Howto test and tune Gigabit Networking (1000M)
Pine64+ and Pine64+2GB have a Gigabit NIC. To actually test the speed of the network interface a few things need to be considered. If you want to test the NIC performance of your Pine64, this thread is for you.
To do any meaningful testing, you need another device which is well known and capable to deliver over 900MBit/s with the cable and switch it is connected to. Also make sure that the network cable you use for the Pine64 is working with Gigabit Network (8 wires twisted pair, Cat5e or Cat6).
It is important to understand that you should test network speed only. If you copy a file to the Pine or something you are testing something completely different.
Furthermore it is important to know the settings of the whole stack involved and always use same / good settings. I added a platform-script at https://github.com/longsleep/build-pine6...network.sh to help with that. Make sure to run this or similar before any testing.
- Make sure you use the latest Kernel. `uname -a`
root@pine64:~# uname -a Linux pine64 3.10.102-3-pine64-longsleep #98 SMP PREEMPT Sat Aug 20 22:28:17 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
- Use iperf3. Start it in server mode on your other host (iperf3 -s). iperf 3 exists for essentially all platforms as precompiled binary (https://iperf.fr/iperf-download.php).
- Install iperf3 on your Pine64. `sudo apt-get install iperf3`.
- Run iperf3 in client mode on Pine64 `iperf -c $OTHER_HOST_IP`
This can reach about 800 Mbits/sec
root@pine64:~# iperf3 -c 192.168.1.111   Connecting to host 192.168.1.111, port 5201 [  4] local 192.168.1.54 port 33437 connected to 192.168.1.111 port 5201 [ ID] Interval           Transfer     Bandwidth       Retr  Cwnd [  4]   0.00-1.01   sec  99.0 MBytes   825 Mbits/sec    1    168 KBytes       [  4]   1.01-2.00   sec   100 MBytes   848 Mbits/sec    1    139 KBytes       [  4]   2.00-3.00   sec   101 MBytes   849 Mbits/sec    0    197 KBytes       [  4]   3.00-4.00   sec   100 MBytes   841 Mbits/sec    0    235 KBytes       [  4]   4.00-5.00   sec  97.7 MBytes   820 Mbits/sec    3    139 KBytes       [  4]   5.00-6.00   sec  99.1 MBytes   831 Mbits/sec    2   82.0 KBytes       [  4]   6.00-7.00   sec  95.4 MBytes   801 Mbits/sec    1    120 KBytes       [  4]   7.00-8.00   sec  97.7 MBytes   819 Mbits/sec    1    151 KBytes       [  4]   8.00-9.00   sec  96.8 MBytes   812 Mbits/sec    0    202 KBytes       [  4]   9.00-10.00  sec   102 MBytes   854 Mbits/sec    1    175 KBytes       - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec   990 MBytes   830 Mbits/sec   10             sender [  4]   0.00-10.00  sec   989 MBytes   829 Mbits/sec                  receiver
- Run iperf3 in client reverse mode on Pine64 `iperf -c $OTHER_HOST_IP -R`
This can reach about 900 Mbits/sec.
root@pine64:~# iperf3 -c 192.168.1.111 -R Connecting to host 192.168.1.111, port 5201 Reverse mode, remote host 192.168.1.111 is sending [  4] local 192.168.1.54 port 33435 connected to 192.168.1.111 port 5201 [ ID] Interval           Transfer     Bandwidth [  4]   0.00-1.00   sec   104 MBytes   873 Mbits/sec                   [  4]   1.00-2.00   sec   107 MBytes   901 Mbits/sec                   [  4]   2.00-3.00   sec   106 MBytes   893 Mbits/sec                   [  4]   3.00-4.00   sec   107 MBytes   901 Mbits/sec                   [  4]   4.00-5.00   sec   108 MBytes   903 Mbits/sec                   [  4]   5.00-6.00   sec   105 MBytes   879 Mbits/sec                   [  4]   6.00-7.00   sec   109 MBytes   912 Mbits/sec                   [  4]   7.00-8.00   sec   107 MBytes   898 Mbits/sec                   [  4]   8.00-9.00   sec   107 MBytes   900 Mbits/sec                   [  4]   9.00-10.00  sec   107 MBytes   895 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval           Transfer     Bandwidth [  4]   0.00-10.00  sec  1.04 GBytes   896 Mbits/sec                  sender [  4]   0.00-10.00  sec  1.04 GBytes   896 Mbits/sec                  receiver
- To completely max out the Pine64 run iperf 3 in parallel mode (4)
This should be a little faster (combined) than the results from only a single thread.
