Enable Mic on 3.5 jack port
(03-27-2017, 09:43 AM)xalius Wrote: That should be ok, I would use arecord too for testing, make sure you have the correct device...
Here the devices:
**** List of CAPTURE Hardware Devices ****
card 1: audiocodec [audiocodec], device 0: SUNXI-CODEC codec-aif1-0 []
 Subdevices: 1/1
 Subdevice #0: subdevice #0
card 1: audiocodec [audiocodec], device 1: bb Voice codec-aif2-1 []
 Subdevices: 1/1
card 1: audiocodec [audiocodec], device 2: bb-bt-clk codec-aif2-2 []
 Subdevices: 1/1
card 1: audiocodec [audiocodec], device 3: bt Voice codec-aif3-3 []
 Subdevices: 1/1
**** List of PLAYBACK Hardware Devices ****
card 0: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
 Subdevices: 1/1
 Subdevices: 1/1
 Subdevices: 1/1
 Subdevices: 1/1
 Subdevices: 1/1
and the same with pactl command:
Module #0
    Argument:
    Usage counter: n/a
    Properties:
        module.author = "Lennart Poettering"
        module.description = "Automatically restore the volume/mute state of devices"
        module.version = "8.0"
Module #1
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Automatically restore profile of cards"
Module #3
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Augment the property sets of streams with additional static information"
Module #4
    Argument:
    Usage counter: n/a
    Properties:
Module #5
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Detect available audio hardware and load matching drivers"
Module #6
    Argument: device_id="1" name="platform-sound.6" card_name="alsa_card.platform-sound.6" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
    Usage counter: 0
    Properties:
        module.description = "ALSA Card"
Module #7
    Argument: device_id="0" name="platform-sound.7" card_name="alsa_card.platform-sound.7" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
    Usage counter: 0
    Properties:
Module #8
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Native protocol (UNIX sockets)"
Module #9
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Automatically restore the default sink and source"
Module #10
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #11
    Argument:
    Usage counter: n/a
    Properties:
        module.author = "Colin Guthrie"
        module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #12
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Automatically set device of streams based on intended roles of devices"
Module #13
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "When a sink/source is idle for too long, suspend it"
Module #14
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Create a client for each login session of this user"
Module #15
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #16
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Detect when various filters are desirable"
Module #17
    Argument:
    Usage counter: n/a
    Properties:
        module.description = "Load filter sinks automatically when needed"
Sink #0
    State: SUSPENDED
    Description: audiocodec Analog Stereo
    Driver: module-alsa-card.c
    Sample Specification: s16le 2ch 44100Hz
    Channel Map: front-left,front-right
    Owner Module: 6
    Mute: no
    Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
            balance 0.00
    Base Volume: 65536 / 100% / 0.00 dB
    Monitor Source: alsa_output.platform-sound.6.analog-stereo.monitor
    Latency: 0 usec, configured 0 usec
    Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
    Properties:
        alsa.resolution_bits = "16"
        device.api = "alsa"
        device.class = "sound"
        alsa.class = "generic"
        alsa.subclass = "generic-mix"
        alsa.name = ""
        alsa.id = "SUNXI-CODEC codec-aif1-0"
        alsa.subdevice = "0"
        alsa.subdevice_name = "subdevice #0"
        alsa.device = "0"
        alsa.card = "1"
        alsa.card_name = "audiocodec"
        alsa.long_card_name = "audiocodec"
        alsa.driver_name = "sunxi_sndcodec"
        device.bus_path = "platform-sound.6"
        sysfs.path = "/devices/soc.0/sound.6/sound/card1"
        device.string = "hw:1"
        device.buffering.buffer_size = "352800"
        device.buffering.fragment_size = "176400"
        device.access_mode = "mmap+timer"
        device.profile.name = "analog-stereo"
        device.profile.description = "Analog Stereo"
        device.description = "audiocodec Analog Stereo"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card"
    Ports:
        analog-output-headphones: Headphones (priority: 9000)
    Active Port: analog-output-headphones
    Formats:
        pcm
Sink #1
