Enable Mic on 3.5 jack port
(03-27-2017, 09:43 AM)xalius Wrote: That should be ok, I would use arecord too for testing, make sure you have the correct device...
Here the devices:
**** List of CAPTURE Hardware Devices **** card 1: audiocodec [audiocodec], device 0: SUNXI-CODEC codec-aif1-0 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 1: bb Voice codec-aif2-1 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 2: bb-bt-clk codec-aif2-2 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 3: bt Voice codec-aif3-3 []  Subdevices: 1/1  Subdevice #0: subdevice #0 **** List of PLAYBACK Hardware Devices **** card 0: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 0: SUNXI-CODEC codec-aif1-0 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 1: bb Voice codec-aif2-1 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 2: bb-bt-clk codec-aif2-2 []  Subdevices: 1/1  Subdevice #0: subdevice #0 card 1: audiocodec [audiocodec], device 3: bt Voice codec-aif3-3 []  Subdevices: 1/1  Subdevice #0: subdevice #0
and the same with pactl command:
Module #0 Name: module-device-restore Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically restore the volume/mute state of devices" module.version = "8.0" Module #1 Name: module-stream-restore Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically restore the volume/mute/device state of streams" module.version = "8.0" Module #2 Name: module-card-restore Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically restore profile of cards" module.version = "8.0" Module #3 Name: module-augment-properties Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Augment the property sets of streams with additional static information" module.version = "8.0" Module #4 Name: module-switch-on-port-available Argument: Usage counter: n/a Properties: Module #5 Name: module-udev-detect Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Detect available audio hardware and load matching drivers" module.version = "8.0" Module #6 Name: module-alsa-card Argument: device_id="1" name="platform-sound.6" card_name="alsa_card.platform-sound.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1" Usage counter: 0 Properties: module.author = "Lennart Poettering" module.description = "ALSA Card" module.version = "8.0" Module #7 Name: module-alsa-card Argument: device_id="0" name="platform-sound.7" card_name="alsa_card.platform-sound.7" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1" Usage counter: 0 Properties: module.author = "Lennart Poettering" module.description = "ALSA Card" module.version = "8.0" Module #8 Name: module-native-protocol-unix Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Native protocol (UNIX sockets)" module.version = "8.0" Module #9 Name: module-default-device-restore Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically restore the default sink and source" module.version = "8.0" Module #10 Name: module-rescue-streams Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "When a sink/source is removed, try to move its streams to the default sink/source" module.version = "8.0" Module #11 Name: module-always-sink Argument: Usage counter: n/a Properties: module.author = "Colin Guthrie" module.description = "Always keeps at least one sink loaded even if it's a null one" module.version = "8.0" Module #12 Name: module-intended-roles Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Automatically set device of streams based on intended roles of devices" module.version = "8.0" Module #13 Name: module-suspend-on-idle Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "When a sink/source is idle for too long, suspend it" module.version = "8.0" Module #14 Name: module-systemd-login Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Create a client for each login session of this user" module.version = "8.0" Module #15 Name: module-position-event-sounds Argument: Usage counter: n/a Properties: module.author = "Lennart Poettering" module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them." module.version = "8.0" Module #16 Name: module-filter-heuristics Argument: Usage counter: n/a Properties: module.author = "Colin Guthrie" module.description = "Detect when various filters are desirable" module.version = "8.0" Module #17 Name: module-filter-apply Argument: Usage counter: n/a Properties: module.author = "Colin Guthrie" module.description = "Load filter sinks automatically when needed" module.version = "8.0" Sink #0 State: SUSPENDED Name: alsa_output.platform-sound.6.analog-stereo Description: audiocodec Analog Stereo Driver: module-alsa-card.c Sample Specification: s16le 2ch 44100Hz Channel Map: front-left,front-right Owner Module: 6 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB        balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor Source: alsa_output.platform-sound.6.analog-stereo.monitor Latency: 0 usec, configured 0 usec Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY Properties: alsa.resolution_bits = "16" device.api = "alsa" device.class = "sound" alsa.class = "generic" alsa.subclass = "generic-mix" alsa.name = "" alsa.id = "SUNXI-CODEC codec-aif1-0" alsa.subdevice = "0" alsa.subdevice_name = "subdevice #0" alsa.device = "0" alsa.card = "1" alsa.card_name = "audiocodec" alsa.long_card_name = "audiocodec" alsa.driver_name = "sunxi_sndcodec" device.bus_path = "platform-sound.6" sysfs.path = "/devices/soc.0/sound.6/sound/card1" device.string = "hw:1" device.buffering.buffer_size = "352800" device.buffering.fragment_size = "176400" device.access_mode = "mmap+timer" device.profile.name = "analog-stereo" device.profile.description = "Analog Stereo" device.description = "audiocodec Analog Stereo" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Ports: analog-output-headphones: Headphones (priority: 9000) Active Port: analog-output-headphones Formats: pcm Sink #1 State: SUSPENDED Name: alsa_output.platform-sound.7.analog-stereo Description: sndhdmi Analog Stereo Driver: module-alsa-card.c Sample Specification: s16le 2ch 44100Hz Channel Map: front-left,front-right Owner Module: 7 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB        balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor Source: alsa_output.platform-sound.7.analog-stereo.monitor Latency: 0 usec, configured 0 usec Flags: HARDWARE DECIBEL_VOLUME LATENCY Properties: alsa.resolution_bits = "16" device.api = "alsa" device.class = "sound" alsa.class = "generic" alsa.subclass = "generic-mix" alsa.name = "" alsa.id = "SUNXI-HDMIAUDIO sndhdmi-0" alsa.subdevice = "0" alsa.subdevice_name = "subdevice #0" alsa.device = "0" alsa.card = "0" alsa.card_name = "sndhdmi" alsa.long_card_name = "sndhdmi" device.bus_path = "platform-sound.7" sysfs.path = "/devices/soc.0/sound.7/sound/card0" device.string = "hw:0" device.buffering.buffer_size = "352800" device.buffering.fragment_size = "176400" device.access_mode = "mmap+timer" device.profile.name = "analog-stereo" device.profile.description = "Analog Stereo" device.description = "sndhdmi Analog Stereo" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Ports: analog-output: Analog Output (priority: 9900) Active Port: analog-output Formats: pcm Source #0 State: SUSPENDED Name: alsa_output.platform-sound.6.analog-stereo.monitor Description: Monitor of audiocodec Analog Stereo Driver: module-alsa-card.c Sample Specification: s16le 2ch 44100Hz Channel Map: front-left,front-right Owner Module: 6 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB        balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: alsa_output.platform-sound.6.analog-stereo Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Monitor of audiocodec Analog Stereo" device.class = "monitor" alsa.card = "1" alsa.card_name = "audiocodec" alsa.long_card_name = "audiocodec" alsa.driver_name = "sunxi_sndcodec" device.bus_path = "platform-sound.6" sysfs.path = "/devices/soc.0/sound.6/sound/card1" device.string = "1" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Formats: pcm Source #1 State: SUSPENDED Name: alsa_input.platform-sound.6.analog-stereo Description: audiocodec Analog Stereo Driver: module-alsa-card.c Sample Specification: s16le 2ch 44100Hz Channel Map: front-left,front-right Owner Module: 6 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB        balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: n/a Latency: 0 usec, configured 0 usec Flags: HARDWARE DECIBEL_VOLUME LATENCY Properties: alsa.resolution_bits = "16" device.api = "alsa" device.class = "sound" alsa.class = "generic" alsa.subclass = "generic-mix" alsa.name = "" alsa.id = "SUNXI-CODEC codec-aif1-0" alsa.subdevice = "0" alsa.subdevice_name = "subdevice #0" alsa.device = "0" alsa.card = "1" alsa.card_name = "audiocodec" alsa.long_card_name = "audiocodec" alsa.driver_name = "sunxi_sndcodec" device.bus_path = "platform-sound.6" sysfs.path = "/devices/soc.0/sound.6/sound/card1" device.string = "hw:1" device.buffering.buffer_size = "352800" device.buffering.fragment_size = "176400" device.access_mode = "mmap+timer" device.profile.name = "analog-stereo" device.profile.description = "Analog Stereo" device.description = "audiocodec Analog Stereo" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Ports: analog-input: Analog Input (priority: 10000) Active Port: analog-input Formats: pcm Source #2 State: SUSPENDED Name: alsa_output.platform-sound.7.analog-stereo.monitor Description: Monitor of sndhdmi Analog Stereo Driver: module-alsa-card.c Sample Specification: s16le 2ch 44100Hz Channel Map: front-left,front-right Owner Module: 7 Mute: no Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB        balance 0.00 Base Volume: 65536 / 100% / 0.00 dB Monitor of Sink: alsa_output.platform-sound.7.analog-stereo Latency: 0 usec, configured 0 usec Flags: DECIBEL_VOLUME LATENCY Properties: device.description = "Monitor of sndhdmi Analog Stereo" device.class = "monitor" alsa.card = "0" alsa.card_name = "sndhdmi" alsa.long_card_name = "sndhdmi" device.bus_path = "platform-sound.7" sysfs.path = "/devices/soc.0/sound.7/sound/card0" device.string = "0" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Formats: pcm Client #0 Driver: module-systemd-login.c Owner Module: 14 Properties: application.name = "Login Session c1" systemd-login.session = "c1" Client #6 Driver: protocol-native.c Owner Module: 8 Properties: application.name = "pactl" native-protocol.peer = "UNIX socket client" native-protocol.version = "30" application.process.id = "14826" application.process.user = "ubuntu" application.process.host = "pine64" application.process.binary = "pactl" application.language = "C" window.x11.display = "localhost:10.0" application.process.machine_id = "8a7eae2accb7977bad9de1e15856980a" application.process.session_id = "c1" Card #0 Name: alsa_card.platform-sound.6 Driver: module-alsa-card.c Owner Module: 6 Properties: alsa.card = "1" alsa.card_name = "audiocodec" alsa.long_card_name = "audiocodec" alsa.driver_name = "sunxi_sndcodec" device.bus_path = "platform-sound.6" sysfs.path = "/devices/soc.0/sound.6/sound/card1" device.string = "1" device.description = "audiocodec" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Profiles: input:analog-mono: Analog Mono Input (sinks: 0, sources: 1, priority: 2, available: yes) input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 60, available: yes) output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority: 200, available: yes) output:analog-mono+input:analog-mono: Analog Mono Duplex (sinks: 1, sources: 1, priority: 202, available: yes) output:analog-mono+input:analog-stereo: Analog Mono Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 260, available: yes) output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6000, available: yes) output:analog-stereo+input:analog-mono: Analog Stereo Output + Analog Mono Input (sinks: 1, sources: 1, priority: 6002, available: yes) output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6060, available: yes) off: Off (sinks: 0, sources: 0, priority: 0, available: yes) Active Profile: output:analog-stereo+input:analog-stereo Ports: analog-input: Analog Input (priority: 10000, latency offset: 0 usec) Part of profile(s): input:analog-mono, input:analog-stereo, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo analog-output-headphones: Headphones (priority: 9000, latency offset: 0 usec) Properties: device.icon_name = "audio-headphones" Part of profile(s): output:analog-mono, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo Card #1 Name: alsa_card.platform-sound.7 Driver: module-alsa-card.c Owner Module: 7 Properties: alsa.card = "0" alsa.card_name = "sndhdmi" alsa.long_card_name = "sndhdmi" device.bus_path = "platform-sound.7" sysfs.path = "/devices/soc.0/sound.7/sound/card0" device.string = "0" device.description = "sndhdmi" module-udev-detect.discovered = "1" device.icon_name = "audio-card" Profiles: output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority: 200, available: yes) output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6000, available: yes) off: Off (sinks: 0, sources: 0, priority: 0, available: yes) Active Profile: output:analog-stereo Ports: analog-output: Analog Output (priority: 9900, latency offset: 0 usec) Part of profile(s): output:analog-mono, output:analog-stereo
Aren't these correct?
