Change mouse pointer colour
HI,
I've been using PINE64 since I received it and have had no problems, once I burned Android to my SD Card. I won't mention the airmouse as I@m not using it but rather the Minix M1 which is far superior [actually works]
My question[s] is : Is there any way of changing the mouse pointer to be more noticeable? At the moment, it's predominantly dark with a slight light outline. Is there a way to reverse this where the mainly light with a dark outline. Or maybe have a settings toggle to toggle between 2 or 3 options?
For example, if I'm watching Netflix, it's all but impossible to see the pointer. I have to search the screen. It's a minor annoyance but would be great if it was just gone Smile
The mouse pointer is not configurable in the image; however, look around, there may be mouse apps on the play store or on the Net that would allow for mouse pointer options (I mean basically, its just a bitmap in the image).
(08-03-2016, 08:17 AM)MarkHaysHarris777 Wrote: The mouse pointer is not configurable in the image;  however, look around, there may be mouse apps on the play store or on the Net that would allow for mouse pointer options (I mean basically, its just a bitmap in the image).
I was more asking the image creators if they could build this in. I have a few android boxes and all of them have a white pointer. This is the first one where the pointer is dark. When you are sitting 10 to 20 feet away from the TV, it's kind of hard to see Smile
First world problems.....
I realize what you are asking, and from whom.  The answer is still the same.
At this point in time there is no channel for relaying Android improvements on to the engineers working on the images.  To put this more simply, the image is what it is at the moment.  That may change. I have deliberately attempted to find out where bug reports or code improvements should go ... and there is no clear answer at this time.
I regret that  that is the answer.
  Change Android boot logo? ipsw 5 17,447 05-03-2017, 09:39 PM
Last Post: Quezbeme
  Does wireless mouse work? marco97pa 5 10,072 06-30-2016, 08:40 PM
Last Post: pedalman
  Android can not see my bluetooth mouse Punkyclown 5 12,064 06-16-2016, 02:43 PM
Last Post: Ghost
  Change MicroSD card AA666 2 7,081 05-26-2016, 01:20 PM
Last Post: AA666
  Remove mouse acceleration in Android 5.1.1? instanteggrolls 0 5,321 05-18-2016, 08:43 AM
Last Post: instanteggrolls
  odd mouse wheel issue with 20160505 chrwei 1 4,042 05-14-2016, 05:51 PM
Last Post: octopus
  Mouse? Nion 5 10,386 04-04-2016, 05:03 PM
Last Post: Nion