    State: SUSPENDED
    Description: sndhdmi Analog Stereo
    Owner Module: 7
    Mute: no
            balance 0.00
    Monitor Source: alsa_output.platform-sound.7.analog-stereo.monitor
    Flags: HARDWARE DECIBEL_VOLUME LATENCY
    Properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.id = "SUNXI-HDMIAUDIO sndhdmi-0"
        alsa.device = "0"
        alsa.card = "0"
        alsa.card_name = "sndhdmi"
        alsa.long_card_name = "sndhdmi"
        device.bus_path = "platform-sound.7"
        sysfs.path = "/devices/soc.0/sound.7/sound/card0"
        device.string = "hw:0"
        device.description = "sndhdmi Analog Stereo"
    Ports:
        analog-output: Analog Output (priority: 9900)
    Formats:
        pcm
Source #0
    State: SUSPENDED
    Description: Monitor of audiocodec Analog Stereo
    Owner Module: 6
    Mute: no
            balance 0.00
    Monitor of Sink: alsa_output.platform-sound.6.analog-stereo
    Flags: DECIBEL_VOLUME LATENCY
    Properties:
        device.description = "Monitor of audiocodec Analog Stereo"
        device.class = "monitor"
        alsa.card = "1"
        device.string = "1"
    Formats:
        pcm
Source #1
    State: SUSPENDED
    Owner Module: 6
    Mute: no
            balance 0.00
    Monitor of Sink: n/a
    Properties:
        device.api = "alsa"
        alsa.name = ""
        alsa.device = "0"
        alsa.card = "1"
    Ports:
        analog-input: Analog Input (priority: 10000)
    Active Port: analog-input
    Formats:
        pcm
Source #2
    State: SUSPENDED
    Description: Monitor of sndhdmi Analog Stereo
    Owner Module: 7
    Mute: no
            balance 0.00
    Monitor of Sink: alsa_output.platform-sound.7.analog-stereo
    Properties:
        device.description = "Monitor of sndhdmi Analog Stereo"
        alsa.card = "0"
        device.string = "0"
    Formats:
        pcm
Client #0
    Driver: module-systemd-login.c
    Owner Module: 14
    Properties:
        application.name = "Login Session c1"
        systemd-login.session = "c1"
Client #6
    Driver: protocol-native.c
    Owner Module: 8
    Properties:
        application.name = "pactl"
        native-protocol.peer = "UNIX socket client"
        native-protocol.version = "30"
        application.process.id = "14826"
        application.process.user = "ubuntu"
        application.process.host = "pine64"
        application.process.binary = "pactl"
        application.language = "C"
        window.x11.display = "localhost:10.0"
        application.process.machine_id = "8a7eae2accb7977bad9de1e15856980a"
        application.process.session_id = "c1"
Card #0
    Owner Module: 6
    Properties:
        alsa.card = "1"
        device.string = "1"
        device.description = "audiocodec"
    Profiles:
        input:analog-mono: Analog Mono Input (sinks: 0, sources: 1, priority: 2, available: yes)
        input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 60, available: yes)
        output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority: 200, available: yes)
        output:analog-mono+input:analog-mono: Analog Mono Duplex (sinks: 1, sources: 1, priority: 202, available: yes)
        output:analog-mono+input:analog-stereo: Analog Mono Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 260, available: yes)
        output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6000, available: yes)
        output:analog-stereo+input:analog-mono: Analog Stereo Output + Analog Mono Input (sinks: 1, sources: 1, priority: 6002, available: yes)
        output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6060, available: yes)
        off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
    Active Profile: output:analog-stereo+input:analog-stereo
    Ports:
        analog-input: Analog Input (priority: 10000, latency offset: 0 usec)
            Part of profile(s): input:analog-mono, input:analog-stereo, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo
        analog-output-headphones: Headphones (priority: 9000, latency offset: 0 usec)
            Properties:
                device.icon_name = "audio-headphones"
            Part of profile(s): output:analog-mono, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo
Card #1
    Owner Module: 7
    Properties:
        alsa.card = "0"
        device.string = "0"
        device.description = "sndhdmi"
    Profiles:
    Ports:
        analog-output: Analog Output (priority: 9900, latency offset: 0 usec)
            Part of profile(s): output:analog-mono, output:analog-stereo
Aren't these correct?
Thanks in advance for your patience.
changing various parameters now Mic is ok.