root@pine64:~# iperf3 -c 192.168.1.111 -P 4 Connecting to host 192.168.1.111, port 5201 [  4] local 192.168.1.54 port 33439 connected to 192.168.1.111 port 5201 [  6] local 192.168.1.54 port 33440 connected to 192.168.1.111 port 5201 [  8] local 192.168.1.54 port 33441 connected to 192.168.1.111 port 5201 [ 10] local 192.168.1.54 port 33442 connected to 192.168.1.111 port 5201 [ ID] Interval           Transfer     Bandwidth       Retr  Cwnd [  4]   0.00-1.03   sec  26.9 MBytes   219 Mbits/sec    1    107 KBytes       [  6]   0.00-1.03   sec  26.7 MBytes   218 Mbits/sec    0    209 KBytes       [  8]   0.00-1.03   sec  26.5 MBytes   216 Mbits/sec    0    212 KBytes       [ 10]   0.00-1.03   sec  26.4 MBytes   215 Mbits/sec    0    208 KBytes       [SUM]   0.00-1.03   sec   106 MBytes   868 Mbits/sec    1             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   1.03-2.02   sec  26.2 MBytes   222 Mbits/sec    0    122 KBytes       [  6]   1.03-2.02   sec  26.2 MBytes   222 Mbits/sec    0    236 KBytes       [  8]   1.03-2.02   sec  26.2 MBytes   222 Mbits/sec    0    239 KBytes       [ 10]   1.03-2.02   sec  26.2 MBytes   222 Mbits/sec    0    239 KBytes       [SUM]   1.03-2.02   sec   105 MBytes   888 Mbits/sec    0             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   2.02-3.02   sec  26.2 MBytes   220 Mbits/sec    1   97.6 KBytes       [  6]   2.02-3.02   sec  26.2 MBytes   221 Mbits/sec    1    112 KBytes       [  8]   2.02-3.02   sec  26.2 MBytes   221 Mbits/sec    0    257 KBytes       [ 10]   2.02-3.02   sec  26.2 MBytes   221 Mbits/sec    0    255 KBytes       [SUM]   2.02-3.02   sec   105 MBytes   882 Mbits/sec    2             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   3.02-4.02   sec  26.2 MBytes   221 Mbits/sec    0    110 KBytes       [  6]   3.02-4.02   sec  26.2 MBytes   221 Mbits/sec    0    124 KBytes       [  8]   3.02-4.02   sec  26.2 MBytes   221 Mbits/sec    0    262 KBytes       [ 10]   3.02-4.02   sec  26.2 MBytes   221 Mbits/sec    1    109 KBytes       [SUM]   3.02-4.02   sec   105 MBytes   884 Mbits/sec    1             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   4.02-5.01   sec  26.2 MBytes   222 Mbits/sec    0    122 KBytes       [  6]   4.02-5.01   sec  26.2 MBytes   222 Mbits/sec    0    130 KBytes       [  8]   4.02-5.01   sec  26.2 MBytes   222 Mbits/sec    0    269 KBytes       [ 10]   4.02-5.01   sec  26.2 MBytes   222 Mbits/sec    0    123 KBytes       [SUM]   4.02-5.01   sec   105 MBytes   887 Mbits/sec    0             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   5.01-6.05   sec  27.5 MBytes   222 Mbits/sec    1    106 KBytes       [  6]   5.01-6.05   sec  27.5 MBytes   222 Mbits/sec    0    132 KBytes       [  8]   5.01-6.05   sec  27.5 MBytes   222 Mbits/sec    1   94.7 KBytes       [ 10]   5.01-6.05   sec  27.5 MBytes   222 Mbits/sec    0    129 KBytes       [SUM]   5.01-6.05   sec   110 MBytes   889 Mbits/sec    2             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   6.05-7.04   sec  27.0 MBytes   227 Mbits/sec    0    117 KBytes       [  6]   6.05-7.04   sec  27.9 MBytes   235 Mbits/sec    0    143 KBytes       [  8]   6.05-7.04   sec  25.8 MBytes   218 Mbits/sec    0    115 KBytes       [ 10]   6.05-7.04   sec  22.8 MBytes   192 Mbits/sec    2   84.8 KBytes       [SUM]   6.05-7.04   sec   103 MBytes   872 Mbits/sec    2             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   7.04-8.01   sec  26.1 MBytes   226 Mbits/sec    0    127 KBytes       [  6]   7.04-8.01   sec  26.2 MBytes   228 Mbits/sec    0    150 KBytes       [  8]   7.04-8.01   sec  24.9 MBytes   216 Mbits/sec    0    126 KBytes       [ 10]   7.04-8.01   sec  23.8 MBytes   206 Mbits/sec    0    102 KBytes       [SUM]   7.04-8.01   sec   101 MBytes   875 Mbits/sec    0             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   8.01-9.00   sec  26.2 MBytes   221 Mbits/sec    0    136 KBytes       [  6]   8.01-9.01   sec  26.2 MBytes   221 Mbits/sec    0    156 KBytes       [  8]   8.01-9.01   sec  26.2 MBytes   221 Mbits/sec    0    130 KBytes       [ 10]   8.01-9.01   sec  26.2 MBytes   221 Mbits/sec    0    116 KBytes       [SUM]   8.01-9.00   sec   105 MBytes   885 Mbits/sec    0             - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   9.00-10.00  sec  26.2 MBytes   221 Mbits/sec    0    144 KBytes       [  6]   9.01-10.00  sec  26.2 MBytes   221 Mbits/sec    1    109 KBytes       [  8]   9.01-10.00  sec  26.2 MBytes   221 Mbits/sec    0    139 KBytes       [ 10]   9.01-10.00  sec  26.2 MBytes   221 Mbits/sec    0    127 KBytes       [SUM]   9.00-10.00  sec   105 MBytes   882 Mbits/sec    1             - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec   265 MBytes   222 Mbits/sec    3             sender [  4]   0.00-10.00  sec   265 MBytes   222 Mbits/sec                  receiver [  6]   0.00-10.00  sec   266 MBytes   223 Mbits/sec    2             sender [  6]   0.00-10.00  sec   266 MBytes   223 Mbits/sec                  receiver [  8]   0.00-10.00  sec   262 MBytes   220 Mbits/sec    1             sender [  8]   0.00-10.00  sec   262 MBytes   220 Mbits/sec                  receiver [ 10]   0.00-10.00  sec   258 MBytes   216 Mbits/sec    3             sender [ 10]   0.00-10.00  sec   258 MBytes   216 Mbits/sec                  receiver [SUM]   0.00-10.00  sec  1.03 GBytes   881 Mbits/sec    9             sender [SUM]   0.00-10.00  sec  1.03 GBytes   881 Mbits/sec                  receiver
