Booting off iSCSI
After building kernel 3.10.102 based on longsheep's sources I now have working iSCSI support on my Pine64, however, I can't figure out the correct arguments to put into uEnv.txt to actually boot off iSCSI - has anyone gotten this working and if so, what does your uEnv.txt look like?
Thanks!
(07-07-2016, 12:43 PM)mgamble Wrote: After building kernel 3.10.102 based on longsheep's sources I now have working iSCSI support on my Pine64, however, I can't figure out the correct arguments to put into uEnv.txt to actually boot off iSCSI - has anyone gotten this working and if so, what does your uEnv.txt look like?
Thanks!
You use 'rootwait' along with root=<device>
... which points the /boot to the iSCI location where the root partition is mounted.
marcus
Any chance some one has a complete set of steps to boot off iSCSI?  Would like to be able to boot and run off of my NAS instead of from the SDCard
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,198 07-13-2017, 08:38 PM
Last Post: cztian
Question Show pine logos when booting Pander 6 13,238 08-10-2016, 07:12 AM
Last Post: Pander
  Android kernel booting drag00n 23 53,568 02-18-2016, 09:51 AM
Last Post: taros