Here my asound.state file:
state.audiocodec {
    control.1 {
        iface MIXER
        name 'AIF1 ADC timeslot 0 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.2 {
        iface MIXER
        name 'AIF1 ADC timeslot 1 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.3 {
        iface MIXER
        name 'AIF1 DAC timeslot 0 volume'
        value.0 153
        value.1 153
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -450
            dbvalue.1 -450
    control.4 {
        iface MIXER
        name 'AIF1 DAC timeslot 1 volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.5 {
        iface MIXER
        name 'AIF1 ADC timeslot 0 mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.6 {
        iface MIXER
        name 'AIF1 ADC timeslot 1 mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 3'
            dbmin -600
            dbmax 1200
            dbvalue.0 -600
            dbvalue.1 -600
    control.7 {
        iface MIXER
        name 'AIF2 ADC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.8 {
        iface MIXER
        name 'AIF2 DAC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.9 {
        iface MIXER
        name 'AIF2 ADC mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.10 {
        iface MIXER
        name 'ADC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.11 {
        iface MIXER
        name 'DAC volume'
        value.0 160
        value.1 160
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 75
            dbvalue.1 75
    control.12 {
        iface MIXER
        name 'DAC mixer gain'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.13 {
        iface MIXER
        name 'digital volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -7308
            dbmax 0
            dbvalue.0 -7308
    control.14 {
        iface MIXER
        name 'earpiece volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4350
            dbmax 300
            dbvalue.0 -4350
    control.15 {
        iface MIXER
        name 'speaker volume'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4800
            dbmax -150
            dbvalue.0 -4800
    control.16 {
        iface MIXER
        name 'headphone volume'
        value 44
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -6300
            dbmax 0
            dbvalue.0 -1900
    control.17 {
        iface MIXER
        name 'MIC1_G boost stage output mixer control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.18 {
        iface MIXER
        name 'MIC1 boost AMP gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.19 {
        iface MIXER
        name 'MIC2 BST stage to L_R outp mixer gain'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.20 {
        iface MIXER
        name 'MIC2 boost AMP gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.21 {
        iface MIXER
        name 'LINEINL/R to L_R output mixer gain'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.22 {
        iface MIXER
        name 'ADC input gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.23 {
        iface MIXER
        name 'Phoneout gain control'
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.24 {
        iface MIXER
        name 'SRC FUCTION'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.25 {
        iface MIXER
        name 'I2S HUB FUNC'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.26 {
        iface MIXER
        name 'Phoneout Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.27 {
        iface MIXER
        name 'Phoneout Mixer MIC2 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.28 {
        iface MIXER
        name 'Phoneout Mixer Rout_Mixer_Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.29 {
        iface MIXER
        name 'Phoneout Mixer Lout_Mixer_Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.30 {
        iface MIXER
        name 'ADCR Mux'
        value DMIC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.31 {
        iface MIXER
        name 'ADCL Mux'
        value DMIC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.32 {
        iface MIXER
        name 'MIC2 SRC'
        value MIC2
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 MIC3
            item.1 MIC2
    control.33 {
        iface MIXER
        name 'RADC input Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.34 {
        iface MIXER
        name 'RADC input Mixer MIC2 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.35 {
        iface MIXER
        name 'RADC input Mixer LINEINR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.36 {
        iface MIXER
        name 'RADC input Mixer r_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.37 {
        iface MIXER
        name 'RADC input Mixer l_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.38 {
        iface MIXER
        name 'RADC input Mixer PHONINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.39 {
        iface MIXER
        name 'RADC input Mixer PHONINN-PHONINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.40 {
        iface MIXER
        name 'LADC input Mixer MIC1 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.41 {
        iface MIXER
        name 'LADC input Mixer MIC2 boost Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.42 {
        iface MIXER
        name 'LADC input Mixer LINEINL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.43 {
        iface MIXER
