Audio Passthrough in SPMC Working
Information
While I could not get Kodi to correctly reproduce AC3 audio via pass-through (cuts out for a fraction of a second every 5-10 seconds or so), I have been able to achieve correct AC3 audio reproduction with SPMC.  Playback of recorded mpeg-ts files has been great with no video sync issues or audio issues.  However, I am not getting great playback of live TV (via HDHomerun via tvheadend on an Odroid C1+).  I will need to explore that more, but more than likely it is related to my network/NAS setup.  The best playback experience of NAS mpeg-ts files has been through using Plex / MX player mashup.
My current settings / setup for SPMC is listed out below:
  • Android: 5.1.1 HDMI image release 20160505 64gb version non-rooted
  • SPMC build: SPMC 16.3-0 Git:2016-04-30-22df3d0-dirty
  • CAT 6 cables between as many devices as possible: Pine64 and Fast Ethernet (100/10) Switch which is then connected to my router (not sure if this made a difference as I did not methodically test it, but before CAT 6 I had lesser cables between some of these devices and I know at that time SPMC was not working correctly either)
  • HDMI from Pine64 to Marantz Receiver
SPMC Options:
Videos:
     Playback:
         Adjust display refresh rate: On start / stop
         Sync playback to display: Off
     Acceleration:
         Allow hardware acceleration -MediaCodec
System:
     Audio output:
         Audio output device: Android, RAW Passthrough
         Number of channels: 7.1
         Output Configuration: Fixed
         Limit sampling rate (kHz): 48.0
         Stereo upmix: On
         Maintain original volume on downmix: On
         Resample quality: High
         Enable audio DSP processing: Off
Hopefully someone can build off of this and continue to improve the Pine64 media experience.
Actually, Android and Remix plays my live TV streams using tvheadend backend and HDHomeRun tuners.
Starts around the 3 minute mark.
https://www.youtube.com/watch?v=nPaSRIurhj8
(07-13-2016, 08:44 AM)clarkss12 Wrote: Actually, Android and Remix plays my live TV streams using tvheadend backend and HDHomeRun tuners.
I hadn't tried direct streams but that isn't my goal for my system.  While I am familiar with the apps used in that video and have those on my personal phone, I intend to use Pine64 with SPMC/Kodi so that I may make use of the timeshift abilities of tvheadend.  But perhaps I'll make use of TVHClient as a stop-gap measure until live TV in SPMC improves.  Thanks.
Hi
thank you for sharing your setup.
Are you getting 7.1 audio with those settings?
(09-25-2016, 10:01 AM)FoZo Wrote: Hi
That is a great question and I do not have an answer for you at this time.  While I have 7.1 selected in my settings, I don't have a single file that contains 7.1 audio. The most I have seen in my movie/HDTV recordings has been 5.1 audio.  I will need to try ripping a movie with 7.1 audio....or find a 7.1 audio test file online somewhere.
But at least 5.1 audio works fine?
While 5.1 works there still remains issues with overall sync between the video and audio. The video tends to stutter without affecting the audio.
(07-12-2016, 11:21 PM)czechr08 Wrote: While I could not get Kodi to correctly reproduce AC3 audio via pass-through (cuts out for a fraction of a second every 5-10 seconds or so), I have been able to achieve correct AC3 audio reproduction with SPMC.  Playback of recorded mpeg-ts files has been great with no video sync issues or audio issues.  However, I am not getting great playback of live TV (via HDHomerun via tvheadend on an Odroid C1+).  I will need to explore that more, but more than likely it is related to my network/NAS setup.  The best playback experience of NAS mpeg-ts files has been through using Plex / MX player mashup.
SPMC Options:
Videos:
     Playback:
     Acceleration:
System:
     Audio output:
         Stereo upmix: On
I tried this setup with the last build (5.1.1 2016-10-19) and spmc 16.4.2 from the playstore. I don't have 5.1 surround. How did you do ? When i set "Output Configuration: Fixed", the passthrough option below is hidden. I only can set passthrough "on" with "Output Configuration: Optimized or Best match". When i set the passthrough option ON, i only get crashed sound. Did you tried that setup with updated software like mine since your post ?
SPMC Options:
Videos:
     Playback:
     Acceleration:
System:
     Audio output:
         Stereo upmix: On
I originally obtained SPMC via github, not the playstore.  When I have time later tonight I will try getting the latest build from github and see if I can make all the option changes that I could make in 16.3. I have not tried it with the latest android build for Pine64 (5.1.1 2016-10-19). I am still on android build 5.1.1 2016-07-11.
  3,5mm audio out not working MikkoL 9 23,353 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  MTP Stopped Working miller08 0 4,871 12-24-2019, 02:42 AM
Last Post: miller08
  Android audio Danbrack 0 3,586 03-24-2018, 10:51 PM
Last Post: Danbrack
  Wiki version of Android 7.1 not working with touchscreen abba2566 3 8,877 02-28-2018, 08:02 AM
Last Post: wezzjm
  <•••> and no audio on my android is Help PoppaLeague 0 3,335 09-10-2017, 01:32 AM
Last Post: PoppaLeague
  Microphone / Audio In iammackinnon 4 10,327 04-24-2017, 07:03 AM
Last Post: kenjiru
  Android 6.0 TV analog audio Ophir 2 7,834 02-02-2017, 03:55 PM
Last Post: Ophir
  HDMI not working gubaguba 7 14,518 01-25-2017, 09:45 PM
Last Post: MakerLing81
  Netflix and Twitter no longer working Punkyclown 0 3,853 10-20-2016, 08:45 AM
Last Post: Punkyclown
  USB Audio? mesaxi 3 7,553 09-28-2016, 09:45 PM
Last Post: mikey0000
