revision board
I would like to know what is the revision board will be sold to backers?
 and if we can to know the evolution between the board, Rev A/B/C or upper if exist..?
thank you
(12-25-2015, 12:38 PM)hazerty Wrote: I would like to know what is the revision board will be sold to backers?
thank you
As I know, Pine64 has a revision B board which will be shipped in January for the developers and from February to KS supporters. I don't know what are the differences between it and the first one.
Best Regards,
Marcell Nemes
several question for Revision B board:
what is the purpose of the soldering in orange circle?
what is the purpose of some empty connectors in red circle?
pink circle : is that really behind the AXP803 chip? i never see the back of any chip is that white  Rolleyes  will be it a problem? more static sensitive?
green circle : that is a nasty soldering job, I hoped its only at developer version.
pictures from : http://blog.hypriot.com/post/the-pine-a6...un-Docker/
(02-25-2016, 08:32 PM)vsz85 Wrote: several question for Revision B board:
Well, I can tell you that the items in the red circle are connectors for power and reset switches, and charging LEDs.
@tllim would be great if you can answer some of my questions..
The orange circle reserve for metal shield if necessary.
The red circle are for optional Power/Reset push buttons, and LED indicators
The pink circle is the AXP803 heat spread
The green circle soldering only happens on developer board during to hand soldering and this doesn't effect board quality. The production boards are machine wave solder and clean.
thanks @tllim
the board haven't got need metal shield?
(03-01-2016, 02:58 AM)hazerty Wrote: the board haven't got need metal shield?
By default, there is no metal shield. If there is certain application, such as medical equipment, the metal shield may needed to further reduce EMI.
  Design custom board behnam_sh 6 17,220 07-11-2017, 12:26 PM
Last Post: xalius
  Linux is always crashing - bad board? hscharke 3 9,311 09-24-2016, 09:57 PM
Last Post: cyphergenetics
Exclamation Pine A64+ 2GB Board Schematic wenderfit 19 39,016 09-13-2016, 06:37 PM
  Board will not boot/does not work major7 2 6,884 09-03-2016, 02:53 AM
Last Post: major7
  Dead Board?? gubaguba 2 6,639 07-12-2016, 03:46 PM
Last Post: gubaguba
  new 2gb board not booting to known good image mythocelt 3 8,039 06-04-2016, 09:41 AM
Last Post: martinayotte