root@pine64:~# iperf3 -c 192.168.1.111 -P 4 -R Connecting to host 192.168.1.111, port 5201 Reverse mode, remote host 192.168.1.111 is sending [  4] local 192.168.1.54 port 33444 connected to 192.168.1.111 port 5201 [  6] local 192.168.1.54 port 33445 connected to 192.168.1.111 port 5201 [  8] local 192.168.1.54 port 33446 connected to 192.168.1.111 port 5201 [ 10] local 192.168.1.54 port 33447 connected to 192.168.1.111 port 5201 [ ID] Interval           Transfer     Bandwidth [  4]   0.00-1.01   sec  20.9 MBytes   174 Mbits/sec                   [  6]   0.00-1.01   sec  20.8 MBytes   174 Mbits/sec                   [  8]   0.00-1.01   sec  20.9 MBytes   174 Mbits/sec                   [ 10]   0.00-1.01   sec  20.8 MBytes   173 Mbits/sec                   [SUM]   0.00-1.01   sec  83.3 MBytes   694 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   1.01-2.00   sec  27.4 MBytes   231 Mbits/sec                   [  6]   1.01-2.00   sec  27.3 MBytes   230 Mbits/sec                   [  8]   1.01-2.00   sec  27.5 MBytes   232 Mbits/sec                   [ 10]   1.01-2.00   sec  27.5 MBytes   232 Mbits/sec                   [SUM]   1.01-2.00   sec   110 MBytes   925 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   2.00-3.00   sec  28.1 MBytes   236 Mbits/sec                   [  6]   2.00-3.00   sec  28.0 MBytes   235 Mbits/sec                   [  8]   2.00-3.00   sec  28.0 MBytes   235 Mbits/sec                   [ 10]   2.00-3.00   sec  28.0 MBytes   235 Mbits/sec                   [SUM]   2.00-3.00   sec   112 MBytes   941 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   3.00-4.00   sec  28.0 MBytes   235 Mbits/sec                   [  6]   3.00-4.00   sec  28.1 MBytes   236 Mbits/sec                   [  8]   3.00-4.00   sec  28.0 MBytes   235 Mbits/sec                   [ 10]   3.00-4.00   sec  28.0 MBytes   235 Mbits/sec                   [SUM]   3.00-4.00   sec   112 MBytes   941 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   4.00-5.00   sec  28.0 MBytes   235 Mbits/sec                   [  6]   4.00-5.00   sec  28.0 MBytes   235 Mbits/sec                   [  8]   4.00-5.00   sec  28.1 MBytes   236 Mbits/sec                   [ 10]   4.00-5.00   sec  28.1 MBytes   236 Mbits/sec                   [SUM]   4.00-5.00   sec   112 MBytes   941 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   5.00-6.00   sec  28.1 MBytes   236 Mbits/sec                   [  6]   5.00-6.00   sec  28.1 MBytes   236 Mbits/sec                   [  8]   5.00-6.00   sec  28.0 MBytes   235 Mbits/sec                   [ 10]   5.00-6.00   sec  27.8 MBytes   233 Mbits/sec                   [SUM]   5.00-6.00   sec   112 MBytes   940 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   6.00-7.00   sec  27.9 MBytes   234 Mbits/sec                   [  6]   6.00-7.00   sec  27.9 MBytes   234 Mbits/sec                   [  8]   6.00-7.00   sec  27.9 MBytes   234 Mbits/sec                   [ 10]   6.00-7.00   sec  27.9 MBytes   234 Mbits/sec                   [SUM]   6.00-7.00   sec   112 MBytes   934 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   7.00-8.00   sec  28.1 MBytes   236 Mbits/sec                   [  6]   7.00-8.00   sec  28.0 MBytes   235 Mbits/sec                   [  8]   7.00-8.00   sec  28.0 MBytes   235 Mbits/sec                   [ 10]   7.00-8.00   sec  28.0 MBytes   235 Mbits/sec                   [SUM]   7.00-8.00   sec   112 MBytes   941 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   8.00-9.00   sec  28.0 MBytes   235 Mbits/sec                   [  6]   8.00-9.00   sec  28.0 MBytes   235 Mbits/sec                   [  8]   8.00-9.00   sec  28.0 MBytes   235 Mbits/sec                   [ 10]   8.00-9.00   sec  28.0 MBytes   235 Mbits/sec                   [SUM]   8.00-9.00   sec   112 MBytes   941 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   9.00-10.00  sec  28.0 MBytes   235 Mbits/sec                   [  6]   9.00-10.00  sec  28.1 MBytes   236 Mbits/sec                   [  8]   9.00-10.00  sec  28.0 MBytes   235 Mbits/sec                   [ 10]   9.00-10.00  sec  28.0 MBytes   235 Mbits/sec                   [SUM]   9.00-10.00  sec   112 MBytes   940 Mbits/sec                   - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval           Transfer     Bandwidth [  4]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  sender [  4]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  receiver [  6]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  sender [  6]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  receiver [  8]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  sender [  8]   0.00-10.00  sec   273 MBytes   229 Mbits/sec                  receiver [ 10]   0.00-10.00  sec   272 MBytes   228 Mbits/sec                  sender [ 10]   0.00-10.00  sec   272 MBytes   228 Mbits/sec                  receiver [SUM]   0.00-10.00  sec  1.06 GBytes   915 Mbits/sec                  sender [SUM]   0.00-10.00  sec  1.06 GBytes   914 Mbits/sec                  receiver
If your results are even faster, consider yourself lucky Smile. Feel free to post your results (please iperf3 results only).
