Anyone know can play how long the LITHIUM BATTERY CASING?
anyone know it can play how long ?
https://www.pine64.org/?product=lithium-battery-casing
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
(03-05-2017, 06:35 AM)joe Wrote: any know it can play how long ?
It's intended to accept 18650 lithium-ion cylindrical batteries/cell, and since it's based on a power bank case, I'd estimate that it is approximately 10cm long, 8cm wide, and 2cm high (give or take a few millimetres on each axis, and when on its side, as shown in the pictures). This is based on an aluminium 3-cell powerbank that I have that looks very similar in appearance, and also contains three batteries.
Think Joe was asking about how long the Pine64 can run off the battery and not the physical size ? Smile (I may be mistaken).
If yes, then granted you use 1500mha batteries (4500mha total) - I'd guess 3-4 hrs (depending on OS, application and load).
(03-06-2017, 06:19 AM)Luke Wrote: Think Joe was asking about how long the Pine64 can run off the battery and not the physical size ? Smile  (I may be mistaken).
You're Right , my bad English  Big Grin
but thank pfeerick and luke !
Modern 18650 cells like the Panasonic NCR18650B 3,6V - 3,7V 3400mAh will give you around 10Ah in the battery pack which is about the same as the Pinebook battery...
  Battery and the PlayBox JoeHz 6 14,886 09-13-2016, 12:18 AM
Last Post: gperez1234
  Battery backup and automatic shutdown and startup caseih 9 19,900 05-09-2016, 10:17 AM
Last Post: rahlquist
