Android 7.1 (Pinebook)
#21
Yes latest version (Android 7.1 v0.3.5-r61). Did couple reboots, and I am thinking to switch back on Linux. I am also waiting for Remix OS, hopefully it will run faster.
#22
(06-30-2017, 12:13 AM)amilino Wrote: Yes latest version (Android 7.1 v0.3.5-r61). Did couple reboots, and I am thinking to switch back on Linux. I am also waiting for Remix OS, hopefully it will run faster.
Strange ... A 7.1 was very snappy for me ... even on a (fast) SD card.
#23
I can confirm it reboots a lot, not very usable system. Running from SD, did not install to eMMC.
#24
(07-03-2017, 12:51 PM)Wizzard Wrote: I can confirm it reboots a lot, not very usable system. Running from SD, did not install to eMMC.
reboots ?
#25
reboots ?
Random reboots.
#26
I had issues where coming out of sleep it would reboot after a short while, and when I had something trying to charge off the left usb port, it would crash randomly (though it kept charging when it wasn't crashing). Stopped using something high drain on the left port (I am using a wireless mouse for that) and it has been better.
it doesn't get happy
it doesn't get sad
it just runs programs
#27
which image number ?
edit: never mind, you are obviously referring to the image here ... try one of the pre-release images from ayufans git ?
#28
(07-03-2017, 05:16 PM)Luke Wrote: which image number ?
How to perform update of Android, for an example with this prerelease? I don't want to lose apps and all what I already configured.
Is this sufficient: pine64_upgrade_android.sh /dev/mmcblk1 android-7.1 0.3.11
#29
If I understand it, when I want to install it to emmc, I just have to grab the installer file from ubuntu img, modify it, copy it to sdcard with A7.1, boot it and run that script?
#30
(07-05-2017, 02:20 AM)Wizzard Wrote: If I understand it, when I want to install it to emmc, I just have to grab the installer file from ubuntu img, modify it, copy it to sdcard with A7.1, boot it and run that script?
Yes. Delete the ubuntu image on the installer and rename the A7.1 image to whatever the ubuntu image is called (IIRC its Pinebook.img).
Smile PrimeOS for Pinebook 1080p teamprimeos 1 17,591 10-05-2024, 11:22 PM
Last Post: brken
  Lineage + pinebook, havin an issue when porting it Phie 5 14,501 01-18-2021, 09:02 AM
Last Post: mindao
  [26/09/2019] /e/ on pinebook, lineage derivative Phie 16 46,277 03-29-2020, 06:22 AM
Last Post: Surehand53
  SD2emmc custom android build Phie 0 4,702 11-06-2019, 09:14 AM
Last Post: Phie
  Privacy of Android and Chromium on new PineBook Clea 3 10,643 10-15-2019, 09:19 AM
  Android for 1080p Pinebook? Tomash 7 18,139 09-09-2019, 07:30 AM
  Bliss OS for Pinebook tllim 61 140,257 07-08-2019, 06:34 PM
  Android Oreo? epigon 12 31,730 07-02-2019, 03:18 PM
Last Post: TecapanV
Question 1080P Android 7? toca180 3 10,639 06-27-2019, 07:08 AM
  Stock Android for 1080P Pinebook pineadmin 1 8,415 11-24-2018, 09:45 AM
Last Post: ramboton