Thanks in advance for your patience.
changing various parameters now Mic is ok.
Here my asound.state file:
state.audiocodec { control.1 { iface MIXER name 'AIF1 ADC timeslot 0 volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.2 { iface MIXER name 'AIF1 ADC timeslot 1 volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.3 { iface MIXER name 'AIF1 DAC timeslot 0 volume' value.0 153 value.1 153 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -450 dbvalue.1 -450 } } control.4 { iface MIXER name 'AIF1 DAC timeslot 1 volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.5 { iface MIXER name 'AIF1 ADC timeslot 0 mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 -600 dbvalue.1 -600 } } control.6 { iface MIXER name 'AIF1 ADC timeslot 1 mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 3' dbmin -600 dbmax 1200 dbvalue.0 -600 dbvalue.1 -600 } } control.7 { iface MIXER name 'AIF2 ADC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.8 { iface MIXER name 'AIF2 DAC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.9 { iface MIXER name 'AIF2 ADC mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 -600 dbvalue.1 -600 } } control.10 { iface MIXER name 'ADC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.11 { iface MIXER name 'DAC volume' value.0 160 value.1 160 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 75 dbvalue.1 75 } } control.12 { iface MIXER name 'DAC mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 -600 dbvalue.1 -600 } } control.13 { iface MIXER name 'digital volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 63' dbmin -7308 dbmax 0 dbvalue.0 -7308 } } control.14 { iface MIXER name 'earpiece volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4350 dbmax 300 dbvalue.0 -4350 } } control.15 { iface MIXER name 'speaker volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4800 dbmax -150 dbvalue.0 -4800 } } control.16 { iface MIXER name 'headphone volume' value 44 comment { access 'read write' type INTEGER count 1 range '0 - 63' dbmin -6300 dbmax 0 dbvalue.0 -1900 } } control.17 { iface MIXER name 'MIC1_G boost stage output mixer control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.18 { iface MIXER name 'MIC1 boost AMP gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin 0 dbmax 1400 dbvalue.0 0 } } control.19 { iface MIXER name 'MIC2 BST stage to L_R outp mixer gain' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.20 { iface MIXER name 'MIC2 boost AMP gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin 0 dbmax 1400 dbvalue.0 0 } } control.21 { iface MIXER name 'LINEINL/R to L_R output mixer gain' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.22 { iface MIXER name 'ADC input gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.23 { iface MIXER name 'Phoneout gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.24 { iface MIXER name 'SRC FUCTION' value false comment { access 'read write' type BOOLEAN count 1 } } control.25 { iface MIXER name 'I2S HUB FUNC' value false comment { access 'read write' type BOOLEAN count 1 } } control.26 { iface MIXER name 'Phoneout Mixer MIC1 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.27 { iface MIXER name 'Phoneout Mixer MIC2 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.28 { iface MIXER name 'Phoneout Mixer Rout_Mixer_Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.29 { iface MIXER name 'Phoneout Mixer Lout_Mixer_Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.30 { iface MIXER name 'ADCR Mux' value DMIC comment { access 'read write' type ENUMERATED count 1 item.0 ADC item.1 DMIC } } control.31 { iface MIXER name 'ADCL Mux' value DMIC comment { access 'read write' type ENUMERATED count 1 item.0 ADC item.1 DMIC } } control.32 { iface MIXER name 'MIC2 SRC' value MIC2 comment { access 'read write' type ENUMERATED count 1 item.0 MIC3 item.1 MIC2 } } control.33 { iface MIXER name 'RADC input Mixer MIC1 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.34 { iface MIXER name 'RADC input Mixer MIC2 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.35 { iface MIXER name 'RADC input Mixer LINEINR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.36 { iface MIXER name 'RADC input Mixer r_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.37 { iface MIXER name 'RADC input Mixer l_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.38 { iface MIXER name 'RADC input Mixer PHONINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.39 { iface MIXER name 'RADC input Mixer PHONINN-PHONINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.40 { iface MIXER name 'LADC input Mixer MIC1 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.41 { iface MIXER name 'LADC input Mixer MIC2 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.42 { iface MIXER name 'LADC input Mixer LINEINL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.43 { iface MIXER name 'LADC input Mixer l_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.44 { iface MIXER name 'LADC input Mixer r_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.45 { iface MIXER name 'LADC input Mixer PHONINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.46 { iface MIXER name 'LADC input Mixer PHONINP-PHONINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.47 { iface MIXER name 'AIF3OUT Mux' value 'AIF2 ADC left channel' comment { access 'read write' type ENUMERATED count 1 item.0 'AIF2 ADC left channel' item.1 'AIF2 ADC right channel' } } control.48 { iface MIXER name 'AIF2 ADR Mixer AIF1 DA0R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.49 { iface MIXER name 'AIF2 ADR Mixer AIF1 DA1R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.50 { iface MIXER name 'AIF2 ADR Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.51 { iface MIXER name 'AIF2 ADR Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.52 { iface MIXER name 'AIF2 ADL Mixer AIF1 DA0L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.53 { iface MIXER name 'AIF2 ADL Mixer AIF1 DA1L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.54 { iface MIXER name 'AIF2 ADL Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.55 { iface MIXER name 'AIF2 ADL Mixer ADCL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.56 { iface MIXER name 'AIF2INR Mux' value AIF2_DACR comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_DACR item.1 AIF2_DACL item.2 SUM_AIF2DACL_AIF2DACR item.3 AVE_AIF2DACL_AIF2DACR } } control.57 { iface MIXER name 'AIF2INL Mux' value AIF2_DACL comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_DACL item.1 AIF2_DACR item.2 SUM_AIF2DACL_AIF2DACR item.3 AVE_AIF2DACL_AIF2DACR } } control.58 { iface MIXER name 'AIF2OUTR Mux' value AIF2_ADCR comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_ADCR item.1 AIF2_ADCL item.2 SUM_AIF2_ADCL_AIF2_ADCR item.3 AVE_AIF2_ADCL_AIF2_ADCR } } control.59 { iface MIXER name 'AIF2OUTL Mux' value AIF2_ADCL comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_ADCL item.1 AIF2_ADCR item.2 SUM_AIF2_ADCL_AIF2_ADCR item.3 AVE_AIF2_ADCL_AIF2_ADCR } } control.60 { iface MIXER name 'EAR Mux' value DACR comment { access 'read write' type