I moved this thread to the Ethernet sub-forum; also, the thread has been made 'sticky'.
Hi there,
just made a short test with my actual environment again including the netwrok-script from longsleep with his actual kernel.
Switching the Pine64+ to a fixed GbE-port on my FritzBox 7490 acting as client: [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec  24.8 MBytes  20.8 Mbits/sec   31             sender [  4]   0.00-10.00  sec  24.7 MBytes  20.7 Mbits/sec                  receiver [  6]   0.00-10.00  sec  25.6 MBytes  21.5 Mbits/sec   31             sender [  6]   0.00-10.00  sec  25.5 MBytes  21.4 Mbits/sec                  receiver [  8]   0.00-10.00  sec  33.9 MBytes  28.5 Mbits/sec   19             sender [  8]   0.00-10.00  sec  33.8 MBytes  28.3 Mbits/sec                  receiver [ 10]   0.00-10.00  sec  28.5 MBytes  23.9 Mbits/sec   28             sender [ 10]   0.00-10.00  sec  28.3 MBytes  23.7 Mbits/sec                  receiver [SUM]   0.00-10.00  sec   113 MBytes  94.6 Mbits/sec  109             sender [SUM]   0.00-10.00  sec   112 MBytes  94.1 Mbits/sec                  receiver So about 100 Mbits as expected with a 100Mb server, but 109 retries! Same connection, but setting down the Pine64 to a fixed 100Mb port: [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec  28.2 MBytes  23.7 Mbits/sec    0             sender [  4]   0.00-10.00  sec  28.0 MBytes  23.5 Mbits/sec                  receiver [  6]   0.00-10.00  sec  28.1 MBytes  23.6 Mbits/sec    0             sender [  6]   0.00-10.00  sec  27.9 MBytes  23.4 Mbits/sec                  receiver [  8]   0.00-10.00  sec  28.3 MBytes  23.8 Mbits/sec    0             sender [  8]   0.00-10.00  sec  28.1 MBytes  23.6 Mbits/sec                  receiver [ 10]   0.00-10.00  sec  28.3 MBytes  23.8 Mbits/sec    0             sender [ 10]   0.00-10.00  sec  28.2 MBytes  23.6 Mbits/sec                  receiver [SUM]   0.00-10.00  sec   113 MBytes  94.8 Mbits/sec    0             sender [SUM]   0.00-10.00  sec   112 MBytes  94.1 Mbits/sec                  receiver same speed with not a single retry! Same connection with GbE port, but Pine64 this time acting as server: [ ID] Interval           Transfer     Bandwidth [  5]   0.00-10.05  sec  1008 KBytes   822 Kbits/sec                  sender [  5]   0.00-10.05  sec   901 KBytes   735 Kbits/sec                  receiver So this is ridiculous even with a 100Mb client. Switching the Pine64 back to a fixed 100Mb port acting as server: [ ID] Interval           Transfer     Bandwidth [  5]   0.00-10.06  sec   113 MBytes  94.3 Mbits/sec                  sender [  5]   0.00-10.06  sec   113 MBytes  94.3 Mbits/sec                  receiver
Will setup a second connection with my GbE-Win10 pc later and post the results also.
BTW: Also use a fixed MAC-addr with the leading 00:06:dc numbers and disabled ipv6 and avahidaemon, if somebody still thinks this makes really a difference!
Still no improvement and i can confirm my Fritzbox (FritzOS 6.60, also actual version) is capable to handle GbE with some other PCs i'm using.
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
(08-21-2016, 10:46 AM)androsch Wrote: BTW: Also use a fixed MAC-addr with the leading 00:06:dc numbers and disabled ipv6 and avahidaemon, if somebody still thinks this makes really a difference!
Yes this is what i expected. That is the board you sent me a couple of months ago yes? As it worked fine for my network it is something in your network / some incompatibility.
Btw, i got myself the cheapest gigabit switch i could find on Amazon to make the numbers from above: NETGEAR GS605-400PES (which is aroud 20EUR).
