Dead Board??
So got the board about two weeks ago and am trying to get it to boot. I have the LCD so down loaded the Phoenix card image for the LCD screen. Have Sandisk 32GB microSD I purchased from BH Photo so confident it was not a fake.  Phoenix card runs fine without any issues and installs image no error messages. Put in board power it up and nothing. No screen flicker or anything. The LED on board comes on for about 3 seconds then goes off. Power supply is from Pine64.
Did you select Startup! in the Write Mode field? Otherwise try to write another image with win32diskimager just to test the board via HDMI... for example you can use https://www.pine64.pro/getting-started-linux/ from lenny's site
I got it working. I think the WiFi Bluetooth module was preventing initial boot. I unplugged the module, and removed the SD card and powered up the board, turned off, inserted the SD card and it booted fine. After initial boot, shutdown and plugged in WiFi Bluetooth module and it booted fine and I could connect to WiFi without issue.
  Design custom board behnam_sh 6 17,220 07-11-2017, 12:26 PM
Last Post: xalius
  Linux is always crashing - bad board? hscharke 3 9,311 09-24-2016, 09:57 PM
Last Post: cyphergenetics
Exclamation Pine A64+ 2GB Board Schematic wenderfit 19 39,008 09-13-2016, 06:37 PM
  Board will not boot/does not work major7 2 6,884 09-03-2016, 02:53 AM
Last Post: major7
  new 2gb board not booting to known good image mythocelt 3 8,039 06-04-2016, 09:41 AM
Last Post: martinayotte
Bug Pine64+ not starting up. Did I receive dead motherboard? asardiwal 1 5,681 04-24-2016, 12:16 PM
Last Post: androsch
  revision board hazerty 8 17,541 03-01-2016, 03:35 PM