ENUMERATED count 1 item.0 DACR item.1 DACL item.2 'Right Analog Mixer' item.3 'Left Analog Mixer' } } control.61 { iface MIXER name 'SPK_L Mux' value 'MIXEL Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'MIXEL Switch' item.1 'MIXL MIXR  Switch' } } control.62 { iface MIXER name 'SPK_R Mux' value 'MIXER Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'MIXER Switch' item.1 'MIXR MIXL Switch' } } control.63 { iface MIXER name 'HP_L Mux' value 'DACL HPL Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'DACL HPL Switch' item.1 'Left Analog Mixer HPL Switch' } } control.64 { iface MIXER name 'HP_R Mux' value 'DACR HPR Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'DACR HPR Switch' item.1 'Right Analog Mixer HPR Switch' } } control.65 { iface MIXER name 'Right Output Mixer DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.66 { iface MIXER name 'Right Output Mixer DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.67 { iface MIXER name 'Right Output Mixer LINEINR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.68 { iface MIXER name 'Right Output Mixer MIC2Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.69 { iface MIXER name 'Right Output Mixer MIC1Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.70 { iface MIXER name 'Right Output Mixer PHONEINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.71 { iface MIXER name 'Right Output Mixer PHONEINN-PHONEINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.72 { iface MIXER name 'Left Output Mixer DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.73 { iface MIXER name 'Left Output Mixer DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.74 { iface MIXER name 'Left Output Mixer LINEINL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.75 { iface MIXER name 'Left Output Mixer MIC2Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.76 { iface MIXER name 'Left Output Mixer MIC1Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.77 { iface MIXER name 'Left Output Mixer PHONEINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.78 { iface MIXER name 'Left Output Mixer PHONEINP-PHONEINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.79 { iface MIXER name 'DACR Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.80 { iface MIXER name 'DACR Mixer AIF2DACR Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.81 { iface MIXER name 'DACR Mixer AIF1DA1R Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.82 { iface MIXER name 'DACR Mixer AIF1DA0R Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.83 { iface MIXER name 'DACL Mixer ADCL Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.84 { iface MIXER name 'DACL Mixer AIF2DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.85 { iface MIXER name 'DACL Mixer AIF1DA1L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.86 { iface MIXER name 'DACL Mixer AIF1DA0L Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.87 { iface MIXER name 'AIF1 AD1R Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.88 { iface MIXER name 'AIF1 AD1R Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.89 { iface MIXER name 'AIF1 AD1L Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.90 { iface MIXER name 'AIF1 AD1L Mixer ADCL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.91 { iface MIXER name 'AIF1 AD0R Mixer AIF1 DA0R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.92 { iface MIXER name 'AIF1 AD0R Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.93 { iface MIXER name 'AIF1 AD0R Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.94 { iface MIXER name 'AIF1 AD0R Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.95 { iface MIXER name 'AIF1 AD0L Mixer AIF1 DA0L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.96 { iface MIXER name 'AIF1 AD0L Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.97 { iface MIXER name 'AIF1 AD0L Mixer ADCL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.98 { iface MIXER name 'AIF1 AD0L Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.99 { iface MIXER name 'AIF1IN1R Mux' value AIF1_DA1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA1R item.1 AIF1_DA1L item.2 SUM_AIF1DA1L_AIF1DA1R item.3 AVE_AIF1DA1L_AIF1DA1R } } control.100 { iface MIXER name 'AIF1IN1L Mux' value AIF1_DA1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA1L item.1 AIF1_DA1R item.2 SUM_AIF1DA1L_AIF1DA1R item.3 AVE_AIF1DA1L_AIF1DA1R } } control.101 { iface MIXER name 'AIF1IN0R Mux' value AIF1_DA0R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA0R item.1 AIF1_DA0L item.2 SUM_AIF1DA0L_AIF1DA0R item.3 AVE_AIF1DA0L_AIF1DA0R } } control.102 { iface MIXER name 'AIF1IN0L Mux' value AIF1_DA0L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA0L item.1 AIF1_DA0R item.2 SUM_AIF1DA0L_AIF1DA0R item.3 AVE_AIF1DA0L_AIF1DA0R } } control.103 { iface MIXER name 'AIF1OUT1R Mux' value AIF1_AD1R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD1R item.1 AIF1_AD1L item.2 SUM_AIF1ADC1L_AIF1ADC1R item.3 AVE_AIF1ADC1L_AIF1ADC1R } } control.104 { iface MIXER name 'AIF1OUT1L Mux' value AIF1_AD1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD1L item.1 AIF1_AD1R item.2 SUM_AIF1ADC1L_AIF1ADC1R item.3 AVE_AIF1ADC1L_AIF1ADC1R } } control.105 { iface MIXER name 'AIF1OUT0R Mux' value AIF1_AD0R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD0R item.1 AIF1_AD0L item.2 SUM_AIF1AD0L_AIF1AD0R item.3 AVE_AIF1AD0L_AIF1AD0R } } control.106 { iface MIXER name 'AIF1OUT0L Mux' value AIF1_AD0L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD0L item.1 AIF1_AD0R item.2 SUM_AIF1AD0L_AIF1AD0R item.3 AVE_AIF1AD0L_AIF1AD0R } } control.107 { iface MIXER name 'AIF2INR Mux VIR switch aif2inr aif3' value false comment { access 'read write' type BOOLEAN count 1 } } control.108 { iface MIXER name 'AIF2INL Mux VIR switch aif2inl aif3' value false comment { access 'read write' type BOOLEAN count 1 } } control.109 { iface MIXER name 'AIF2INR Mux switch aif2inr aif2' value false comment { access 'read write' type BOOLEAN count 1 } } control.110 { iface MIXER name 'AIF2INL Mux switch aif2inl aif2' value false comment { access 'read write' type BOOLEAN count 1 } } control.111 { iface MIXER name 'External Speaker Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.112 { iface MIXER name 'Headphone Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.113 { iface MIXER name 'Earpiece Switch' value false comment { access 'read write' type BOOLEAN count 1 } } } state.sndhdmi { control.1 { iface MIXER name 'hdmi audio format Function' value pcm comment { access 'read write' type ENUMERATED count 1 item.0 null item.1 pcm item.2 AC3 item.3 MPEG1 item.4 MP3 item.5 MPEG2 item.6 AAC item.7 DTS item.8 ATRAC item.9 ONE_BIT_AUDIO item.10 DOLBY_DIGITAL_PLUS item.11 DTS_HD item.12 MAT item.13 WMAPRO } } } state.U0x46d0x9a1 { control.1 { iface MIXER name 'Mic Capture Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.2 { iface MIXER name 'Mic Capture Volume' value 1536 comment { access 'read write' type INTEGER count 1 range '0 - 3072' dbmin 1800 dbmax 3000 dbvalue.0 2400 } } }
Thanks to Xalius for support Wink
Go to the bottom for correct asound.state file.
