Kodi Network
I am not able to play movie files via my network on Kodi (android OS)
Kodi is buffering and the file stops playing. No fluent playback at all..
Is this also related to the pine64 network issues?
I am getting the same "buffering" notice on KODI movie file playback, I'm using REMIX. And it happens not matter if my Pine64 is wirelessly or LAN connected. This thing is becoming a pile of....to work with. What gives?
Must be a network issue as kodi on my raspberry pi works perfect.
Running the standard Android release.  I was having the same issue.  I wiped the cache partition and then factory reset it.  Now everything installs properly and runs properly.
(08-18-2016, 10:45 AM)gwaligorski Wrote: Running the standard Android release.  I was having the same issue.  I wiped the cache partition and then factory reset it.  Now everything installs properly and runs properly.
Is it possible to explain how you wiped the cach partition and did the factory reset?
Thanks!
  Kodi on Android Mikiya 82 231,940 04-12-2018, 03:39 PM
Last Post: S265
  Android 7.1 - KODI & PVR Add on (VU+) Partymack711 0 3,674 02-14-2018, 12:08 PM
Last Post: Partymack711
  Which image runs Kodi & plays You Tube video koda 2 7,258 07-12-2016, 07:55 AM
Last Post: koda
  Stream torrents with Kodi on Android Treville 1 9,540 07-09-2016, 05:49 AM
Last Post: Treville
  KODI??? mcc1961 6 13,240 05-30-2016, 07:05 AM
Last Post: g_t_j
  Mounting network NFS/CIFS shares simmo 1 9,053 05-28-2016, 09:14 PM
Last Post: UnixOutlaw
Question slow wired network bongo 3 8,403 05-18-2016, 04:36 AM
Last Post: Luke
  network kdarius 0 2,623 04-27-2016, 10:01 AM
Last Post: kdarius
