Wifi - broadcast
Hi all,
I have a Pine64+ board.  The WiFi unit on the Pine is configured fine and it's able to detect and connect to my home WiFi router.
Now, I have a web server hosted on my Pine 64+ board.  I'm able to access this webpage (i.e. homepage hosted on Pine64+ board) using my tablet, all connected through the home WiFi router.
Is it possible to configure the Pine 64+ WiFi module such that I should be able to connect to it directly from my tab instead of connecting from my home WiFi router?  In other words, the Pine64+ WiFi module should broadcast itself, so that my tablet is able to detect and connect to the WiFi module of the Pine64+ board.  (thereby removing the need of a WiFi router).
I have attached a png file (task.png), which I feel explains the above better.
Thanks,
Ravi.
Missed to give the OS details: I'm running xubuntu on the Pine64 board and have installed LAMP stack.
you might be able to get a software access point setup. this explains one method.
https://www.cyberciti.biz/faq/debian-ubu...ess-point/
Hi Shankar,
I am trying to achieve the same task that you tried two years ago.
Your experience and success story regarding this will save me time and effort.
Thank you
  WiFi Packet Loss and Slow Speed PineA64 Debian 8 Stymied 2 9,124 03-26-2017, 01:23 AM
Last Post: Stymied