Just finished some further testing with my 2 Win10 PCs with GbE-ports:
Both connected with 1GbE ports: One acting as server: [ ID] Interval           Transfer     Bandwidth [  5]   0.00-10.06  sec  0.00 Bytes  0.00 bits/sec                  sender [  5]   0.00-10.06  sec   204 MBytes   170 Mbits/sec                  receiver [  7]   0.00-10.06  sec  0.00 Bytes  0.00 bits/sec                  sender [  7]   0.00-10.06  sec   196 MBytes   164 Mbits/sec                  receiver [  9]   0.00-10.06  sec  0.00 Bytes  0.00 bits/sec                  sender [  9]   0.00-10.06  sec   198 MBytes   165 Mbits/sec                  receiver [ 11]   0.00-10.06  sec  0.00 Bytes  0.00 bits/sec                  sender [ 11]   0.00-10.06  sec   194 MBytes   162 Mbits/sec                  receiver [SUM]   0.00-10.06  sec  0.00 Bytes  0.00 bits/sec                  sender [SUM]   0.00-10.06  sec   792 MBytes   660 Mbits/sec                  receiver the other acting as server: [ ID] Interval           Transfer     Bandwidth [  4]   0.00-10.00  sec   190 MBytes   159 Mbits/sec                  sender [  4]   0.00-10.00  sec   190 MBytes   159 Mbits/sec                  receiver [  6]   0.00-10.00  sec   165 MBytes   139 Mbits/sec                  sender [  6]   0.00-10.00  sec   165 MBytes   139 Mbits/sec                  receiver [  8]   0.00-10.00  sec   195 MBytes   163 Mbits/sec                  sender [  8]   0.00-10.00  sec   195 MBytes   163 Mbits/sec                  receiver [ 10]   0.00-10.00  sec   130 MBytes   109 Mbits/sec                  sender [ 10]   0.00-10.00  sec   130 MBytes   109 Mbits/sec                  receiver [SUM]   0.00-10.00  sec   680 MBytes   570 Mbits/sec                  sender [SUM]   0.00-10.00  sec   680 MBytes   570 Mbits/sec                  receiver So my GbE is not too quick, but both are connected during this test via remote desktop. One is in the basement, connected to the Fritzbox (port with 1GbE), the Fritzbox to the switch (TP-Link, about 5m cable) and then with a very long cable (about 30m) to the 3rd floor in a D-Link DIR 645 router just acting as additional wifi router for the 3rd floor. The other PC is connected with a short 3m cable to the DIR-645. So this proves (at least from my point of view) even with this long and maybe not perfect connection, there is a GbE connection capable to handle at least 570 - 660 Mbits! Using this connection (just plugging the cable from the Fritzbox from the pc to the Pine64+, this is what we get (Pine64 as server): [ ID] Interval           Transfer     Bandwidth [  4]   0.00-10.01  sec   693 KBytes   567 Kbits/sec                  sender [  4]   0.00-10.01  sec   621 KBytes   508 Kbits/sec                  receiver [  6]   0.00-10.01  sec   441 KBytes   361 Kbits/sec                  sender [  6]   0.00-10.01  sec   365 KBytes   299 Kbits/sec                  receiver [  8]   0.00-10.01  sec   756 KBytes   619 Kbits/sec                  sender [  8]   0.00-10.01  sec   656 KBytes   537 Kbits/sec                  receiver [ 10]   0.00-10.01  sec   945 KBytes   774 Kbits/sec                  sender [ 10]   0.00-10.01  sec   875 KBytes   716 Kbits/sec                  receiver [SUM]   0.00-10.01  sec  2.77 MBytes  2.32 Mbits/sec                  sender [SUM]   0.00-10.01  sec  2.46 MBytes  2.06 Mbits/sec                  receiver Pine64 acting as client: [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec  9.47 MBytes  7.95 Mbits/sec    5             sender [  4]   0.00-10.00  sec  9.37 MBytes  7.86 Mbits/sec                  receiver [  6]   0.00-10.00  sec  10.2 MBytes  8.56 Mbits/sec   44             sender [  6]   0.00-10.00  sec  10.1 MBytes  8.48 Mbits/sec                  receiver [  8]   0.00-10.00  sec  9.82 MBytes  8.23 Mbits/sec   28             sender [  8]   0.00-10.00  sec  9.71 MBytes  8.14 Mbits/sec                  receiver [ 10]   0.00-10.00  sec  11.0 MBytes  9.20 Mbits/sec   13             sender [ 10]   0.00-10.00  sec  10.8 MBytes  9.09 Mbits/sec                  receiver [SUM]   0.00-10.00  sec  40.5 MBytes  33.9 Mbits/sec   90             sender [SUM]   0.00-10.00  sec  40.0 MBytes  33.6 Mbits/sec                  receiver and now?
Got similar results before even with connecting one PC and the pine directly via the FritzBox or the TP-Link switch or the DIR-645, so i can not imagine any other influence than the Pine itself!
As stated again will be very interested if someone figures out the real reason for those problems with the Pine64, but for me its just working with a fixed 100Mbs port and then its stable and reliable with about 95Mbits.
Have a nice evening all together!
BTW: Yes, its the board you tested some time ago.