        name 'LADC input Mixer l_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.44 {
        iface MIXER
        name 'LADC input Mixer r_output mixer Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.45 {
        iface MIXER
        name 'LADC input Mixer PHONINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.46 {
        iface MIXER
        name 'LADC input Mixer PHONINP-PHONINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.47 {
        iface MIXER
        name 'AIF3OUT Mux'
        value 'AIF2 ADC left channel'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'AIF2 ADC left channel'
            item.1 'AIF2 ADC right channel'
    control.48 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF1 DA0R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.49 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF1 DA1R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.50 {
        iface MIXER
        name 'AIF2 ADR Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.51 {
        iface MIXER
        name 'AIF2 ADR Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.52 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF1 DA0L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.53 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF1 DA1L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.54 {
        iface MIXER
        name 'AIF2 ADL Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.55 {
        iface MIXER
        name 'AIF2 ADL Mixer ADCL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.56 {
        iface MIXER
        name 'AIF2INR Mux'
        value AIF2_DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACR
            item.1 AIF2_DACL
            item.2 SUM_AIF2DACL_AIF2DACR
            item.3 AVE_AIF2DACL_AIF2DACR
    control.57 {
        iface MIXER
        name 'AIF2INL Mux'
        value AIF2_DACL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACL
            item.1 AIF2_DACR
    control.58 {
        iface MIXER
        name 'AIF2OUTR Mux'
        value AIF2_ADCR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCR
            item.1 AIF2_ADCL
            item.2 SUM_AIF2_ADCL_AIF2_ADCR
            item.3 AVE_AIF2_ADCL_AIF2_ADCR
    control.59 {
        iface MIXER
        name 'AIF2OUTL Mux'
        value AIF2_ADCL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCL
            item.1 AIF2_ADCR
    control.60 {
        iface MIXER
        name 'EAR Mux'
        value DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 DACR
            item.1 DACL
            item.2 'Right Analog Mixer'
            item.3 'Left Analog Mixer'
    control.61 {
        iface MIXER
        name 'SPK_L Mux'
        value 'MIXEL Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'MIXEL Switch'
            item.1 'MIXL MIXR  Switch'
    control.62 {
        iface MIXER
        name 'SPK_R Mux'
        value 'MIXER Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'MIXER Switch'
            item.1 'MIXR MIXL Switch'
    control.63 {
        iface MIXER
        name 'HP_L Mux'
        value 'DACL HPL Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'DACL HPL Switch'
            item.1 'Left Analog Mixer HPL Switch'
    control.64 {
        iface MIXER
        name 'HP_R Mux'
        value 'DACR HPR Switch'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 'DACR HPR Switch'
            item.1 'Right Analog Mixer HPR Switch'
    control.65 {
        iface MIXER
        name 'Right Output Mixer DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.66 {
        iface MIXER
        name 'Right Output Mixer DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.67 {
        iface MIXER
        name 'Right Output Mixer LINEINR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.68 {
        iface MIXER
        name 'Right Output Mixer MIC2Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.69 {
        iface MIXER
        name 'Right Output Mixer MIC1Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.70 {
        iface MIXER
        name 'Right Output Mixer PHONEINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.71 {
        iface MIXER
        name 'Right Output Mixer PHONEINN-PHONEINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.72 {
        iface MIXER
        name 'Left Output Mixer DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.73 {
        iface MIXER
        name 'Left Output Mixer DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.74 {
        iface MIXER
        name 'Left Output Mixer LINEINL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.75 {
        iface MIXER
        name 'Left Output Mixer MIC2Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.76 {
        iface MIXER
        name 'Left Output Mixer MIC1Booststage Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.77 {
        iface MIXER
        name 'Left Output Mixer PHONEINP Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.78 {
        iface MIXER
        name 'Left Output Mixer PHONEINP-PHONEINN Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.79 {
        iface MIXER
        name 'DACR Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.80 {
        iface MIXER
        name 'DACR Mixer AIF2DACR Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.81 {
        iface MIXER
        name 'DACR Mixer AIF1DA1R Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.82 {
        iface MIXER
