02-19-2017, 02:42 PM
I want to use Pine64 as a home-assistant.io server with homegear installed to control eq-3 max! thermostats. I managed to install all of the software but problem occurred after I connected CC1101 radio board to pine. I followed this diagram ti-cc1101.png which is for Raspberry but I found all of the pins with help from this site http://pixcl.com/wp/decaf-boards-and-the...rypie-2-3/
Unfortunately home-gear doesn't see the board and I can't figure out where is the problem. Do I need to change something in OS config or GPIO interface is not working in current development state?
Thanks in advance for any suggestions