(08-21-2016, 11:12 AM)longsleep Wrote: Btw, i got myself the cheapest gigabit switch i could find on Amazon to make the numbers from above:  NETGEAR GS605-400PES (which is aroud 20EUR).
Have ordered this switch today and will connect my Pine64+ with this switch and all of my GbE-PCs again (each separately and without any other ports active and new cables also). Will take some time (delivery till 24th), so will come back then...
Maybe we get this sorted Undecided
Greetings,
Pre and post tuned network stats.
Pine64+ (2GB) <> TP-Link <> Workstation
Pre:
:~$ iperf3 -c 192.168.1.163 -t 30 [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-30.00  sec  1.83 GBytes   524 Mbits/sec  2755             sender [  4]   0.00-30.00  sec  1.83 GBytes   524 Mbits/sec                  receiver
Post:
:~$ iperf3 -c 192.168.1.163 -t 30 [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-30.00  sec  3.11 GBytes   891 Mbits/sec  382             sender [  4]   0.00-30.00  sec  3.11 GBytes   891 Mbits/sec                  receiver
Thanks.
I tested it with my WNDR3700 router running openwrt and here is my results:
[  4]   0.00-30.00  sec   884 MBytes   247 Mbits/sec    1             sender
[  4]   0.00-30.00  sec   883 MBytes   247 Mbits/sec                  receiver
seems to be slower than what it is supposed to be. any suggestions?
Edit : never mind. did the same test from my desktop to router and got similar result, so it should be my network settings. will try to figure it out.
(08-21-2016, 11:31 AM)androsch Wrote: Have ordered this switch today and will connect my Pine64+ with this switch and all of my GbE-PCs again (each separately and without any other ports active and new cables also). Will take some time (delivery till 24th), so will come back then...
some results with the new switch:
Pine64 as client, only connected via the new switch to the destop: [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.01  sec   470 MBytes   394 Mbits/sec  254             sender [  4]   0.00-10.01  sec   470 MBytes   394 Mbits/sec                  receiver acting as server, same bad speed again: [ ID] Interval           Transfer     Bandwidth [  5]   0.00-10.05  sec   693 KBytes   565 Kbits/sec                  sender [  5]   0.00-10.05  sec   606 KBytes   494 Kbits/sec                  receiver BUT: while i had to change my network config to give the pine and the desktop a fixed ip for the test, i got some errors during ethtool or ifup/ifdown, so it seems there is something messed up with my network config on the Pine. Could not yet figure it out, cause only chage i made was on /etc/network/interfaces: # interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: source-directory /etc/network/interfaces.d # Disable wlan1 by default (8723bs has two intefaces) iface wlan1 inet manual auto eth0 iface eth0 inet dhcp #       mtu 1492 #iface eth0 inet static #       address 192.168.178.63 #       netmask 255.255.255.0 #       broadcast 192.168.178.255 #       network 192.168.178.0 #       mtu 1492 #       gateway 192.168.178.1 For the switch as standalon i commented the dhcp-section and activated the fixed ip-part, same here in /etc/network/interfaces.d/eth0 auto eth0 iface eth0 inet dhcp ##      mtu 1492 #iface eth0 inet static #      address 192.168.178.63 #       netmask 255.255.255.0 #       broadcast 192.168.178.255 #       network 192.168.178.0 #       mtu 1492 #       gateway 192.168.178.1 mtu 1492 is always disabled, that was something i tried earlier...
With dhcp the interface eth0 is coming up and the Pine connects to the network.
With fixed address it boots (had to check with a monitor attached, normally it's headless), but the interface only comes up after logging in at the terminal and calling ifup eth0 as root. It gives a warning (didn't copy that unfortunately), but afterwards the eth-interface shows up (LEDs are blinking) and ifconfig shows a valid ip.
Will try again to use a brand new image from longsleep and repeat those tests. Maybe i messed up some configs by testing and trial-and-error in the beginning....
At least connected it again with my normal switch and it still gives about 400-500 mbits as client, but server is still poor. So its capable to do GbE, just need to sort out why only as client and fix the server part...
Will keep you posted.
(08-24-2016, 11:41 AM)androsch Wrote: With fixed address it boots (had to check with a monitor attached, normally it's headless), but the interface only comes up after logging in at the terminal and calling ifup eth0 as root. It gives a warning (didn't copy that unfortunately), but afterwards the eth-interface shows up (LEDs are blinking) and ifconfig shows a valid ip.
OK guys, here to come my last results:
made a new sdcard with latest image from longsleep, attached fixed ip and mac-addr, updated to latest kernel and uboot, run all helper-scripts including network-tuning and just connected the pine and my desktop via 2 short cable to the new switch (same model longsleep mentioned). No other port connected, so only those two on 2 ports of the switch.
Speed for iperf3 as client again was good with max. 872mbits, about 650 mbits avarage, but server speed from the pine still is:
[  4]   0.00-10.02  sec   567 KBytes   464 Kbits/sec                  sender
[  4]   0.00-10.02  sec   503 KBytes   411 Kbits/sec                  receiver
The problems with connecting above were gone, just made only /etc/network/interfaces smaller (no definitions, only disabled wlan1) and attached a fixed 100 mbs speed full duplex via ethtool in the /etc/network/interfaces.d/eth0 file.