        name 'DACR Mixer AIF1DA0R Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.83 {
        iface MIXER
        name 'DACL Mixer ADCL Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.84 {
        iface MIXER
        name 'DACL Mixer AIF2DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.85 {
        iface MIXER
        name 'DACL Mixer AIF1DA1L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.86 {
        iface MIXER
        name 'DACL Mixer AIF1DA0L Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.87 {
        iface MIXER
        name 'AIF1 AD1R Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.88 {
        iface MIXER
        name 'AIF1 AD1R Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.89 {
        iface MIXER
        name 'AIF1 AD1L Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.90 {
        iface MIXER
        name 'AIF1 AD1L Mixer ADCL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.91 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF1 DA0R Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.92 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.93 {
        iface MIXER
        name 'AIF1 AD0R Mixer ADCR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.94 {
        iface MIXER
        name 'AIF1 AD0R Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.95 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF1 DA0L Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.96 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF2 DACL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.97 {
        iface MIXER
        name 'AIF1 AD0L Mixer ADCL Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.98 {
        iface MIXER
        name 'AIF1 AD0L Mixer AIF2 DACR Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.99 {
        iface MIXER
        name 'AIF1IN1R Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1R
            item.1 AIF1_DA1L
            item.2 SUM_AIF1DA1L_AIF1DA1R
            item.3 AVE_AIF1DA1L_AIF1DA1R
    control.100 {
        iface MIXER
        name 'AIF1IN1L Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1L
            item.1 AIF1_DA1R
    control.101 {
        iface MIXER
        name 'AIF1IN0R Mux'
        value AIF1_DA0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0R
            item.1 AIF1_DA0L
            item.2 SUM_AIF1DA0L_AIF1DA0R
            item.3 AVE_AIF1DA0L_AIF1DA0R
    control.102 {
        iface MIXER
        name 'AIF1IN0L Mux'
        value AIF1_DA0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0L
            item.1 AIF1_DA0R
    control.103 {
        iface MIXER
        name 'AIF1OUT1R Mux'
        value AIF1_AD1R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1R
            item.1 AIF1_AD1L
            item.2 SUM_AIF1ADC1L_AIF1ADC1R
            item.3 AVE_AIF1ADC1L_AIF1ADC1R
    control.104 {
        iface MIXER
        name 'AIF1OUT1L Mux'
        value AIF1_AD1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1L
            item.1 AIF1_AD1R
    control.105 {
        iface MIXER
        name 'AIF1OUT0R Mux'
        value AIF1_AD0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0R
            item.1 AIF1_AD0L
            item.2 SUM_AIF1AD0L_AIF1AD0R
            item.3 AVE_AIF1AD0L_AIF1AD0R
    control.106 {
        iface MIXER
        name 'AIF1OUT0L Mux'
        value AIF1_AD0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0L
            item.1 AIF1_AD0R
    control.107 {
        iface MIXER
        name 'AIF2INR Mux VIR switch aif2inr aif3'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.108 {
        iface MIXER
        name 'AIF2INL Mux VIR switch aif2inl aif3'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.109 {
        iface MIXER
        name 'AIF2INR Mux switch aif2inr aif2'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.110 {
        iface MIXER
        name 'AIF2INL Mux switch aif2inl aif2'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.111 {
        iface MIXER
        name 'External Speaker Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.112 {
        iface MIXER
        name 'Headphone Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.113 {
        iface MIXER
        name 'Earpiece Switch'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
state.sndhdmi {
    control.1 {
        iface MIXER
        name 'hdmi audio format Function'
        value pcm
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 null
            item.1 pcm
            item.2 AC3
            item.3 MPEG1
            item.4 MP3
            item.5 MPEG2
            item.6 AAC
            item.7 DTS
            item.8 ATRAC
            item.9 ONE_BIT_AUDIO
            item.10 DOLBY_DIGITAL_PLUS
            item.11 DTS_HD
            item.12 MAT
            item.13 WMAPRO
state.U0x46d0x9a1 {
    control.1 {
        iface MIXER
        name 'Mic Capture Switch'
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.2 {
        iface MIXER
        name 'Mic Capture Volume'
        value 1536
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 3072'
            dbmin 1800
            dbmax 3000
            dbvalue.0 2400
Thanks to Xalius for support Wink
Go to the bottom for correct asound.state file.
Ok, thanks :-)
I will maybe make a diff to the original asound.state for the audiojack so we can add those things you changed to longsleep's default?
(03-27-2017, 03:34 PM)xalius Wrote: Ok, thanks :-)
Good Idea...