Ok, thanks :-)
I will maybe make a diff to the original asound.state for the audiojack so we can add those things you changed to longsleep's default?
(03-27-2017, 03:34 PM)xalius Wrote: Ok, thanks :-)
Good Idea...
Thanks for all Xalius Smile
Hi Xalius,
here my correct asound.state (previous reply is not correct)
wiht the differences exposed:
differences patch file:
--- /home/noviabook3/Scrivania/asound.state +++ /home/noviabook3/Scrivania/asound.state.OK_MIC_OUT_BKP @@ -2,6 +2,54 @@      control.1 {          iface MIXER          name 'AIF1 ADC timeslot 0 volume' +        value.0 228 +        value.1 228 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 255' +            dbmin -11925 +            dbmax 7200 +            dbvalue.0 5175 +            dbvalue.1 5175 +        } +    } +    control.2 { +        iface MIXER +        name 'AIF1 ADC timeslot 1 volume' +        value.0 225 +        value.1 225 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 255' +            dbmin -11925 +            dbmax 7200 +            dbvalue.0 4950 +            dbvalue.1 4950 +        } +    } +    control.3 { +        iface MIXER +        name 'AIF1 DAC timeslot 0 volume' +        value.0 153 +        value.1 153 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 255' +            dbmin -11925 +            dbmax 7200 +            dbvalue.0 -450 +            dbvalue.1 -450 +        } +    } +    control.4 { +        iface MIXER +        name 'AIF1 DAC timeslot 1 volume'          value.0 0          value.1 0          comment { @@ -15,9 +63,41 @@              dbvalue.1 -11925          }      } -    control.2 { -        iface MIXER -        name 'AIF1 ADC timeslot 1 volume' +    control.5 { +        iface MIXER +        name 'AIF1 ADC timeslot 0 mixer gain' +        value.0 14 +        value.1 14 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 15' +            dbmin -600 +            dbmax 8400 +            dbvalue.0 7800 +            dbvalue.1 7800 +        } +    } +    control.6 { +        iface MIXER +        name 'AIF1 ADC timeslot 1 mixer gain' +        value.0 3 +        value.1 3 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 3' +            dbmin -600 +            dbmax 1200 +            dbvalue.0 1200 +            dbvalue.1 1200 +        } +    } +    control.7 { +        iface MIXER +        name 'AIF2 ADC volume'          value.0 0          value.1 0          comment { @@ -31,9 +111,41 @@              dbvalue.1 -11925          }      } -    control.3 { -        iface MIXER -        name 'AIF1 DAC timeslot 0 volume' +    control.8 { +        iface MIXER +        name 'AIF2 DAC volume' +        value.0 0 +        value.1 0 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 255' +            dbmin -11925 +            dbmax 7200 +            dbvalue.0 -11925 +            dbvalue.1 -11925 +        } +    } +    control.9 { +        iface MIXER +        name 'AIF2 ADC mixer gain' +        value.0 0 +        value.1 0 +        comment { +            access 'read write' +            type INTEGER +            count 2 +            range '0 - 15' +            dbmin -600 +            dbmax 8400 +            dbvalue.0 -600 +            dbvalue.1 -600 +        } +    } +    control.10 { +        iface MIXER +        name 'ADC volume'          value.0 153          value.1 153          comment { @@ -47,9 +159,9 @@              dbvalue.1 -450          }      } -    control.4 { -        iface MIXER -        name 'AIF1 DAC timeslot 1 volume' +    control.11 { +        iface MIXER +        name 'DAC volume'          value.0 0          value.1 0          comment { @@ -63,9 +175,9 @@              dbvalue.1 -11925          }      } -    control.5 { -        iface MIXER -        name 'AIF1 ADC timeslot 0 mixer gain' +    control.12 { +        iface MIXER +        name 'DAC mixer gain'          value.0 0          value.1 0          comment { @@ -79,118 +191,6 @@              dbvalue.1 -600          }      } -    control.6 { -        iface MIXER -        name 'AIF1 ADC timeslot 1 mixer gain' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 3' -            dbmin -600 -            dbmax 1200 -            dbvalue.0 -600 -            dbvalue.1 -600 -        } -    } -    control.7 { -        iface MIXER -        name 'AIF2 ADC volume' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 255' -            dbmin -11925 -            dbmax 7200 -            dbvalue.0 -11925 -            dbvalue.1 -11925 -        } -    } -    control.8 { -        iface MIXER -        name 'AIF2 DAC volume' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 255' -            dbmin -11925 -            dbmax 7200 -            dbvalue.0 -11925 -            dbvalue.1 -11925 -        } -    } -    control.9 { -        iface MIXER -        name 'AIF2 ADC mixer gain' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 15' -            dbmin -600 -            dbmax 8400 -            dbvalue.0 -600 -            dbvalue.1 -600 -        } -    } -    control.10 { -        iface MIXER -        name 'ADC volume' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 255' -            dbmin -11925 -            dbmax 7200 -            dbvalue.0 -11925 -            dbvalue.1 -11925 -        } -    } -    control.11 { -        iface MIXER -        name 'DAC volume' -        value.0 160 -        value.1 160 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 255' -            dbmin -11925 -            dbmax 7200 -            dbvalue.0 75 -            dbvalue.1 75 -        } -    } -    control.12 { -        iface MIXER -        name 'DAC mixer gain' -        value.0 0 -        value.1 0 -        comment { -            access 'read write' -            type INTEGER -            count 2 -            range '0 - 15' -            dbmin -600 -            dbmax 8400 -            dbvalue.0 -600 -            dbvalue.1 -600 -        } -    }      control.13 {          iface