Booting works still fine, pine 64 reduces speed to 100mbs even on a 1000mbs port on my normal switch and works still ok with this fixed and reduced speed, but no GbE even with longsleeps switch and new basic image. So i'm running out of ideas and options here by myself and hope for any ideas?
Good evening Huh
OK guys, here to come something for you all to think about:
Could not stop thinking about longsleeps success to have about full GbE speed with my board while i'm not capable to do this.
So i used my laptop to boot via my PXE-server and start a actual linux session with it, not Win10.
ubuntu-gnome@ubuntu-gnome:~$ uname -a
Linux ubuntu-gnome 4.4.0-21-generic #37-Ubuntu SMP Mon Apr 18 18:33:37 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Here i could also use a iperf and an iperf3 server for the pine64 and connect as iperf and iperf3 client also. Something interesting:
ubuntu-gnome@ubuntu-gnome:~$ iperf -c pine64.home.lan -P 4 ------------------------------------------------------------ Client connecting to pine64.home.lan, TCP port 5001 TCP window size: 85.0 KByte (default) ------------------------------------------------------------ [  6] local 192.168.178.200 port 33622 connected with 192.168.178.63 port 5001 [  3] local 192.168.178.200 port 33616 connected with 192.168.178.63 port 5001 [  4] local 192.168.178.200 port 33618 connected with 192.168.178.63 port 5001 [  5] local 192.168.178.200 port 33620 connected with 192.168.178.63 port 5001 [ ID] Interval       Transfer     Bandwidth [  3]  0.0-10.0 sec   251 MBytes   210 Mbits/sec [  6]  0.0-10.0 sec   248 MBytes   208 Mbits/sec [  4]  0.0-10.0 sec   240 MBytes   201 Mbits/sec [  5]  0.0-10.0 sec   216 MBytes   181 Mbits/sec [SUM]  0.0-10.0 sec   956 MBytes   801 Mbits/sec But running iperf3: ubuntu-gnome@ubuntu-gnome:~$ iperf3 -c pine64.home.lan -P 4 Connecting to host pine64.home.lan, port 5201 [  4] local 192.168.178.200 port 54036 connected to 192.168.178.63 port 5201 [  6] local 192.168.178.200 port 54038 connected to 192.168.178.63 port 5201 [  8] local 192.168.178.200 port 54040 connected to 192.168.178.63 port 5201 [ 10] local 192.168.178.200 port 54042 connected to 192.168.178.63 port 5201 [ ID] Interval           Transfer     Bandwidth       Retr  Cwnd [  4]   0.00-1.00   sec   161 KBytes  1.32 Mbits/sec   17   2.83 KBytes        [  6]   0.00-1.00   sec   174 KBytes  1.42 Mbits/sec   26   2.83 KBytes        [  8]   0.00-1.00   sec   157 KBytes  1.29 Mbits/sec   23   2.83 KBytes        [ 10]   0.00-1.00   sec   215 KBytes  1.76 Mbits/sec   29   2.83 KBytes        [SUM]   0.00-1.00   sec   707 KBytes  5.79 Mbits/sec   95              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   1.00-2.00   sec   107 KBytes   880 Kbits/sec   21   1.41 KBytes        [  6]   1.00-2.00   sec   318 KBytes  2.61 Mbits/sec   51   5.66 KBytes        [  8]   1.00-2.00   sec   146 KBytes  1.19 Mbits/sec   25   2.83 KBytes        [ 10]   1.00-2.00   sec   106 KBytes   869 Kbits/sec   16   2.83 KBytes        [SUM]   1.00-2.00   sec   677 KBytes  5.55 Mbits/sec  113              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   2.00-3.00   sec  69.3 KBytes   568 Kbits/sec   10   2.83 KBytes        [  6]   2.00-3.00   sec   206 KBytes  1.69 Mbits/sec   34   2.83 KBytes        [  8]   2.00-3.00   sec   204 KBytes  1.67 Mbits/sec   23   2.83 KBytes        [ 10]   2.00-3.00   sec   109 KBytes   892 Kbits/sec   20   2.83 KBytes        [SUM]   2.00-3.00   sec   588 KBytes  4.82 Mbits/sec   87              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   3.00-4.00   sec   188 KBytes  1.54 Mbits/sec   21   2.83 KBytes        [  6]   3.00-4.00   sec   191 KBytes  1.56 Mbits/sec   24   1.41 KBytes        [  8]   3.00-4.00   sec  91.9 KBytes   753 Kbits/sec   18   2.83 KBytes        [ 10]   3.00-4.00   sec   334 KBytes  2.73 Mbits/sec   42   2.83 KBytes        [SUM]   3.00-4.00   sec   805 KBytes  6.59 Mbits/sec  105              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   4.00-5.00   sec  60.8 KBytes   498 Kbits/sec   11   2.83 KBytes        [  6]   4.00-5.00   sec  63.6 KBytes   521 Kbits/sec   14   1.41 KBytes        [  8]   4.00-5.00   sec   129 KBytes  1.05 Mbits/sec   18   1.41 KBytes        [ 10]   4.00-5.00   sec   144 KBytes  1.18 Mbits/sec   22   2.83 KBytes        [SUM]   4.00-5.00   sec   397 KBytes  3.25 Mbits/sec   65              