"
echo " - android-7.1 (https://github.com/ayufan-pine64/android-7.1/releases)"
echo ""
echo "Version:"
echo " - latest will be used if version is not defined"
exit 1
if [[ $# -ne 1 ]] && [[ $# -ne 2 ]]; then
usage
fi
#if [[ ! -d /sys/devices/soc.0/1c10000.sdmmc/mmc_host/mmc1 ]]; then
# echo "You should boot from SD card"
# exit 1
#fi
#if [[ ! -e /dev/mmcblk1 ]]; then
# exit 1
#fi
case "$1" in
xenial-minimal|xenial-mate|xenial-i3)
REPO="ayufan-pine64/linux-build"
PREFIX="$1-$(cat /etc/pine64_model)-bspkernel-"
SUFFIX="-[0-9]*.img.xz"
ARCHIVER="xz -d"
android-7.0|android-7.1)
REPO="ayufan-pine64/$1"
if [[ "$(cat /etc/pine64_model)" == "pinebook" ]]; then
PREFIX="$1-pine-a64-pinebook-v"
elif [[ "$(cat /etc/pine64_model)" == "sopine" ]]; then
PREFIX="$1-pine-a64-sopine-v"
else
PREFIX="$1-pine-a64-v"
fi
SUFFIX="-r[0-9]*.img.gz"
ARCHIVER="gzip -d"
echo "Unknown system: $1"
echo ""
usage
esac
VERSION="$2"
if [[ -z "$VERSION" ]]; then
VERSION=$(curl -f -sS https://api.github.com/repos/$REPO/releases/latest | jq -r ".tag_name")
if [ -z "$VERSION" ]; then
echo "Latest release was not for $1."
echo "Please go to: https://github.com/$REPO/releases/latest"
exit 1
fi
echo "Using latest release: $VERSION from https://github.com/$REPO/releases."
fi
NAME="$PREFIX$VERSION$SUFFIX"
NAME_SAFE="${NAME//./\\.}"
VERSION_SAFE="${VERSION//./\\.}"
echo "Looking for download URL..."
DOWNLOAD_URL=$(curl -f -sS https://api.github.com/repos/$REPO/releases | \
jq -r ".[].assets | .[].browser_download_url" | \
( grep -o "https://github\.com/$REPO/releases/download/$VERSION_SAFE/$NAME_SAFE" || true))
if [[ -z "$DOWNLOAD_URL" ]]; then
echo "The download URL for $NAME not found".
echo "Look at https://github.com/$REPO/releases for correct versions."
exit 1
fi
echo "Doing this will overwrite all data stored on eMMC."
while true; do
echo "Type YES to continue or Ctrl-C to abort."
read CONFIRM
if [[ "$CONFIRM" == "YES" ]]; then
break
fi
done
echo ""
echo "Using $DOWNLOAD_URL..."
echo "Umounting..."
umount -f /dev/mmcblk1* || true
echo ""
echo "Downloading and writing to /dev/mmcblk1..."
curl -L -f "$DOWNLOAD_URL" | $ARCHIVER | dd bs=30M of=/dev/mmcblk1
sync
echo ""
echo "You may want to run now pine64_remove_boot0.sh to make the current device unbootable."
echo ""
echo "Done."
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697
( I regret that I am not able to respond to personal messages; let's meet on irc! )
![Cool Cool](https://forum.pine64.org/images/smilies/cool.png)
