mounting rootfs
Hello I am running Ubuntu on pine64 i would like to mount system rootfs
how can it be done?
Welcome to Ubuntu 16.04 LTS (GNU/Linux 3.10.101-4-pine64-longsleep aarch64)
Linux localhost.localdomain 3.10.101-4-pine64-longsleep #51 SMP PREEMPT Thu May 26 18:20:37 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
ubuntu@localhost:~$
The rootfs (files located under /)  should be mounted automatically in the Ubuntu image you are using.
Just type "cd /"  and hit enter
Type "ls" and you'll see what files and directories are there.
Type "mount"  to see a list of filesystems and where they are mounted within the rootfs
Filesystems that are mounted at startup an the options they are mounted with, can be found in a file called /etc/fstab.
  Minimal 64bit ARM RootFS for Debian and Ubuntu umiddelb 46 108,231 03-06-2016, 10:28 AM
Last Post: umiddelb