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   5.00-6.00   sec  70.7 KBytes   579 Kbits/sec   21   2.83 KBytes        [  6]   5.00-6.00   sec   127 KBytes  1.04 Mbits/sec   20   1.41 KBytes        [  8]   5.00-6.00   sec   127 KBytes  1.04 Mbits/sec   25   1.41 KBytes        [ 10]   5.00-6.00   sec  63.6 KBytes   521 Kbits/sec    9   1.41 KBytes        [SUM]   5.00-6.00   sec   389 KBytes  3.19 Mbits/sec   75              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   6.00-7.00   sec   212 KBytes  1.74 Mbits/sec   39   7.07 KBytes        [  6]   6.00-7.00   sec   127 KBytes  1.04 Mbits/sec   17   2.83 KBytes        [  8]   6.00-7.00   sec  63.6 KBytes   521 Kbits/sec   14   1.41 KBytes        [ 10]   6.00-7.00   sec  63.6 KBytes   521 Kbits/sec   14   2.83 KBytes        [SUM]   6.00-7.00   sec   467 KBytes  3.82 Mbits/sec   84              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   7.00-8.00   sec   156 KBytes  1.27 Mbits/sec   31   2.83 KBytes        [  6]   7.00-8.00   sec  63.6 KBytes   521 Kbits/sec   12   1.41 KBytes        [  8]   7.00-8.00   sec   141 KBytes  1.16 Mbits/sec   23   2.83 KBytes        [ 10]   7.00-8.00   sec  76.4 KBytes   626 Kbits/sec   26   5.66 KBytes        [SUM]   7.00-8.00   sec   437 KBytes  3.58 Mbits/sec   92              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   8.00-9.00   sec   150 KBytes  1.23 Mbits/sec   29   2.83 KBytes        [  6]   8.00-9.00   sec  63.6 KBytes   521 Kbits/sec   13   1.41 KBytes        [  8]   8.00-9.00   sec  67.9 KBytes   556 Kbits/sec   18   5.66 KBytes        [ 10]   8.00-9.00   sec   257 KBytes  2.11 Mbits/sec   39   2.83 KBytes        [SUM]   8.00-9.00   sec   539 KBytes  4.41 Mbits/sec   99              - - - - - - - - - - - - - - - - - - - - - - - - - [  4]   9.00-10.00  sec  66.5 KBytes   545 Kbits/sec   14   1.41 KBytes        [  6]   9.00-10.00  sec   338 KBytes  2.77 Mbits/sec   36   4.24 KBytes        [  8]   9.00-10.00  sec   150 KBytes  1.23 Mbits/sec   38   4.24 KBytes        [ 10]   9.00-10.00  sec  63.6 KBytes   521 Kbits/sec   12   1.41 KBytes        [SUM]   9.00-10.00  sec   618 KBytes  5.06 Mbits/sec  100              - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-10.00  sec  1.21 MBytes  1.02 Mbits/sec  214             sender [  4]   0.00-10.00  sec  1.15 MBytes   964 Kbits/sec                  receiver [  6]   0.00-10.00  sec  1.63 MBytes  1.37 Mbits/sec  247             sender [  6]   0.00-10.00  sec  1.42 MBytes  1.19 Mbits/sec                  receiver [  8]   0.00-10.00  sec  1.25 MBytes  1.05 Mbits/sec  225             sender [  8]   0.00-10.00  sec  1.18 MBytes   988 Kbits/sec                  receiver [ 10]   0.00-10.00  sec  1.40 MBytes  1.17 Mbits/sec  229             sender [ 10]   0.00-10.00  sec  1.33 MBytes  1.11 Mbits/sec                  receiver [SUM]   0.00-10.00  sec  5.49 MBytes  4.61 Mbits/sec  915             sender [SUM]   0.00-10.00  sec  5.07 MBytes  4.25 Mbits/sec                  receiver Of course the pine also was set up as server in iperf resp. iperf3 mode (iperf[3] -s).
So while longsleep also only checked my board with iperf only (see http://forum.pine64.org/showthread.php?t...8#pid11838), i wonder whether he assumed the 'good' speed it shows with iperf to be fine and didn't try iperf3? @longsleep: Can you remember?
So maybe this also is part of the problem, iperf shows perfect speed and iperf3 not!
Can not test the real speed other than via iperf(3), because of the PXE-server there is no real disk on the host to copy to with the Pine as server (PXE-server is only a 100mbs machine), but at least the file (1.2GB from a samba share on the pine) copied with about 10.5MB/s, so about 100mbits, thats at least full speed for the PXE-host...
Trying to copy 3 samba-share files from the Pine to an also GbE network drive had about 13MB/s speed, so more than 100mbs, writing them back to the pine only had about 200kb/s,  seems also very slow, but the disc at the pine is a SD-card, so the speed of this samba file test mainly depends on the reading/writing speed of the card!
Maybe this also helps to figure something out? Maybe the problem is caused by Win10 as client/server also? Can anybody also try to check his speeds with iperf and iperf3?
  Howto use MAC address as printed on the label on the back longsleep 3 9,833 08-21-2016, 07:31 AM
Last Post: MarkHaysHarris777