MIXER          name 'digital volume' @@ -236,7 +236,7 @@      control.16 {          iface MIXER          name 'headphone volume' -        value 44 +        value 50          comment {              access 'read write'              type INTEGER @@ -244,7 +244,7 @@              range '0 - 63'              dbmin -6300              dbmax 0 -            dbvalue.0 -1900 +            dbvalue.0 -1300          }      }      control.17 { @@ -320,6 +320,20 @@      control.22 {          iface MIXER          name 'ADC input gain control' +        value 4 +        comment { +            access 'read write' +            type INTEGER +            count 1 +            range '0 - 7' +            dbmin -450 +            dbmax 600 +            dbvalue.0 150 +        } +    } +    control.23 { +        iface MIXER +        name 'Phoneout gain control'          value 0          comment {              access 'read write' @@ -331,20 +345,6 @@              dbvalue.0 -450          }      } -    control.23 { -        iface MIXER -        name 'Phoneout gain control' -        value 0 -        comment { -            access 'read write' -            type INTEGER -            count 1 -            range '0 - 7' -            dbmin -450 -            dbmax 600 -            dbvalue.0 -450 -        } -    }      control.24 {          iface MIXER          name 'SRC FUCTION' @@ -368,7 +368,7 @@      control.26 {          iface MIXER          name 'Phoneout Mixer MIC1 boost Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN @@ -378,7 +378,7 @@      control.27 {          iface MIXER          name 'Phoneout Mixer MIC2 boost Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN @@ -408,7 +408,7 @@      control.30 {          iface MIXER          name 'ADCR Mux' -        value DMIC +        value ADC          comment {              access 'read write'              type ENUMERATED @@ -420,7 +420,7 @@      control.31 {          iface MIXER          name 'ADCL Mux' -        value DMIC +        value ADC          comment {              access 'read write'              type ENUMERATED @@ -454,7 +454,7 @@      control.34 {          iface MIXER          name 'RADC input Mixer MIC2 boost Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN @@ -524,7 +524,7 @@      control.41 {          iface MIXER          name 'LADC input Mixer MIC2 boost Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN @@ -1074,7 +1074,7 @@      control.93 {          iface MIXER          name 'AIF1 AD0R Mixer ADCR Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN @@ -1114,7 +1114,7 @@      control.97 {          iface MIXER          name 'AIF1 AD0L Mixer ADCL Switch' -        value false +        value true          comment {              access 'read write'              type BOOLEAN
complete asound.state:
state.audiocodec { control.1 { iface MIXER name 'AIF1 ADC timeslot 0 volume' value.0 228 value.1 228 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 5175 dbvalue.1 5175 } } control.2 { iface MIXER name 'AIF1 ADC timeslot 1 volume' value.0 225 value.1 225 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 4950 dbvalue.1 4950 } } control.3 { iface MIXER name 'AIF1 DAC timeslot 0 volume' value.0 153 value.1 153 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -450 dbvalue.1 -450 } } control.4 { iface MIXER name 'AIF1 DAC timeslot 1 volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.5 { iface MIXER name 'AIF1 ADC timeslot 0 mixer gain' value.0 14 value.1 14 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 7800 dbvalue.1 7800 } } control.6 { iface MIXER name 'AIF1 ADC timeslot 1 mixer gain' value.0 3 value.1 3 comment { access 'read write' type INTEGER count 2 range '0 - 3' dbmin -600 dbmax 1200 dbvalue.0 1200 dbvalue.1 1200 } } control.7 { iface MIXER name 'AIF2 ADC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.8 { iface MIXER name 'AIF2 DAC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.9 { iface MIXER name 'AIF2 ADC mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 -600 dbvalue.1 -600 } } control.10 { iface MIXER name 'ADC volume' value.0 153 value.1 153 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -450 dbvalue.1 -450 } } control.11 { iface MIXER name 'DAC volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 255' dbmin -11925 dbmax 7200 dbvalue.0 -11925 dbvalue.1 -11925 } } control.12 { iface MIXER name 'DAC mixer gain' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 15' dbmin -600 dbmax 8400 dbvalue.0 -600 dbvalue.1 -600 } } control.13 { iface MIXER name 'digital volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 63' dbmin -7308 dbmax 0 dbvalue.0 -7308 } } control.14 { iface MIXER name 'earpiece volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4350 dbmax 300 dbvalue.0 -4350 } } control.15 { iface MIXER name 'speaker volume' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4800 dbmax -150 dbvalue.0 -4800 } } control.16 { iface MIXER name 'headphone volume' value 50 comment { access 'read write' type INTEGER count 1 range '0 - 63' dbmin -6300 dbmax 0 dbvalue.0 -1300 } } control.17 { iface MIXER name 'MIC1_G boost stage output mixer control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.18 { iface MIXER name 'MIC1 boost AMP gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin 0 dbmax 1400 dbvalue.0 0 } } control.19 { iface MIXER name 'MIC2 BST stage to L_R outp mixer gain' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.20 { iface MIXER name 'MIC2 boost AMP gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin 0 dbmax 1400 dbvalue.0 0 } } control.21 { iface MIXER name 'LINEINL/R to L_R output mixer gain' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.22 { iface MIXER name 'ADC input gain control' value 4 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 150 } } control.23 { iface MIXER name 'Phoneout gain control' value 0 comment { access 'read write' type INTEGER count 1 range '0 - 7' dbmin -450 dbmax 