USB Capture Card??
Would this USB video capture card work with Android 5.1 plus touchscreen I have installed
It's a AV.Io Capture card.
https://www.epiphan.com/products/avio-sdi/
Here's the minimum requirements
Video capture workstation operating system Windows 7, Windows 8.1, Windows 10 Mac OS X 10.10 and up Linux distribution with kernel 3.5.0 or higher
On the download page it says Ubuntu 14.04 LTS 64-bit and similar
https://www.epiphan.com/products/avio-sd...downloads/
(08-01-2016, 11:05 PM)AUDIOTEK Wrote: Would this USB video capture card work with Android 5.1 plus touchscreen I have installed
Hmm, my guess is no since Android isn't one of the listed supported operating systems.
There may be ways to get it to work, but it definitely wouldn't be a plug and play experience, I wouldn't have thought. It depends if Android is similar enough to Ubuntu, which I don't think it is (despite both being Linux-based).
So my best bet would be to install Ubuntu on the Pine? Only issue is I need the touch screen for that project. You know if there's any plans of developing Ubuntu with the touchscreen option?
One of our team is working on LCD for gnu+linux;  he actually has the device now, and is working to get things going on that unit.   I don't expect it will be long, no promises mind you, but it is definitely on the way... so sit tight...
marcus
  PoE Daughter card Option? bigmacattack 3 10,485 02-10-2016, 07:10 PM
Lightbulb Server Oriented Card JigenEagle 9 20,207 01-20-2016, 07:00 AM
Last Post: hazerty
