01-07-2017, 11:49 AM
I was attempting to rebuild the EFI to support win10 core.
I followed the instructions at:https://github.com/Leeway213/WinIoTBoot
I am running under Ubuntu 16 (64bit) as the Windows build is not supported yet.
After executing the ./build.sh script in the SunxiPlatformPkg directory and answering the target questions it failed because the "C" directory
in the base tools source folder is not present. I copied the "C" folder from the edk2 master repo and it rebuild tools now on launch of same script but now I get the
following error:
Build start time: 09:25:01, Jan.07 2017
WORKSPACE = /home/david/edk2
ECP_SOURCE = /home/david/edk2/EdkCompatibilityPkg
EDK_SOURCE = /home/david/edk2/EdkCompatibilityPkg
EFI_SOURCE = /home/david/edk2/EdkCompatibilityPkg
EDK_TOOLS_PATH = /home/david/edk2/BaseTools
Architecture(s) = ARM
Build target = RELEASE
Toolchain = ARMLINUXGCC
Active Platform = /home/david/edk2/SunxiPlatformPkg/sun50iw1p1Pkg/sun50iw1p1Pkg.dsc
Flash Image Definition = /home/david/edk2/SunxiPlatformPkg/sun50iw1p1Pkg/sun50iw1p1Pkg.fdf
Processing meta-data ............. done!
Building ... /home/david/edk2/MdePkg/Library/BasePcdLibNull/BasePcdLibNull.inf [ARM]
"/home/david/edk2/SunxiPlatformPkg/pctools/toolchain/gcc-linaro/bin/arm-linux-gnueabi-gcc" -march=armv7-a -mfpu=neon -I/home/david/edk2/SunxiPlatformPkg/sun50iw1p1Pkg/Include/Sun50iW1P1 -g -O2 -fshort-wchar -fno-strict-aliasing -Wall -Werror -Wno-missing-braces -Wno-array-bounds -c -include AutoGen.h -mword-relocations -mlittle-endian -mabi=aapcs -mapcs -fno-short-enums -save-temps -fsigned-char -ffunction-sections -fdata-sections -fomit-frame-pointer -Wno-address -mfloat-abi=soft -fno-stack-protector -mno-unaligned-access -Wno-unused-but-set-variable -DCONFIG_ARCH_SUN50IW1P1 -o /home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BasePcdLibNull/BasePcdLibNull/OUTPUT/./PcdLib.obj -I/home/david/edk2/MdePkg/Library/BasePcdLibNull -I/home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BasePcdLibNull/BasePcdLibNull/DEBUG -I/home/david/edk2/MdePkg -I/home/david/edk2/MdePkg/Include -I/home/david/edk2/MdePkg/Include/Arm /home/david/edk2/MdePkg/Library/BasePcdLibNull/PcdLib.c
/bin/sh: 1: /home/david/edk2/SunxiPlatformPkg/pctools/toolchain/gcc-linaro/bin/arm-linux-gnueabi-gcc: not found
GNUmakefile:316: recipe for target '/home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BasePcdLibNull/BasePcdLibNull/OUTPUT/PcdLib.obj' failed
make: *** [/home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BasePcdLibNull/BasePcdLibNull/OUTPUT/PcdLib.obj] Error 127
build.py...
: error 7000: Failed to execute command
make --no-print-directory tbuild [/home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BasePcdLibNull/BasePcdLibNull]
build.py...
make --no-print-directory tbuild [/home/david/edk2/Build/SunxiPlatform/sun50iw1p1Pkg/RELEASE_ARMLINUXGCC/ARM/MdePkg/Library/BaseDebugLibNull/BaseDebugLibNull]
build.py...
: error F002: Failed to build module
/home/david/edk2/MdePkg/Library/BasePcdLibNull/BasePcdLibNull.inf [ARM, ARMLINUXGCC, RELEASE]
- Failed -
Build end time: 09:25:15, Jan.07 2017
Build total time: 00:00:14
I can not understand this error. the arm-linux-gnueabi-gcc is clearly in the pctools/toolchain directory and it has the executable attribute.
Any help?
following error:
build.py...
build.py...
build.py...
- Failed -
Any help?