600 dbvalue.0 -450 } } control.24 { iface MIXER name 'SRC FUCTION' value false comment { access 'read write' type BOOLEAN count 1 } } control.25 { iface MIXER name 'I2S HUB FUNC' value false comment { access 'read write' type BOOLEAN count 1 } } control.26 { iface MIXER name 'Phoneout Mixer MIC1 boost Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.27 { iface MIXER name 'Phoneout Mixer MIC2 boost Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.28 { iface MIXER name 'Phoneout Mixer Rout_Mixer_Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.29 { iface MIXER name 'Phoneout Mixer Lout_Mixer_Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.30 { iface MIXER name 'ADCR Mux' value ADC comment { access 'read write' type ENUMERATED count 1 item.0 ADC item.1 DMIC } } control.31 { iface MIXER name 'ADCL Mux' value ADC comment { access 'read write' type ENUMERATED count 1 item.0 ADC item.1 DMIC } } control.32 { iface MIXER name 'MIC2 SRC' value MIC2 comment { access 'read write' type ENUMERATED count 1 item.0 MIC3 item.1 MIC2 } } control.33 { iface MIXER name 'RADC input Mixer MIC1 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.34 { iface MIXER name 'RADC input Mixer MIC2 boost Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.35 { iface MIXER name 'RADC input Mixer LINEINR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.36 { iface MIXER name 'RADC input Mixer r_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.37 { iface MIXER name 'RADC input Mixer l_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.38 { iface MIXER name 'RADC input Mixer PHONINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.39 { iface MIXER name 'RADC input Mixer PHONINN-PHONINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.40 { iface MIXER name 'LADC input Mixer MIC1 boost Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.41 { iface MIXER name 'LADC input Mixer MIC2 boost Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.42 { iface MIXER name 'LADC input Mixer LINEINL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.43 { iface MIXER name 'LADC input Mixer l_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.44 { iface MIXER name 'LADC input Mixer r_output mixer Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.45 { iface MIXER name 'LADC input Mixer PHONINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.46 { iface MIXER name 'LADC input Mixer PHONINP-PHONINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.47 { iface MIXER name 'AIF3OUT Mux' value 'AIF2 ADC left channel' comment { access 'read write' type ENUMERATED count 1 item.0 'AIF2 ADC left channel' item.1 'AIF2 ADC right channel' } } control.48 { iface MIXER name 'AIF2 ADR Mixer AIF1 DA0R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.49 { iface MIXER name 'AIF2 ADR Mixer AIF1 DA1R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.50 { iface MIXER name 'AIF2 ADR Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.51 { iface MIXER name 'AIF2 ADR Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.52 { iface MIXER name 'AIF2 ADL Mixer AIF1 DA0L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.53 { iface MIXER name 'AIF2 ADL Mixer AIF1 DA1L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.54 { iface MIXER name 'AIF2 ADL Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.55 { iface MIXER name 'AIF2 ADL Mixer ADCL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.56 { iface MIXER name 'AIF2INR Mux' value AIF2_DACR comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_DACR item.1 AIF2_DACL item.2 SUM_AIF2DACL_AIF2DACR item.3 AVE_AIF2DACL_AIF2DACR } } control.57 { iface MIXER name 'AIF2INL Mux' value AIF2_DACL comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_DACL item.1 AIF2_DACR item.2 SUM_AIF2DACL_AIF2DACR item.3 AVE_AIF2DACL_AIF2DACR } } control.58 { iface MIXER name 'AIF2OUTR Mux' value AIF2_ADCR comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_ADCR item.1 AIF2_ADCL item.2 SUM_AIF2_ADCL_AIF2_ADCR item.3 AVE_AIF2_ADCL_AIF2_ADCR } } control.59 { iface MIXER name 'AIF2OUTL Mux' value AIF2_ADCL comment { access 'read write' type ENUMERATED count 1 item.0 AIF2_ADCL item.1 AIF2_ADCR item.2 SUM_AIF2_ADCL_AIF2_ADCR item.3 AVE_AIF2_ADCL_AIF2_ADCR } } control.60 { iface MIXER name 'EAR Mux' value DACR comment { access 'read write' type ENUMERATED count 1 item.0 DACR item.1 DACL item.2 'Right Analog Mixer' item.3 'Left Analog Mixer' } } control.61 { iface MIXER name 'SPK_L Mux' value 'MIXEL Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'MIXEL Switch' item.1 'MIXL MIXR  Switch' } } control.62 { iface MIXER name 'SPK_R Mux' value 'MIXER Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'MIXER Switch' item.1 'MIXR MIXL Switch' } } control.63 { iface MIXER name 'HP_L Mux' value 'DACL HPL Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'DACL HPL Switch' item.1 'Left Analog Mixer HPL Switch' } } control.64 { iface MIXER name 'HP_R Mux' value 'DACR HPR Switch' comment { access 'read write' type ENUMERATED count 1 item.0 'DACR HPR Switch' item.1 'Right Analog Mixer HPR Switch' } } control.65 { iface MIXER name 'Right Output Mixer DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.66 { iface MIXER name 'Right Output Mixer DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.67 { iface MIXER name 'Right Output Mixer LINEINR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.68 { iface MIXER name 'Right Output Mixer MIC2Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.69 { iface MIXER name 'Right Output Mixer MIC1Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.70 { iface MIXER name 'Right Output Mixer PHONEINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.71 { iface MIXER name 'Right Output Mixer PHONEINN-PHONEINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.72 { iface MIXER name 'Left Output Mixer DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.73 { iface MIXER