Thanks for all Xalius Smile
Hi Xalius,
here my correct asound.state (previous reply is not correct)
wiht the differences exposed:
differences patch file:
--- /home/noviabook3/Scrivania/asound.state
+++ /home/noviabook3/Scrivania/asound.state.OK_MIC_OUT_BKP
@@ -2,6 +2,54 @@
     control.1 {
         iface MIXER
+        value.0 228
+        value.1 228
+        comment {
+            access 'read write'
+            type INTEGER
+            count 2
+            range '0 - 255'
+            dbmin -11925
+            dbmax 7200
+            dbvalue.0 5175
+            dbvalue.1 5175
+    control.2 {
+        iface MIXER
+        name 'AIF1 ADC timeslot 1 volume'
+        value.0 225
+        value.1 225
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 255'
+            dbmin -11925
+            dbmax 7200
+            dbvalue.0 4950
+            dbvalue.1 4950
+    control.3 {
+        iface MIXER
+        name 'AIF1 DAC timeslot 0 volume'
+        value.0 153
+        value.1 153
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 255'
+            dbmin -11925
+            dbmax 7200
+            dbvalue.0 -450
+            dbvalue.1 -450
+    control.4 {
+        iface MIXER
+        name 'AIF1 DAC timeslot 1 volume'
         value.0 0
         value.1 0
         comment {
@@ -15,9 +63,41 @@
             dbvalue.1 -11925
-    control.2 {
-        iface MIXER
-        name 'AIF1 ADC timeslot 1 volume'
+    control.5 {
+        iface MIXER
+        name 'AIF1 ADC timeslot 0 mixer gain'
+        value.0 14
+        value.1 14
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 15'
+            dbmin -600
+            dbmax 8400
+            dbvalue.0 7800
+            dbvalue.1 7800
+    control.6 {
+        iface MIXER
+        name 'AIF1 ADC timeslot 1 mixer gain'
+        value.0 3
+        value.1 3
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 3'
+            dbmin -600
+            dbmax 1200
+            dbvalue.0 1200
+            dbvalue.1 1200
+    control.7 {
+        iface MIXER
+        name 'AIF2 ADC volume'
         value.0 0
         value.1 0
         comment {
@@ -31,9 +111,41 @@
             dbvalue.1 -11925
-    control.3 {
-        iface MIXER
-        name 'AIF1 DAC timeslot 0 volume'
+    control.8 {
+        iface MIXER
+        name 'AIF2 DAC volume'
+        value.0 0
+        value.1 0
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 255'
+            dbmin -11925
+            dbmax 7200
+            dbvalue.0 -11925
+            dbvalue.1 -11925
+    control.9 {
+        iface MIXER
+        name 'AIF2 ADC mixer gain'
+        value.0 0
+        value.1 0
+        comment {
+            type INTEGER
+            count 2
+            range '0 - 15'
+            dbmin -600
+            dbmax 8400
+            dbvalue.0 -600
+            dbvalue.1 -600
+    control.10 {
+        iface MIXER
+        name 'ADC volume'
         value.0 153
         value.1 153
         comment {
@@ -47,9 +159,9 @@
             dbvalue.1 -450
-    control.4 {
-        iface MIXER
-        name 'AIF1 DAC timeslot 1 volume'
+    control.11 {
+        iface MIXER
+        name 'DAC volume'
         value.0 0
         value.1 0
         comment {
@@ -63,9 +175,9 @@
             dbvalue.1 -11925
-    control.5 {
-        iface MIXER
-        name 'AIF1 ADC timeslot 0 mixer gain'
+    control.12 {
+        iface MIXER
+        name 'DAC mixer gain'
         value.0 0
         value.1 0
         comment {
@@ -79,118 +191,6 @@
             dbvalue.1 -600
-    control.6 {
-        iface MIXER
-        name 'AIF1 ADC timeslot 1 mixer gain'
-        value.0 0
-        value.1 0
-        comment {
-            access 'read write'
-            type INTEGER
-            count 2
-            range '0 - 3'
-            dbmin -600
-            dbmax 1200
-            dbvalue.0 -600
-            dbvalue.1 -600
-    control.7 {
-        iface MIXER
-        name 'AIF2 ADC volume'
-        value.0 0
-        value.1 0
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 255'
-            dbmin -11925
-            dbmax 7200
-            dbvalue.0 -11925
-            dbvalue.1 -11925
-    control.8 {
-        iface MIXER
-        name 'AIF2 DAC volume'
-        value.0 0
-        value.1 0
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 255'
-            dbmin -11925
-            dbmax 7200
-            dbvalue.0 -11925
-            dbvalue.1 -11925
-    control.9 {
-        iface MIXER
-        name 'AIF2 ADC mixer gain'
-        value.0 0
-        value.1 0
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 15'
-            dbmin -600
-            dbmax 8400
-            dbvalue.0 -600
-            dbvalue.1 -600
-    control.10 {
-        iface MIXER
-        name 'ADC volume'
-        value.0 0
-        value.1 0
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 255'
-            dbmin -11925
-            dbmax 7200
-            dbvalue.0 -11925
-            dbvalue.1 -11925
-    control.11 {
-        iface MIXER
-        name 'DAC volume'
-        value.0 160
-        value.1 160
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 255'
-            dbmin -11925
-            dbmax 7200
-            dbvalue.0 75
-            dbvalue.1 75
-    control.12 {
-        iface MIXER
-        name 'DAC mixer gain'
-        value.0 0
-        value.1 0
-        comment {
-            type INTEGER
-            count 2
-            range '0 - 15'
-            dbmin -600
-            dbmax 8400
-            dbvalue.0 -600
-            dbvalue.1 -600
     control.13 {
         iface MIXER
@@ -236,7 +236,7 @@
     control.16 {
         iface MIXER
-        value 44
+        value 50
         comment {
             access 'read write'
             type INTEGER
@@ -244,7 +244,7 @@
             range '0 - 63'
             dbmin -6300
             dbmax 0
-            dbvalue.0 -1900
+            dbvalue.0 -1300
     control.17 {
@@ -320,6 +320,20 @@
     control.22 {
         iface MIXER
+        value 4
+        comment {
+            type INTEGER
+            count 1
+            range '0 - 7'
+            dbmin -450
+            dbmax 600
+            dbvalue.0 150
+    control.23 {
+        iface MIXER
+        name 'Phoneout gain control'
         value 0
         comment {
             access 'read write'
@@ -331,20 +345,6 @@
             dbvalue.0 -450
-    control.23 {
-        iface MIXER
