[Problem] help find R110~R113 resistors on board to LCD Rotation 180deg
I have an old MIPI LCD panel. It works fine with pine64 2GB version. I want to rotate the screen 180deg. I checked the board schematic and found the MIPI L/R Pin is 0, U/D is 1, which means LCD is mirrored and upside down.
So, I want to make L/D pin 1, U/D pin 0, which means LCD is in default direction according to the datasheet. Move the resistor R113 to R112, R111 to R110. I have two problems:
1. Where is the R110 to R113 on board?
2. The resistors are very tiny and it is difficult to move them. I am using Android 6. Is this have other way to rotate screen 180deg without rotate the touch panel?
(07-19-2017, 08:24 PM)msmmbl Wrote: I have an old MIPI LCD panel. It works fine with pine64 2GB version. I want to rotate the screen 180deg. I checked the board schematic and found the MIPI L/R Pin is 0, U/D is 1, which means LCD is mirrored and upside down.
Glad that you manage to interface up your old MiPi LCD panel. I will release the PINE A64 component location PDF on next week, so that you can locate the component location.
very cool
Exclamation LCD 7" Pine64 own not working with pine64 A64 board HL3D 0 10,468 01-27-2025, 10:51 AM
Last Post: HL3D
  LCD Touch Screen Problem. Gavin 8 15,309 11-27-2016, 10:26 PM
Last Post: michaelquezon