name 'Left Output Mixer DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.74 { iface MIXER name 'Left Output Mixer LINEINL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.75 { iface MIXER name 'Left Output Mixer MIC2Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.76 { iface MIXER name 'Left Output Mixer MIC1Booststage Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.77 { iface MIXER name 'Left Output Mixer PHONEINP Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.78 { iface MIXER name 'Left Output Mixer PHONEINP-PHONEINN Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.79 { iface MIXER name 'DACR Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.80 { iface MIXER name 'DACR Mixer AIF2DACR Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.81 { iface MIXER name 'DACR Mixer AIF1DA1R Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.82 { iface MIXER name 'DACR Mixer AIF1DA0R Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.83 { iface MIXER name 'DACL Mixer ADCL Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.84 { iface MIXER name 'DACL Mixer AIF2DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.85 { iface MIXER name 'DACL Mixer AIF1DA1L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.86 { iface MIXER name 'DACL Mixer AIF1DA0L Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.87 { iface MIXER name 'AIF1 AD1R Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.88 { iface MIXER name 'AIF1 AD1R Mixer ADCR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.89 { iface MIXER name 'AIF1 AD1L Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.90 { iface MIXER name 'AIF1 AD1L Mixer ADCL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.91 { iface MIXER name 'AIF1 AD0R Mixer AIF1 DA0R Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.92 { iface MIXER name 'AIF1 AD0R Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.93 { iface MIXER name 'AIF1 AD0R Mixer ADCR Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.94 { iface MIXER name 'AIF1 AD0R Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.95 { iface MIXER name 'AIF1 AD0L Mixer AIF1 DA0L Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.96 { iface MIXER name 'AIF1 AD0L Mixer AIF2 DACL Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.97 { iface MIXER name 'AIF1 AD0L Mixer ADCL Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.98 { iface MIXER name 'AIF1 AD0L Mixer AIF2 DACR Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.99 { iface MIXER name 'AIF1IN1R Mux' value AIF1_DA1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA1R item.1 AIF1_DA1L item.2 SUM_AIF1DA1L_AIF1DA1R item.3 AVE_AIF1DA1L_AIF1DA1R } } control.100 { iface MIXER name 'AIF1IN1L Mux' value AIF1_DA1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA1L item.1 AIF1_DA1R item.2 SUM_AIF1DA1L_AIF1DA1R item.3 AVE_AIF1DA1L_AIF1DA1R } } control.101 { iface MIXER name 'AIF1IN0R Mux' value AIF1_DA0R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA0R item.1 AIF1_DA0L item.2 SUM_AIF1DA0L_AIF1DA0R item.3 AVE_AIF1DA0L_AIF1DA0R } } control.102 { iface MIXER name 'AIF1IN0L Mux' value AIF1_DA0L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_DA0L item.1 AIF1_DA0R item.2 SUM_AIF1DA0L_AIF1DA0R item.3 AVE_AIF1DA0L_AIF1DA0R } } control.103 { iface MIXER name 'AIF1OUT1R Mux' value AIF1_AD1R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD1R item.1 AIF1_AD1L item.2 SUM_AIF1ADC1L_AIF1ADC1R item.3 AVE_AIF1ADC1L_AIF1ADC1R } } control.104 { iface MIXER name 'AIF1OUT1L Mux' value AIF1_AD1L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD1L item.1 AIF1_AD1R item.2 SUM_AIF1ADC1L_AIF1ADC1R item.3 AVE_AIF1ADC1L_AIF1ADC1R } } control.105 { iface MIXER name 'AIF1OUT0R Mux' value AIF1_AD0R comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD0R item.1 AIF1_AD0L item.2 SUM_AIF1AD0L_AIF1AD0R item.3 AVE_AIF1AD0L_AIF1AD0R } } control.106 { iface MIXER name 'AIF1OUT0L Mux' value AIF1_AD0L comment { access 'read write' type ENUMERATED count 1 item.0 AIF1_AD0L item.1 AIF1_AD0R item.2 SUM_AIF1AD0L_AIF1AD0R item.3 AVE_AIF1AD0L_AIF1AD0R } } control.107 { iface MIXER name 'AIF2INR Mux VIR switch aif2inr aif3' value false comment { access 'read write' type BOOLEAN count 1 } } control.108 { iface MIXER name 'AIF2INL Mux VIR switch aif2inl aif3' value false comment { access 'read write' type BOOLEAN count 1 } } control.109 { iface MIXER name 'AIF2INR Mux switch aif2inr aif2' value false comment { access 'read write' type BOOLEAN count 1 } } control.110 { iface MIXER name 'AIF2INL Mux switch aif2inl aif2' value false comment { access 'read write' type BOOLEAN count 1 } } control.111 { iface MIXER name 'External Speaker Switch' value false comment { access 'read write' type BOOLEAN count 1 } } control.112 { iface MIXER name 'Headphone Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.113 { iface MIXER name 'Earpiece Switch' value false comment { access 'read write' type BOOLEAN count 1 } } } state.sndhdmi { control.1 { iface MIXER name 'hdmi audio format Function' value pcm comment { access 'read write' type ENUMERATED count 1 item.0 null item.1 pcm item.2 AC3 item.3 MPEG1 item.4 MP3 item.5 MPEG2 item.6 AAC item.7 DTS item.8 ATRAC item.9 ONE_BIT_AUDIO item.10 DOLBY_DIGITAL_PLUS item.11 DTS_HD item.12 MAT item.13 WMAPRO } } } state.U0x46d0x9a1 { control.1 { iface MIXER name 'Mic Capture Switch' value true comment { access 'read write' type BOOLEAN count 1 } } control.2 { iface MIXER name 'Mic Capture Volume' value 1536 comment { access 'read write' type INTEGER count 1 range '0 - 3072' dbmin 1800 dbmax 3000 dbvalue.0 2400 } } }
Thanks.
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 6,037 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,201 01-24-2019, 07:00 AM
Last Post: ecolezen
  Sound quality from audio jack devanl 0 6,260 10-11-2017, 10:39 PM
Last Post: devanl
  Packet loss on lan port Hiren 4 11,455 09-06-2016, 08:18 AM
Last Post: Hiren