-        name 'Phoneout gain control'
-        value 0
-        comment {
-            type INTEGER
-            count 1
-            range '0 - 7'
-            dbmin -450
-            dbmax 600
-            dbvalue.0 -450
     control.24 {
         iface MIXER
         name 'SRC FUCTION'
@@ -368,7 +368,7 @@
     control.26 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
@@ -378,7 +378,7 @@
     control.27 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
@@ -408,7 +408,7 @@
     control.30 {
         iface MIXER
         name 'ADCR Mux'
-        value DMIC
+        value ADC
         comment {
             access 'read write'
             type ENUMERATED
@@ -420,7 +420,7 @@
     control.31 {
         iface MIXER
         name 'ADCL Mux'
-        value DMIC
+        value ADC
         comment {
             access 'read write'
             type ENUMERATED
@@ -454,7 +454,7 @@
     control.34 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
@@ -524,7 +524,7 @@
     control.41 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
@@ -1074,7 +1074,7 @@
     control.93 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
@@ -1114,7 +1114,7 @@
     control.97 {
         iface MIXER
-        value false
+        value true
         comment {
             access 'read write'
             type BOOLEAN
complete asound.state:
state.audiocodec {
    control.1 {
        iface MIXER
        value.0 228
        value.1 228
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 5175
            dbvalue.1 5175
    control.2 {
        iface MIXER
        value.0 225
        value.1 225
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 4950
            dbvalue.1 4950
    control.3 {
        iface MIXER
        value.0 153
        value.1 153
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -450
            dbvalue.1 -450
    control.4 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.5 {
        iface MIXER
        value.0 14
        value.1 14
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 7800
            dbvalue.1 7800
    control.6 {
        iface MIXER
        value.0 3
        value.1 3
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 3'
            dbmin -600
            dbmax 1200
            dbvalue.0 1200
            dbvalue.1 1200
    control.7 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.8 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.9 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.10 {
        iface MIXER
        name 'ADC volume'
        value.0 153
        value.1 153
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -450
            dbvalue.1 -450
    control.11 {
        iface MIXER
        name 'DAC volume'
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 255'
            dbmin -11925
            dbmax 7200
            dbvalue.0 -11925
            dbvalue.1 -11925
    control.12 {
        iface MIXER
        value.0 0
        value.1 0
        comment {
            access 'read write'
            type INTEGER
            count 2
            range '0 - 15'
            dbmin -600
            dbmax 8400
            dbvalue.0 -600
            dbvalue.1 -600
    control.13 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -7308
            dbmax 0
            dbvalue.0 -7308
    control.14 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4350
            dbmax 300
            dbvalue.0 -4350
    control.15 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 31'
            dbmin -4800
            dbmax -150
            dbvalue.0 -4800
    control.16 {
        iface MIXER
        value 50
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 63'
            dbmin -6300
            dbmax 0
            dbvalue.0 -1300
    control.17 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.18 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.19 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.20 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin 0
            dbmax 1400
            dbvalue.0 0
    control.21 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.22 {
        iface MIXER
        value 4
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 150
    control.23 {
        iface MIXER
        value 0
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 7'
            dbmin -450
            dbmax 600
            dbvalue.0 -450
    control.24 {
        iface MIXER
        name 'SRC FUCTION'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.25 {
        iface MIXER
        name 'I2S HUB FUNC'
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.26 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.27 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.28 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.29 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.30 {
        iface MIXER
        name 'ADCR Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.31 {
        iface MIXER
        name 'ADCL Mux'
        value ADC
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 ADC
            item.1 DMIC
    control.32 {
        iface MIXER
        name 'MIC2 SRC'
        value MIC2
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 MIC3
            item.1 MIC2
    control.33 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.34 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.35 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.36 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.37 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.38 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.39 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.40 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.41 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.42 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.43 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.44 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.45 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.46 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.47 {
        iface MIXER
        name 'AIF3OUT Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.48 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.49 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.50 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.51 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.52 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.53 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.54 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.55 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.56 {
