Power up HDDs
Hello, good day. I'm trying to use my pine to setup a simpe nfs server with 3 HDDs. There's not enough power to get even one working so, how do I power up the disks to get them working in the pine? Thank you.
Hey!
I use an external hub to power the HDD I have attached to my pine64. I use this hub: https://www.amazon.co.uk/gp/product/B00E...UTF8&psc=1
I am not sure It could handle 3 HDDs tho, but I can assure you it does well with one.
I would recommend a powered hub as well, one with at least one amp per hard drive.  The one linked above would be marginal for three hard drives.  It might work but it might not if all three decided to spin up at the same time.
(03-17-2017, 03:07 PM)fractal Wrote: I would recommend a powered hub as well, one with at least one amp per hard drive.  The one linked above would be marginal for three hard drives.  It might work but it might not if all three decided to spin up at the same time.
Since my original post, I now have 2.5" drives attached to the USB hub and haven't had any issues insofar.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 7,430 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 38,599 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 5,540 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 15,550 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 29,148 03-20-2018, 12:01 AM
Last Post: pfeerick
  Provide power in via Pi-2 header BenCranston 22 52,745 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 11,744 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 29,441 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 57,556 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 11,111 10-02-2016, 04:35 AM
Last Post: pfeerick
