Android 7.1 (Pinebook)
#31
(07-05-2017, 04:07 AM)Luke Wrote:
(07-05-2017, 02:20 AM)Wizzard Wrote: If I understand it, when I want to install it to emmc, I just have to grab the installer file from ubuntu img, modify it, copy it to sdcard with A7.1, boot it and run that script?
Yes. Delete the ubuntu image on the installer and rename the A7.1 image to whatever the ubuntu image is called (IIRC its Pinebook.img).
So this is just opposite of what I said Smile so I have to use ubuntu emmc installer image on sd and replace one file on that sdcard from A7.1.
#32
1) Flash the ubuntu install image to SD
2) mount rootfs of the installer
3) delete the pinebook.img (please check, I cant remember if thats what its called)
4) rename A7.1 image to 'pinbook.img'
5) copy the renamed A7.1 image to the installers rootfs
6) put the SD into your Pinebook
#33
How to upgrade to latest pre release version (0.3.12: jenkins-android-7.1-pine-a64-69)?
From this url https://github.com/ayufan-pine64/android-7.1/releases
#34
Now it seems very clearly, thank you very much, I will try it today, hopefully.
#35
(07-05-2017, 08:23 AM)amilino Wrote: How to upgrade to latest pre release version (0.3.12: jenkins-android-7.1-pine-a64-69)?
You probably want to ask ayufan this question directly in IRC. I believe there is an update script in ubuntu for Android. I havent tried it, will not try it, and dont know how it works.
#36
Installation to emmc was successfull, just miss the stock email app.
#37
(07-06-2017, 07:29 AM)Wizzard Wrote: Installation to emmc was successfull, just miss the stock email app.
I recommend Aquamail. Free version gives limited accounts, 2 I think? Pricey for paid version but I love it.
Sent from my Swift 2 Plus using Tapatalk
#38
Thank you very much, but I am just used to stock mail. Will try to find some apk.
Also I have a problem with link2sd app, it does not load the apps.
#39
After running $ pine64_upgrade_android.sh /dev/mmcblk1 android-7.1 0.3.10, I received curl: (23) Failed writing body (637 != 16360)
Any help please, my current version installed on eMMC is android-7.1 0.3.5?
#40
(07-06-2017, 02:45 PM)amilino Wrote: After running $ pine64_upgrade_android.sh /dev/mmcblk1 android-7.1 0.3.10, I received curl: (23) Failed writing body (637 != 16360)
paste the entire log please
Smile PrimeOS for Pinebook 1080p teamprimeos 1 17,591 10-05-2024, 11:22 PM
Last Post: brken
  Lineage + pinebook, havin an issue when porting it Phie 5 14,501 01-18-2021, 09:02 AM
Last Post: mindao
  [26/09/2019] /e/ on pinebook, lineage derivative Phie 16 46,277 03-29-2020, 06:22 AM
Last Post: Surehand53
  SD2emmc custom android build Phie 0 4,702 11-06-2019, 09:14 AM
Last Post: Phie
  Privacy of Android and Chromium on new PineBook Clea 3 10,643 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 18,139 09-09-2019, 07:30 AM
  Bliss OS for Pinebook tllim 61 140,289 07-08-2019, 06:34 PM
  Android Oreo? epigon 12 31,730 07-02-2019, 03:18 PM
Last Post: TecapanV
Question 1080P Android 7? toca180 3 10,639 06-27-2019, 07:08 AM
  Stock Android for 1080P Pinebook pineadmin 1 8,415 11-24-2018, 09:45 AM
Last Post: ramboton