        iface MIXER
        name 'AIF2INR Mux'
        value AIF2_DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACR
            item.1 AIF2_DACL
    control.57 {
        iface MIXER
        name 'AIF2INL Mux'
        value AIF2_DACL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_DACL
            item.1 AIF2_DACR
    control.58 {
        iface MIXER
        name 'AIF2OUTR Mux'
        value AIF2_ADCR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCR
            item.1 AIF2_ADCL
    control.59 {
        iface MIXER
        name 'AIF2OUTL Mux'
        value AIF2_ADCL
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF2_ADCL
            item.1 AIF2_ADCR
    control.60 {
        iface MIXER
        name 'EAR Mux'
        value DACR
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 DACR
            item.1 DACL
    control.61 {
        iface MIXER
        name 'SPK_L Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.62 {
        iface MIXER
        name 'SPK_R Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.63 {
        iface MIXER
        name 'HP_L Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.64 {
        iface MIXER
        name 'HP_R Mux'
        comment {
            access 'read write'
            type ENUMERATED
            count 1
    control.65 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.66 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.67 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.68 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.69 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.70 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.71 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.72 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.73 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.74 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.75 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.76 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.77 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.78 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.79 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.80 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.81 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.82 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.83 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.84 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.85 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.86 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.87 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.88 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.89 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.90 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.91 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.92 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.93 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.94 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.95 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.96 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.97 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.98 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.99 {
        iface MIXER
        name 'AIF1IN1R Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1R
            item.1 AIF1_DA1L
    control.100 {
        iface MIXER
        name 'AIF1IN1L Mux'
        value AIF1_DA1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA1L
            item.1 AIF1_DA1R
    control.101 {
        iface MIXER
        name 'AIF1IN0R Mux'
        value AIF1_DA0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0R
            item.1 AIF1_DA0L
    control.102 {
        iface MIXER
        name 'AIF1IN0L Mux'
        value AIF1_DA0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_DA0L
            item.1 AIF1_DA0R
    control.103 {
        iface MIXER
        value AIF1_AD1R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1R
            item.1 AIF1_AD1L
    control.104 {
        iface MIXER
        value AIF1_AD1L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD1L
            item.1 AIF1_AD1R
    control.105 {
        iface MIXER
        value AIF1_AD0R
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0R
            item.1 AIF1_AD0L
    control.106 {
        iface MIXER
        value AIF1_AD0L
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 AIF1_AD0L
            item.1 AIF1_AD0R
    control.107 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.108 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.109 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.110 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.111 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.112 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.113 {
        iface MIXER
        value false
        comment {
            access 'read write'
            type BOOLEAN
            count 1
state.sndhdmi {
    control.1 {
        iface MIXER
        value pcm
        comment {
            access 'read write'
            type ENUMERATED
            count 1
            item.0 null
            item.1 pcm
            item.2 AC3
            item.3 MPEG1
            item.4 MP3
            item.5 MPEG2
            item.6 AAC
            item.7 DTS
            item.8 ATRAC
            item.11 DTS_HD
            item.12 MAT
            item.13 WMAPRO
state.U0x46d0x9a1 {
    control.1 {
        iface MIXER
        value true
        comment {
            access 'read write'
            type BOOLEAN
            count 1
    control.2 {
        iface MIXER
        value 1536
        comment {
            access 'read write'
            type INTEGER
            count 1
            range '0 - 3072'
            dbmin 1800
            dbmax 3000
            dbvalue.0 2400
Thanks.
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 5,887 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,067 01-24-2019, 07:00 AM
Last Post: ecolezen
  Sound quality from audio jack devanl 0 6,115 10-11-2017, 10:39 PM
Last Post: devanl
  Packet loss on lan port Hiren 4 11,212 09-06-2016, 08:18 AM
Last Post: Hiren
