Geographical location setting
My Google-Fu must be weak today. With a lot of help from the forum I have at least temporarily got the Play Store running, and down loaded & installed UKTV Play. All good EXCEPT that UKTV Play does not think I am in the UK and I should change device settings accordingly. But I can't find any settings that DON'T think I am in the UK. Am I missing something obvious ? I am set for the UK time zone & Google knows where I am  :-)
When new technology rolls over, you are either part of the steam roller... or part of the road.
(10-20-2016, 05:45 AM)Jessica Spongekipper Wrote: My Google-Fu must be weak today. With a lot of help from the forum I have at least temporarily got the Play Store running, and down loaded & installed UKTV Play. All good EXCEPT that UKTV Play does not think I am in the UK and I should change device settings accordingly. But I can't find any settings that DON'T think I am in the UK. Am I missing something obvious ? I am set for the UK time zone & Google knows where I am  :-)
Obviously time and TZ are important... but also perhaps your IP address ?
... are you using a VPN so that it looks like your IP host is elsewhere ( like you were hiding? ) I do this deliberately at times to look like I'm in London ( for instance ) when I'm really still sitting here is Minnesota !
Standard UK type address and UK based provider. And no VPN   :-) Only seems to be a problem with the Pine. Works fine on my 'phone.
Did you figure this out eventually? I'm in the same bother.
  Hulu and location Dagur 2 6,627 08-04-2017, 02:58 AM
Last Post: Dagur
  How to Setting Proxy Server in Android x-86 Kitkat, Lollipop and Marshmallow deniyulianti 1 6,083 01-15-2017, 01:35 PM
Last Post: Ferio
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 10,820 09-22-2016, 03:56 PM
Last Post: edszr.co
